Modify Event Behavior Rules (Location Referencing Tools)
Summary
Modifies event behavior rules for the registered event layer or feature class.
Usage
  • The following event behavior rules are set by default:
    Activity
    Rule
    Calibrate Route
    Stay Put
    Retire Route
    Stay Put
    Extend Route
    Stay Put
    Reassign Route
    Stay Put
    Realign Route
    Stay Put
    Reverse Route
    Stay Put
    Carto Realign Route
    Honor Route Measure
Parameters
Label Explanation Data type
Event Feature Class
The event feature class.
Feature Layer
Calibrate Rule
(Optional)
Specifies the event behavior rule that will be defined for the calibrate activity.
  • Stay put—The geographic location of the event will be preserved; measures may change. This is the default.
  • Retire—Both measure and geographic location will be preserved; the event will be retired.
  • Move—The measures of the event will be preserved; the geographic location may change.
String
Retire Rule
(Optional)
Specifies the event behavior rule that will be defined for the retire activity.
  • Snap—The geographic location of the event will be preserved by snapping the event to a concurrent route; measures may change.
String
Extend Rule
(Optional)
Specifies the event behavior rule that will be defined for the extend activity.
  • Cover—The geometric location and measure of a line event will be modified to include a new or newly modified section.
String
Reassign Rule
(Optional)
Specifies the event behavior rule that will be defined for the reassign activity.
String
Realign Rule
(Optional)
Specifies the event behavior rule that will be defined for the realign activity.
String
Reverse Rule
(Optional)
Specifies the event behavior rule that will be defined for the reverse activity.
String
Carto Realign Rule
(Optional)
Specifies the event behavior rule that will be defined for the cartographic realignment activity.
  • Honor Route Measure—The measure of the event will be preserved or will change proportionally to the route's measure change. This is the default.
  • Honor Referent Location—The referent location of the event will be preserved.
String
Derived output
Updated Input Feature Class
The updated feature layer.
Feature Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
