Location Referencing toolbox history
The tables below catalog changes made to every tool in the toolbox. There is one table per tool and you can click the tool name to go to the tool reference page.
For more information about how to interpret and use these tables, see Toolbox history topics.
Version |
Description |
3.6 |
New parameter added: |
3.5 |
3.2 |
Supports loading events via |
2.1 |
1.4 |
New at this version |
Version |
Description |
3.6 |
2 new parameters added:
3.3 |
3.2 |
2.4 |
Parameter |
2.1 |
Version |
Description |
2.4 |
1.4 |
Version |
Description |
3.1 |
Version |
Description |
2.9 |
Version |
Description |
3.5 |
3.3 |
Version |
Description |
3.3 |
Parameter |
2.9 |
Parameter Parameter
2.8 |
Version |
Description |
3.5 |
Version |
Description |
2.4 |
Version |
Description |
2.9 |
Version |
Description |
2.5 |
Version |
Description |
3.7 |
Version |
Description |
2.1 |
4 new parameters added:
2.0 |
Version |
Description |
2.0 |
Version |
Description |
2.0 |
Version |
Description |
2.0 |
Version |
Description |
2.6 |
Version |
Description |
2.6 |
Version |
Description |
3.5 |
Parameter |
3.0 |
Parameter |
2.0 |
Version |
Description |
2.4 |
Parameter |
2.0 |
Create UPDM Geodatabase
Version |
Description |
2.1 |
Tool removed or moved to another toolbox |
1.4 |
Version |
Description |
2.5 |
2.2 |
Version |
Description |
2.3 |
1.4 |
Version |
Description |
2.1 |
Version |
Description |
2.0 |
Version |
Description |
3.0 |
Version |
Description |
2.1 |
Version |
Description |
3.5 |
Parameter |
3.0 |
Parameter
2.0 |
Version |
Description |
3.5 |
Parameter |
3.0 |
Version |
Description |
3.0 |
Parameter
2.3 |
Version |
Description |
3.7 |
2.9 |
1.4 |
Version |
Description |
3.6 |
2.6 |
Version |
Description |
3.6 |
Version |
Description |
3.6 |
Version |
Description |
3.7 |
An LRS intersection feature class can be used as an input to the |
3.6 |
Version |
Description |
3.6 |
Parameter |
3.5 |
Parameter Parameter |
3.4 |
Version |
Description |
3.2 |
The |
2.3 |
2.2 |
1.4 |
Version |
Description |
3.3 |
Parameter |
2.9 |
Parameter Parameter
2.0 |
Version |
Description |
2.9 |
2.0 |
Version |
Description |
2.0 |
Version |
Description |
2.6 |
Version |
Description |
2.4 |
2.3 |
2.0 |
Version |
Description |
2.9 |
2.6 |
Version |
Description |
2.4 |
Version |
Description |
3.7 |
The Pipeline Device and Pipeline Junction feature classes can be used as inputs to the Environment added: Parallel Processing Factor |
3.5 |
1.4 |
Version |
Description |
3.3 |
Parameter |
2.6 |
Parameter |
2.0 |
Version |
Description |
2.3 |
Version |
Description |
3.2 |
Version |
Description |
1.4 |
Version |
Description |
3.5 |
2.5 |
