An overview of the LRS Event toolset
The LRS Event toolset contains tools to create or modify an LRS event.
Tool name |
Description |
Associates event data stored in an external system with an LRS. |
Configures an external event in an LRS without connecting to an external event system. |
Creates line or point events for an existing LRS Network. |
Registers an existing feature class as an LRS event. |
Disables fields that store the derived network route ID, route name, and measure fields. |
Disables referent fields for an existing linear referencing system (LRS) event feature class or feature layer. It does not delete the referent columns; it removes the referent column information from the Lrs_Metadata table. |
Disables stationing fields for the registered LRS event. |
Enables fields to store the derived route ID, derived route name, and derived measure fields for the specified LRS event feature class. |
Enables or modifies the referent fields so that you can manage referent information for the registered LRS event. |
Enables or modifies stationing fields so that you can manage stationing information for the registered LRS event. |
Modifies event behavior rules for the registered event layer or feature class. |
Modifies properties of a linear referencing system (LRS) event. |
