View site address point properties
Available with Location Referencing license.
If you have a combined LRS and Address Data Management dataset, you can view the properties of a site address point as either a map layer or a feature class. This is helpful to verify which fields are configured with the Address Data Management solution.
Site address point properties
The tables below describe the site address point properties:
Site Address Name
The Site Address Name property appears in the Location Referencing tab of the Layer Properties and Feature Class Properties dialog boxes.
Property |
Description |
Site Address Name |
The name of the site address point feature class |
Address Fields
You can view the following Address Fields properties for the site address point feature class:
Property |
Description |
Address Number |
The site address number |
Road Name |
The name of the roadway |
View site address point properties by map layer
To view the properties of a site address point map layer from the Contents pane, complete the following steps:
Open the Contents pane in ArcGIS Pro.
Right-click the site address point layer, and click Properties.
The Layer Properties dialog box appears with the selected site address point layer name in the title bar.
The tabs on the dialog box are specific to the selected layer type.
Click the Location Referencing tab.
Scroll down if the tab isn't visible in the list.
The Location Referencing tab displays general properties for the selection at the top, with additional nodes below.
Click the arrow for a node to expand or collapse its properties.
If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
Tip:
You can copy the read-only properties to the clipboard.
Click OK to close the Layer Properties dialog box.
View site address point properties by feature class
To view the properties of a site address point feature class from the Catalog pane, complete the following steps:
Open the Catalog pane in ArcGIS Pro.
Expand the geodatabase connection and the feature dataset to browse to the feature class.
Right-click the site address point feature class, and click Properties.
The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
The tabs on the dialog box are specific to the selected feature class type.
Tip:
Click OK to close the Feature Class Properties dialog box.
