Create LRS Event From Existing Dataset (Location Referencing Tools)
Summary
Registers an existing feature class as an LRS event.
Usage
Parameters
Label Explanation Data type
Parent LRS Network
The network to which the event will be registered.
Feature Layer
Event Feature Class
The event to be registered.
Feature Layer
Event ID Field
The event ID field in the event feature class.
Field
Route ID Field
The route ID field if the feature class is a point event that doesn't span routes or the from route ID field if the feature class is a line event that spans routes.
Field
From Date Field
The from date field in the event feature class.
Field
To Date Field
The to date field in the event feature class.
Field
Loc Error Field
The location error field in the event feature class.
Field
Measure Field
The measure field if the feature class is a point event or the from measure field if the feature class is a line event.
Field
To Measure Field
(Optional)
The to measure field in the event feature class. This parameter is required for line events.
Field
Event Spans Routes
(Optional)
Specifies whether the event records will span routes.
  • Checked—The event records will span routes.
  • Unchecked—The event records will not span routes. This is the default.
Boolean
To Route ID Field
(Optional)
The to route ID field for events that span routes. This parameter is required if the event feature class geometry type is polyline.
Field
Store Route Name
(Optional)
Specifies whether the route name will be stored with the event records.
  • Checked—The route name will be stored with the event records.
  • Unchecked—The route name will not be stored with the event records. This is the default.
Boolean
Route Name Field
(Optional)
The route name field if the feature class is a point event that doesn't span routes or the from route name field if the feature class is a line event that spans routes. This parameter is required if Store Route Name is checked.
Field
To Route Name Field
(Optional)
The to route name field for line events that span routes. This parameter is required if Store Route Name is checked.
Field
Derived output
Output Event Feature Class
The updated event feature layer.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
