Generate Routes (Location Referencing Tools)
Summary
Recreates shapes and applies calibration changes for route features in an LRS Network.
Usage
  • For the Input Route Features parameter use an input whose features need to be regenerated or need calibration changes applied based on the route shape from the centerline feature class, and measure values from the calibration point feature class.
  • If a derived network is configured using a line network, running this tool on the line network will also update the derived network.
  • Routes in the derived network are generated by combining the route shapes in the parent line.
  • When conflict prevention is enabled for the tool, any events being generated by the tool will be locked.
    • While working in the default version, the locks acquired will be released automatically when the tool completes.
    • While working in a named version, the locks acquired will remain in On Post status when the tool completes. The lock owner must post or delete the version to release the locks.
    • While working in a named version, if the tool is canceled by interruption, the locks are acquired and will remain in releasable status when the tool completes.
  • This tool supports conflict prevention and will attempt to acquire and transfer locks.
    Learn more about conflict prevention in ArcGIS Pipeline Referencing or conflict prevention in ArcGIS Roads and Highways.
    Legacy:
    The Record calibration changes for event location updates parameter is no longer supported.
Parameters
Label Explanation Data type
The LRS Network for which route shapes will be regenerated and calibration changes will be applied.
Feature Layer
(Optional)
Legacy:
This parameter is no longer supported.
Boolean
Derived output
Output Route Features
The updated route feature layer.
Feature Layer
Output Derived Route Features
The updated LRS Network to which route shapes have been generated and calibration changes have been applied.
Feature Layer
Output Results File
A text file that details the routes that were updated in the LRS Network feature class.
Text File
Environments
Current Workspace, Parallel Processing Factor
Special cases
The default value for this environment, if left blank, is 0%. Any absolute value for the environment is always clamped between 0 and the number of logical cores in that machine.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
