An overview of the Configuration toolset
The Configuration toolset contains tools for creating and modifying an LRS, LRS Networks, and LRS events, as well as configure a utility network for use with an LRS.
Tool |
Description |
Configures the Address Range and Site Address Point feature classes from the Address Data Management solution for use with a linear referencing system (LRS) and the ArcGIS Roads and Highways extension. |
Configures the ArcGIS Utility Network Pipeline Line feature class for use with a linear referencing system (LRS). |
Configures the ArcGIS Utility Network Pipeline Line, Pipeline Device, and Pipeline Junction feature classes for use with a linear referencing system (LRS). |
Removes a linear referencing system (LRS) entity from an input geodatabase workspace. |
Toolset |
Description |
The LRS toolset contains tools to create or modify an LRS. |
The LRS Event toolset contains tools to create or modify an LRS event. |
The LRS Intersection toolset contains tools to create and modify an LRS intersection. |
The LRS Network toolset contains tools that allow you to create and modify LRS Networks. |
