Enable Derived Measure Fields (Location Referencing Tools)
Summary
Enables fields to store the derived route ID, derived route name, and derived measure fields for the specified LRS event feature class.
Usage
The fields that will store the derived route ID, derived route name, and derived measure fields need to be available prior to running this tool.
You can use an empty event feature class or event feature class that has loaded records.
Parameters
| Label | Explanation | Data type |
LRS Event Feature Class |
An existing event feature class or feature layer that is registered to an LRS. |
Feature Layer |
Derived Route ID Field (Optional) |
The derived route ID field. |
Field |
Derived Route Name Field (Optional) |
The derived route name field. |
Field |
Derived (From) Measure Field (Optional) |
The derived from measure field. |
Field |
Derived To Measure Field (Optional) |
The derived to measure field. |
Field |
Derived output
Updated Input Feature Class |
The updated feature layer for the event. |
Feature Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
- Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
- Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
