LRS data model
Available with Location Referencing license.
The linear referencing system (LRS) is a collection of feature classes and tables that allow the storage and editing of calibrated routes.
The LRS supports the use of a line feature class, known as a centerline, to store the geometry for multiple routes. Centerline geometry, along with route definitions, are stored in a network feature class.
A many-to-many relationship exists between the routes in the network and centerlines providing the geometry. This means that routes are typically composed of multiple centerline features, and centerline features can participate in multiple routes in multiple networks.
LRS Data Model
In addition to geometry, routes must also have measures. The LRS uses route measures to display event layers in their correct locations on a map. Measures are added to routes through a process known as calibration. To explicitly control how routes are calibrated, the LRS uses a calibration point feature class.
Calibration points are point features that store measure values, route references, and network IDs. The combination of these three items constitutes a linear referencing method (LRM). LRMs are created by applying calibration points to routes to create an LRS Network.
The LRS includes the following feature classes and tables:
  • Centerline—The polyline feature class that stores route geometry.
  • Centerline sequence—The cross-reference table that manages the relationship between centerlines and routes.
  • Calibration point—The point feature class that stores route measure values.
  • Redline—The polyline feature class that stores markup features for communicating LRS changes.
Feature classes and tables are created with all necessary fields when running the Create LRS tool.
Feature dataset requirement
To support service-based editing of data in Roads and Highways, certain feature classes in the LRS data model must reside in a geodatabase feature dataset. If the feature classes and tables are modeled in advance, the following feature classes are required and must be contained in a feature dataset:
  • Calibration Point
  • Centerline
  • Events
  • Intersections
  • Networks
  • Redline
  • If you use the Create LRS tool to create an LRS and minimum-required schema items, these feature classes are automatically placed in a feature dataset.
  • If the LRS was created using ArcMap, you must move these feature classes into a feature dataset and run the Modify LRS tool to edit the LRS in ArcGIS Pro.
Version Management requirement
LRS data you publish as a service must be branch versioned, and the Version Management capability must be enabled when it is published as a service.
Before publishing, LRS feature classes and tables require more fields for version management, such as GlobalIDs.
Learn more about registering a dataset using branch versioning requirements
Learn more about publishing with the Linear Referencing and Version Management capabilities
LRS dataset
A linear referencing system (LRS) dataset is a controller dataset in a feature dataset in the geodatabase along with all the feature classes that participate in the LRS.
You can view the LRS hierarchy from the Contents or Catalog pane.
The following tools create an LRS dataset:
  • Create LRS—The newly created centerline, calibration point, and redline feature classes are placed in a feature dataset with the same name as the provided LRS name.
  • Create LRS From Existing Dataset—The existing centerline, calibration point, and redline feature classes that are not yet registered with an LRS must be in a common feature dataset. The feature dataset name can be different from the LRS name.
All tools in the Location Referencing toolbox require an LRS dataset to run.
Use the Migrate Object ID to 64 Bit tool to migrate the LRS dataset to 64-bit Object IDs.
Upgrading a dataset to 64-bit Object IDs is useful when Object ID values exceed 2.1 billion or if data is coming from cloud data warehouses.
Learn more about migrating to a 64-bit Object ID
You can review some of the information contained in the LRS dataset using the arcpy.Describe function. To review the LRS metadata and event behavior rules for a geodatabase with an LRS dataset, use the following functions:
File geodatabase:
desc = arcpy.Describe("C:\\Data\\LRData\\LrsSchema.gdb\\Lrs\\Lrs")
lrsXML = desc.lrsMetadata
eventBehaviors = desc.eventBehaviorRules
Enterprise geodatabase:
desc = arcpy.Describe("C:\\Data\\LRData\\LrsSchema.sde\\GPRefresh.DBO.LRS\\GPRefresh.DBO.LRS")
Writing to a file:
txtFile = open("C:\\Data\\LRData\\lrsXML.xml", "w")
txtFile.write(lrsXML)
txtFile.close()
Centerline feature class
The centerline feature class provides a single source of geometry for all of the LRS Networks you build in an LRS.
Every feature in the centerline feature class represents a single unit of the highway. These can be used to represent a one-to-one relationship with routes or be combined to form larger routes.
  • The tolerance and resolution settings of the centerline feature class are propagated to the networks, intersections, and event feature classes registered with ArcGIS Roads and Highways. The spatial reference, x,y tolerance and resolution, and z-tolerance and resolution of the centerline feature class must match those of the source routes to be used to load data into your LRS.
  • The centerline feature class must be z-enabled.
The LRS requires that the centerline feature class have a centerline ID field. The Create LRS and Create LRS From Existing Dataset tools allow you to map a centerline ID field.
Field
Data type
Length
IsNullable
Centerline ID
GUID
N/A
Yes
Unique ID for the centerline geometry
Caution:
The CenterlineId field is a system-maintained field that is automatically populated by ArcGIS Roads and Highways tools. This field should not be edited manually.
Centerline sequence table
The many-to-many relationship between routes and centerlines is maintained through a cross-reference table known as the centerline sequence table. Since route IDs are not unique in the LRS, the centerline sequence table also contains a reference to the network ID field of the LRS Network. The combination of the network ID and route ID creates a way of uniquely identifying each route in the LRS. The use of the network ID helps differentiate between LRMs, as route IDs may not be unique across networks.
One centerline feature can participate in many routes, and a route can consist of more than one centerline. The centerline sequence table must have at least one record for each centerline-network combination.
