Event behavior
Available with Location Referencing license.
Events are located along a route in a linear referencing system (LRS). Changes in the route due to route editing activities such as extend, realign, reassign, retire, reverse, cartographic realignment, and calibration have a direct impact on how events are located and how they are rendered on a map. Behavior changes with measure or geographic location, or both, on one or more events due to route editing are called event behaviors.
ArcGIS Pipeline Referencing keeps event measures and geographic location (x,y), in alignment with route edits. You can configure event behavior rules for an individual event layer to define how event measures and shapes are updated for each type of route edit.
In the following example, a portion of Route1 is retired. This edit activity affects Event1 according to the event layer's configured event behavior.
Before retirement
After the route is retired, the events are updated using event behavior rules, which are set at the event layer level.
After retirement
Types of event behavior rules
When an LRS route is edited, event behavior rules are applied to the events. By configuring event behavior rules at the layer level, you can specify how the event responds when the route changes: preserve location, preserve measure, or maintain referent location.
Location Referencing supports the following event behaviors:
Event behavior rule
Stay Put
Preserves the geographic location of the event; measures can change
Move
Preserves the measure or measures of the event; geographic location can change
Retire
Preserves both measure and geographic location; event is retired
Snap
Preserves the location of an event by snapping the event to a reassigned or abandoned route; measure or measures can change
Cover
Changes both measure and geographic location to make the event go across the entire route
Honor Route Measure
Preserves the measure of the event or changes the measure proportionally to the route measure change
Honor Referent Location
Changes both measure and geographic location to maintain the referent location of the event using a persistent offset value
To understand how LRS events get updated due to the route edit type for each event behavior rule, see the following:
Configuration of event behavior rules
Default event behavior is configured during the event registration process when using either the Create LRS Event or Create LRS Event From Existing Dataset tool.
The following event behavior rules are set by default:
Activity
Rule
Calibrate Route
Stay Put
Retire Route
Stay Put
Extend Route
Stay Put
Reassign Route
Stay Put
Realign Route
Stay Put
Reverse Route
Stay Put
Carto Realign Route
Honor Route Measure
You can review configured event behaviors by viewing LRS event properties and modifying the default behavior for route calibration, route retirement, route extension, route reassignment, route realignment, route reversal, and cartographic realignment using the Modify Event Behavior Rules tool.
When Recalibrate route downstream is chosen for an LRS route edit, the configured calibrate event behavior is applied to downstream sections. You can review configured event behaviors by viewing LRS event properties.
The reassignment method, route edit, and event behaviors are described below.
Apply event behavior
To apply event behaviors after route edits, run the Apply Event Behaviors tool for the route network. This tool processes event behaviors for all event feature classes registered to the route network.
You do not need to run the Apply Event Behaviors tool after each route edit activity. You can schedule it to run based on your business requirements. It only processes event behaviors for those routes that have been edited but not yet processed.
Events that span routes on a line network
Pipeline Referencing supports events that span routes when those routes are on the same line in a line network. In cases where an event spans multiple routes on the same line, route editing impacts events on that line. The impact that your edits have on events that span routes depends on the configured event behavior.
For example, in the diagram below, route editing impacts both events once event behaviors are applied.
Route1, Route2, Route3, and Route4 are part of the same line. Event1 spans Route1 and ends in Route3, while Event2 starts in Route3 and ends in Route4. A portion of routes 2 and 3 are retired from measures 18 to 32.
Before retirement
Once event behaviors are updated, the result of the route edit affects both Event1 and Event2. In the following example, Stay Put has been applied.
After retirement
