Configure Utility Network Feature Classes (Location Referencing Tools)
Summary
Configures the ArcGIS Utility Network Pipeline Line, Pipeline Device, and Pipeline Junction feature classes for use with a linear referencing system (LRS).
Usage
The Utility Network Pipeline Line feature class serves as the centerline feature class in the LRS.
Learn more about the LRS data model in ArcGIS Pipeline Referencing
This tool supports data from a file geodatabase or an enterprise geodatabase (branch versioned connection).
This tool does not support data from a feature service.
After running this tool, the following are supported:
You can update the route ID and measure fields on the utility network feature classes as needed using the Update Measures From LRS tool.
You can use the utility network feature classes as inputs to the Overlay Events tool for dynamic segmentation.
Parameters
| Label | Explanation | Data type |
Utility Network Line Layer |
The input Utility Network Pipeline Line feature class that will serve as the LRS centerline feature class. |
Feature Layer |
Line Route ID Field |
The field in the Pipeline Line feature class that will be mapped as the route ID field in the LRS Network. The data type and length of the field must match those of the corresponding field in the LRS centerline sequence table. |
Field |
Line From Measure Field |
The start measure field of the Pipeline Line feature class. |
Field |
Line To Measure Field |
The end measure field of the Pipeline Line feature class. |
Field |
Utility Network Devices Layer |
The input Utility Network Pipeline Device feature class. |
Feature Layer |
Devices Route ID Field |
The field in the Pipeline Device feature class that contains the route ID attribute. The data type and length of the field must match those of the corresponding field in the LRS centerline sequence table. |
Field |
Devices Measure Field |
The field in the Pipeline Device feature class that contains the measure value for devices. |
Field |
Utility Network Junctions Layer |
The input Utility Network Pipeline Junction feature class. |
Feature Layer |
Junctions Route ID Field |
The field in the Pipeline Junction feature class that contains the route ID attribute. The data type and length of the field must match those of the corresponding field in the LRS centerline sequence table. |
Field |
Junctions Measure Field |
The field in the Pipeline Junction feature class that contains the measure value for junctions. |
Field |
Derived output
Output Line Feature Class |
The updated Utility Network Pipeline Line feature class. |
Feature Layer |
Output Devices Feature Class |
The updated Utility Network Pipeline Device feature class. |
Feature Layer |
Output Junctions Feature Class |
The updated Utility Network Pipeline Junction feature class. |
Feature Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
- Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
- Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