The minimum fields for the centerline sequence table are as follows:
Field
Data type
Length
IsNullable
Centerline ID
GUID
N/A
Yes
The unique ID for the centerline geometry
From Date
Date
8
Yes
The date that the portion of the centerline becomes active
To Date
Date
8
Yes
The date that the portion of the centerline will be retired
Route ID
String
255 suggested; equal to or greater than the length of the largest route ID in any network.
Yes
The unique ID for the route
Network ID
Short Integer
Yes
The unique ID for the LRS Network in which each route participates
Caution:
Records in the centerline sequence table should not be edited manually.
The NetworkId field is registered with the dLRSNetworks coded value domain when the LRS is created.
Calibration point feature class
Route measures are assigned to routes in the network using the calibration point feature class. Routes are calibrated by calculating an interpolated distance between any two calibration points along the route. Calibration point rules are as follows:
  • There is only one calibration point feature class for all LRS Networks registered with the LRS.
  • A minimum of two calibration points is required for each route.
  • Calibration points should be monotonic, meaning strictly increasing or decreasing in measure along a route. Nonmonotonic routes will calibrate but may result in undefined event locations and event behavior.
  • Add a calibration point to a particular location to maintain a specific measure value.
  • The calibration point feature class should have the same spatial reference, x,y and z-tolerance, and resolution as the centerline feature class.
  • The calibration point feature class must be z-enabled and cannot be m-enabled.
The minimum fields for the calibration point feature class are as follows:
Field
Data type
Length
IsNullable
Measure
Double
8
Yes
The measure value stored for routes in an LRS Network.
From Date
Date
8
Yes
The date that the calibration point becomes active.
To Date
Date
8
Yes
The date that the calibration point will be retired.
Route ID
String
Same length as the route ID field in the centerline sequence table.
No
The unique ID for the route.
Network ID
Short Integer
Yes
The unique ID for the LRS Network.
Use the Generate Calibration Points tool to generate calibration points.
Redline feature class
The redline feature class contains the basic information required to perform many of the route editing functions available in Roads and Highways. This markup feature is a placeholder for a future route editing operation used to alert an LRS editor to necessary changes
  • The redline feature class should have the same spatial reference and x,y tolerance and resolution as the centerline feature class.
  • The redline feature class must be z-enabled and cannot be m-enabled.
The minimum fields for the redline feature class are as follows:
Field
Data type
Length
IsNullable
From Measure
Double
8
Yes
The starting measure of the alignment change.
To Measure
Double
8
Yes
The ending measure of the alignment change.
Route ID
String
No
The unique ID for the target route.
Route Name
String
12
Yes
The name for the route.
Effective Date
Date
8
Yes
The date that the route change becomes effective. The date will be applied to events affected by the change.
Activity Type
Short Integer
Yes
The edit activity that should be made, such as Extend Route.
Network ID
Short Integer
Yes
The unique ID of the LRS Network.
The NetworkId field is registered with the dLRSNetworks coded value domain, and the ActivityType field is registered with the dActivityType coded value domain when the LRS is created.
Redline features can be specific or general. A GIS analyst should verify that the redline feature has accurate geometry in the database. A roughly sketched redline indicates that a change to the LRS is required and provides the general location of the change.
Network feature class
The network feature class contains the route features used in the LRS. These routes have attributes, geometry from the centerline feature class, and calibration from the calibration point feature class.
Combined, these elements constitute a route in the LRM that can be used to locate events on that route. Each route must have a unique route identifier, called a route ID.
The route ID field data type and length should be consistent throughout networks, events, redline, calibration point, and the centerline sequence table.
If the network feature class is modeled before the LRS is created, ensure that the x,y and z-tolerances and resolutions match those of the centerline feature class. The m-tolerance and resolution for the network are based on the unit of measure of the spatial reference for the network feature class and the unit of measure of the LRM being used. If the units of measure are the same, the m-tolerance and resolution will be the same as the x,y-tolerance and resolution. If the units of measure are different, you must convert the x,y tolerance and resolution to the corresponding m-tolerance and resolution.
For example, if your network feature class has a spatial reference in meters, with an x,y tolerance of 0.001 meters and x,y resolution of 0.0001 meters. If the unit of measure for the LRM is in meters, the m-tolerance would be 0.001 and the m-resolution would be 0.0001. However, if the unit of measure for the LRM is in kilometers, the x,y tolerance and resolution values would need to be converted from meters to kilometers for the m-tolerance and resolution. In this example, the m-tolerance would be 0.000001, and the resolution would be 0.0000001.
Learn more about tolerance and resolution settings for the LRS
The minimum fields for the network feature class are as follows:
Field
Data type
Length
IsNullable
From Date
Date
8
Yes
The date that the portion of centerline becomes an active part of the route.
To Date
Date
8
Yes
The date that the portion of centerline becomes a retired part of the route.
Route ID
String
No
Caution:
The network feature class fields should not be directly edited. They are maintained by Location Referencing.
The following fields should be configured if you're using a multi-field route ID composed of several other fields in the network feature class:
Field
Data type
Length
IsNullable
Fields that comprise the Route ID field.
String, Short Integer, and Long Integer
Less than or equal to the Route ID field length
Yes
The fields that comprise the concatenated route ID for the network. Each field should be modeled separately in the network feature class.
The following fields should be configured for a line network with a multi-field route ID:
Field
Data type
Length
IsNullable
Line ID
String or GUID
Same type and length as the Route ID field in the centerline sequence table
Yes
The unique ID for the line
Line Order
Long
N/A
Yes
The order of the route within the line
It is recommended that you configure line order to be in increments of 100. For example, the first route has a line order of 100 and the line order increases in increments of 100 for each route along the same line (100, 200, 300, and so on).
