Configure Utility Network Feature Class (Location Referencing Tools)
Summary
Configures a Utility Network pipeline feature class for use with a linear referencing system (LRS).
After configuration, the Route ID Field parameter and the measure columns can be updated as needed.
Legacy:
This is a deprecated tool. This functionality has been replaced by the Configure Utility Network Feature Classes tool.
Usage
Parameters
Label Explanation Data type
Utility Network Feature Layer
The input Utility Network feature that is also the LRS centerline feature.
Feature Layer
Route ID Field
The field in the feature class that will be mapped as the LRS Network Route ID.
Field
From Measure Field
The From measure field of the centerline feature class.
Field
To Measure Field
The To measure field of the centerline feature class.
Field
Derived output
Output Feature Class
The updated Utility Network feature layer.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
