Remove LRS Entity (Location Referencing Tools)
Summary
Removes a linear referencing system (LRS) entity from an input geodatabase workspace.
Usage
  • This tool performs a cascade delete of LRS entities to prevent any orphaned LRS Networks, LRS events, or LRS intersections. This means that removing an LRS will also unregister all LRS Networks that belong to it, as well as remove all LRS events and LRS intersections that belong to those LRS Networks. Similarly, removing an LRS Network will unregister all LRS events and LRS intersections that belong to that network.
  • The input workspace must contain an ArcGIS Location Referencing LRS.
  • This tool does not delete any feature classes, fields, or data. It updates internal metadata tables that store information about the LRS entities in the input geodatabase workspace.
  • Removing an LRS line network that has an LRS derived network registered will also remove the LRS derived network.
  • Removing an LRS event or LRS intersection unregisters the selected LRS event or LRS intersection; it will not impact the parent LRS Network.
  • Removing a utility network feature class unregisters it from the LRS. It does not delete the feature class from the database.
  • Removing the address management feature classes unregisters both the Address Range and Site Address feature classes from the LRS. It does not delete them from the database.
  • A list of the LRS entities that were removed is provided upon the successful completion of this tool.
  • The output of this tool is a modified geodatabase workspace.
Parameters
Label Explanation Data type
LRS Workspace
The input geodatabase workspace that contains the LRS entity that will be removed.
Workspace
LRS Entity Type
Specifies the type of LRS entity that will be removed from the input geodatabase workspace.
  • LRS—An LRS and its dependent LRS Networks, as well as the LRS events, and LRS intersections registered to those LRS Networks, will be removed.
  • Network—An LRS Network and the LRS events and LRS intersections registered to that LRS Network will be removed.
  • Event—An LRS event will be removed.
  • Intersection—An LRS intersection will be removed.
  • Utility Network Feature Class—A utility network feature class will be removed.
  • Address Feature Class—Address management feature classes will be removed.
String
LRS Entity Name
The name of the LRS entity that will be removed from the input geodatabase workspace. The underlying feature classes and tables of the LRS entity will not be deleted.
String
Derived output
Updated LRS Workspace
The output geodatabase workspace.
Workspace
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
