View LRS event properties
Available with Location Referencing license.
You can view the properties of an LRS event as either a map layer or a feature class.
To modify existing LRS event properties, use the Modify LRS Event geoprocessing tool.
The following tables describe the LRS event properties:
Name and feature class
Event name and event feature class properties appear at the top of the Location Referencing tab.
Property
Event Name
The name of the selected event.
Event Feature Class
The feature class from which the LRS event was created.
Event Type
The data type of the selected event: linear or point.
Parent Network
The LRS Network in which the event is located.
Learn more about tolerance and resolution settings for the LRS
Tolerance and resolution
You can view the following Tolerance and Resolution properties:
Property
Measure Precision
The specified number of decimal places included in the measure.
XY Tolerance
The x,y tolerance set for the network feature class.
M Tolerance
The m-tolerance set for the network feature class.
Z Tolerance
The z-tolerance set for the network feature class.
XY Resolution
The x,y resolution set for the network feature class.
M Resolution
The m-resolution set for the network feature class.
Z Resolution
The z-resolution set for the events feature class.
Event fields
You can view the following Event Fields properties for the events feature class:
Learn more about the events data model
Property
Event Id
The unique ID for each event record.
From Route Name
The name of the route from which the From measure is derived.
From Route Id
The unique ID of the route from which the From measure is derived.
From Measure
The measure on the route where the beginning of the event is located.
To Route Name
The name of the route from which the To measure is derived.
To Route Id
The unique ID of the route from which the To measure is derived.
To Measure
The measure on the route where the end of the event is located.
From Date
The date the event became active on the route.
To Date
The date the event was retired on the route.
Location Error
The location error for the event.
Supports Spanning Routes
Indicates whether the event was registered with span routes enabled.
Referent fields
You can view the following Referent Fields properties:
Property
From Referent Method (linear events)
The method of referencing the offset feature. This can be x,y coordinates, stationing, length, LRS Network, event, intersection, or other point feature classes.
From Referent Location (linear events)
The location of the offsetting feature. This can be an x,y coordinate, feature or event ID, or intersection ID.
From Referent Offset (linear events)
The offset measure. This is saved in the unit of measure configured when configuring offset fields.
To Referent Method (linear events)
To Referent Location (linear events)
To Referent Offset (linear events)
Offset Units
The unit of measure for offsets in the LRS Network in which the event resides.
Event behavior rules
You can view the event behavior rules configured for the LRS event.
The event behavior rules are configured and applied to each of the activity types (calibrate, retire, extend, reassign, and realign) using the Apply Event Behaviors geoprocessing tool.
Address Fields
If an LRS line event feature class is configured as the address range feature class in an Address Data Management configuration, you can view the following Address Fields properties for the line event feature class:
Property
Left From Address
The first address on the left side of a roadway.
Left To Address
The last address on the left side of a roadway.
Right From Address
The first address on the right side of a roadway.
Right To Address
The last address on the right side of a roadway.
Road Name
The name of a roadway.
View event layer properties by map layer
You can view the properties of an LRS event map layer from the Contents pane:
  1. Open the Contents pane in ArcGIS Pro.
  2. Right-click the event layer, and click Properties.
    The Layer Properties dialog box appears with the selected event layer name in the title bar.
    The tabs on the dialog box are specific to the selected layer type.
  3. Click the Location Referencing tab.
    Scroll down if the tab isn't visible in the list.
    The Location Referencing tab displays general properties for the selection at the top, with additional nodes below.
  4. Click the arrow for a node to expand or collapse its properties.
    If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
    Tip:
    You can copy the read-only properties to the clipboard.
  5. Click OK to close the Layer Properties dialog box.
View event layer properties by feature class
You can view the properties of an LRS event feature class from the Catalog pane:
  1. Open the Catalog pane in ArcGIS Pro.
  2. Expand the geodatabase connection and the feature dataset to browse to the feature class.
  3. Right-click the event feature class, and click Properties.
    The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
  4. Click the Location Referencing tab.
  5. Click the arrow for a node to expand or collapse its properties.
    Tip:
  6. Click OK to close the Feature Class Properties dialog box.
