View the LRS hierarchy
Available with Location Referencing license.
A linear referencing system (LRS) dataset is a controller dataset in a feature dataset in the geodatabase along with all the feature classes that participate in the LRS.
In ArcGIS Pro, you can view the hierarchy in an LRS dataset to determine the types of networks that exist in the LRS and the events registered with each network.
Review the LRS hierarchy from the Contents pane
To review the LRS hierarchy from the Contents pane, complete the following steps:
  1. In the ArcGIS Pro project, choose the map that includes the LRS feature layer.
    The Contents pane appears with the layers listed.
  2. In the Contents pane, click to choose a feature layer from the LRS dataset.
    You can choose any of the feature layers that are members of the LRS dataset (calibration point, centerline, event, intersection, network, or redline).
  3. Click the Location Referencing tab on the ArcGIS Pro ribbon.
  4. Click LRS Hierarchy in the Tools group.
    Tip:
    If LRS Hierarchy is not active, the selected feature layer is not a member of the LRS dataset. Choose a valid feature layer in the Contents pane to activate it.
    The LRS Hierarchy pane appears. The LRS (LRS_mod in this example) is the root of the hierarchy.
    The LRS Schema node contains the minimum schema feature classes and the centerline sequence table, and the network nodes show the network, event, and intersection feature classes.
    LRS Hierarchy pane
    In a combined LRS and Address Data Management dataset, the Address Schema node contains the address range and site address point feature classes.
    Address Schema node
  5. Optionally, right-click an entity in the LRS hierarchy to review its properties or add it to a new or current map.
    You can access properties for the calibration point, centerline, event, intersection, network, or redline feature classes, as well as properties for the centerline sequence table.
    In a combined LRS and Address Data Management dataset, you can access properties for the site address point feature class.
Review the LRS hierarchy from the Catalog pane
The LRS dataset appears in the Catalog pane as the LRS folder in the geodatabase node. This folder contains all the members of the dataset.
To review the LRS hierarchy from the Catalog pane, complete the following steps:
  1. In the ArcGIS Pro project, open the Catalog pane.
  2. In the Catalog pane, expand the geodatabase node, and expand the feature dataset.
    The LRS hierarchy appears in the LRS dataset using the name of the LRS (LRS_mod in this example). If an LRS dataset is not present in the LRS, the LRS hierarchy does not appear. Run the Modify LRS tool to update the LRS.
    Catalog pane with the feature dataset expanded
  3. Right-click the LRS dataset, and choose LRS Hierarchy.
    The LRS Hierarchy pane appears with the LRS name (LRS_mod in this example) as root.
    LRS Hierarchy pane
    Address Schema node
  4. Optionally, right-click an entity in the LRS hierarchy to view its properties or add it to a new or current map.
