Disable Referent Fields (Location Referencing Tools)
Summary
Disables referent fields for an existing linear referencing system (LRS) event feature class or feature layer. It does not delete the referent columns; it removes the referent column information from the Lrs_Metadata table.
Usage
  • The referent fields must be enabled for the event prior to running this tool.
Parameters
Label Explanation Data type
LRS Event Feature Class
The input feature class or feature layer for the LRS event.
Feature Layer
Derived output
Updated LRS Event Feature Class
The updated feature layer for the event.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
