An overview of the Location Referencing toolbox
The Location Referencing toolbox provides essential tools for the configuration and management of the LRS.
In ArcGIS Pro 3.8, the tools and toolsets in the Location Referencing toolbox will be moved to the Linear Referencing toolbox.
Tool
Append Events
Appends event records from a table, layer, or feature class to an existing LRS event feature class.
Append Routes
Appends routes from an input polyline layer into an LRS Network.
Apply Event Behaviors
Updates the event locations for all event feature classes registered with the input network based on the route edit performed.
Calculate Intersecting Route Measures
Creates a table of all the routes and measures at each intersection location.
Calculate Route Concurrencies
Calculates and reports concurrent route sections in an LRS Network.
Delete Routes
Deletes routes and associated data elements from the LRS Network.
Derive Event Measures
Populates and updates the DerivedRouteID field and measure values on point and line events with those fields configured and enabled.
Generate Calibration Points
Generates calibration points for any route shape provided, including complex shapes such as self-closing, self-intersecting, and branched routes.
Generate Events
Regenerates shapes for event features registered with an LRS Network.
Generate Intersections
Generates new intersections and updates existing intersections.
Generate Routes
Recreates shapes and applies calibration changes for route features in an LRS Network.
Overlay Events
Overlays one or more line and point event layers onto a target network and outputs a feature class or table that represents the dynamic segmentation of the inputs.
Remove Overlapping Centerlines
Removes overlapping centerline sections to ensure that there is one common centerline when centerline geometry overlaps.
Reverse Line Orders
Reverses the line order for all the routes in a line.
Translate Event Measures
Translates the measures (m-values) of a point or line event layer from one linear referencing method (LRM) to another.
Update Measures From LRS
Populates or updates the route and measure attributes on any point or line features, including Utility Network features such as pipes, devices, and junctions, or LRS features such as events and intersections.
Tools in the Location Referencing toolbox
Toolset
Configuration
The Configuration toolset contains tools for creating and modifying an LRS, LRS Networks, and LRS events, as well as configure a utility network for use with an LRS.
Data Products
The Data Products toolset contains tools to create LRS data products.
Toolsets in the Location Referencing toolbox
