Event behavior for route retirement
Available with Location Referencing license.
When routes are retired, events are impacted depending on the configured event behavior for each event layer.
Events are not updated until the Apply Event Behaviors tool is run after route edits. If you are using conflict prevention on branch versioned data, you are prompted to run Apply Event Behaviors before posting to the default version.
When Recalibrate route downstream is chosen for an LRS route edit, the configured calibrate event behavior is applied to downstream sections. You can review configured event behaviors by viewing LRS event properties.
The route retirement and corresponding event behaviors are described below.
Route retirement scenario
A route can be retired at the beginning, in the middle, or at the end of the route. If the retirement takes place in the middle of the route, the resulting route is a gapped route. For line network, you can fully or partially retire multiple adjoining routes that belong to the same line.
Upstream and downstream sections
Route editing impacts upstream and downstream sections differently.
The following image shows the upstream and downstream sections for the route retirement scenario:
Upstream and downstream sections of route retirement scenarios
The following table details how the retirement editing activity impacts upstream and downstream events according to the configured event behavior:
Behavior
Events upstream
Events intersecting
Events downstream
Stay Put
No action.
Retire event; line events crossing the edit region are split and the original event is retired.
If route calibration is changed, the calibrate event behavior is applied; otherwise, no action is taken.
Move
Shape regenerated, if needed, to new location of route measures.
Shape regenerated to new location of route measures.
Retire
No action.
Retire event; line events crossing the edit region are not split.
Snap
No action
Retire event; line events crossing the edit section will be split. The new event is snapped to a concurrent route, if one exists.
The network can contain events that span routes in a line network. The behaviors are still applied in the same manner.
Because the LRS is time aware, edit activities such as retiring a route will time slice routes and events.
Route retirement results
In this example, the route Route1 is active from 1/1/2000. The retirement is set to occur at the beginning of the route on 1/1/2005. The Recalibrate route downstream option is chosen and the route is recalibrated after retirement. The graphics and tables below demonstrate the route information before and after the retirement.
In all the examples below, the calibrate event behavior for the events is set to Stay Put.
The calibrate event behavior is applied before the retire event behavior, so it is important to verify the event feature layer's calibrate event behavior configuration before checking the Recalibrate route downstream check box.
For other event behaviors for calibration, refer to the calibrate event behavior.
Before route retirement
The following image shows the route before the retirement:
Route1 before retirement
The following table provides details about the route before the retirement:
Route ID
From Date
To Date
From Measure
To Measure
Route1
1/1/2000
<Null>
After route retirement
The following image shows the route after the retirement.
Route1 after retirement
The following table provides details about the route after the retirement:
Route ID
From Date
To Date
From Measure
To Measure
Route1
1/1/2000
1/1/2005
Route1
1/1/2005
<Null>
Events before route retirement
There are three events on Route1 and all of them have a start date (From Date) of 1/1/2000. The following image shows the route and events before the retirement:
Route1 and associated events before retirement
The following table provides details about the events before the retirement:
Event
Route ID
From Date
To Date
From Measure
To Measure
Event1
Route1
1/1/2000
<Null>
Event2
Route1
1/1/2000
<Null>
20
30
Event3
Route1
1/1/2000
<Null>
30
45
The following sections detail how event behavior rules are enforced after running the Apply Event Behaviors tool under this route retirement scenario.
Stay Put event behavior
Although the geographic location of the event is maintained, the measures can change. The event can also split if it crosses the retire region and portions within the retirement region are retired.
The following table shows the edit activities involved in the route edit and their corresponding event behaviors:
Edit activity
Event behavior
Retire
Stay Put
Calibrate
Stay Put
The route retirement described above has the following effects:
  • Event1 is retired on the date of the retirement because it is completely in the edit section.
  • Event2 is retired on the date of the retirement because part of it is in the edit section. A new event is created on the post-retirement route with the retirement date as the starting date (From Date). The length of the new Event2 is shorter and its start measure (From Measure) value changes to 0 and end measure (To Measure) value changes to 5 to accommodate the new measures of Route1.
  • Event3 is not in the retirement region, so retire event behavior does not apply to it. As Route1 is recalibrated, the calibration Stay Put behavior is applied to maintain Event3's geographic location. Event3's start measure value changes to 5 and end measure value changes to 20 to accommodate the new measures of Route1.
The following image shows the route and events after the retirement:
Route1 and associated events after retirement when Stay Put is the configured event behavior
The retired event is not drawn in the graphic above.
The following table provides details about the events after the retirement:
Event
Route ID
From Date
To Date
From Measure
To Measure
Location Error
Event1
Route1
1/1/2000
1/1/2005
No Error
Event2
Route1
1/1/2000
1/1/2005
20
30
No Error
Event2
Route1
1/1/2005
<Null>
No Error
Event3
Route1
1/1/2000
1/1/2005
30
45
No Error
Event3
Route1
1/1/2005
<Null>
20
No Error
Move event behavior
Although the measures of the event are maintained, the geographic location can change.
Edit activity
Event behavior
Retire
Move
Calibrate
Stay Put
  • Event1 is retired on the date of the retirement because part of it is in the edit section. A new event is created on the post-retirement route with the retirement date as the starting date. Because the measures do not change for the Move behavior, the event moves to the new location of Route1 to maintain its original start measure value of 0 and end measure value of 20.
  • Event2 is retired on the date of the retirement because it is completely in the edit section. A new event is created on the post-retirement route with the retirement date as the starting date. Because the measures do not change for the Move behavior, the event moves to the new location of Route1 to maintain its original start measure value of 20 and end measure value of 30.
Route1 and associated events when Move is the configured event behavior
Event
Route ID
From Date
To Date
From Measure
To Measure
Location Error
Event1
Route1
1/1/2000
1/1/2005
No Error
Event1
Route1
1/1/2005
<Null>
No Error
Event2
Route1
1/1/2000
1/1/2005
20
30
No Error
Event2
Route1
1/1/2005
<Null>
20
30
No Error
Event3
Route1
1/1/2000
1/1/2005
30
45
No Error
Event3
Route1
1/1/2005
<Null>
20
No Error
Retire event behavior
Events intersecting the retire region are retired.
Edit activity
Event behavior
Retire
Retire
Calibrate
Stay Put
  • Event1 retires on the date of the retirement because it is completely inside the retired region.
  • Event2 retires on the date of the retirement because it intersects the retired region.
Route1 and associated events after retirement when Retire is the configured event behavior
Event
Route ID
From Date
To Date
From Measure
To Measure
Location Error
Event1
Route1
1/1/2000
1/1/2005
No Error
Event2
Route1
1/1/2000
1/1/2005
20
30
No Error
Event3
Route1
1/1/2000
1/1/2005
30
45
No Error
Event3
Route1
1/1/2005
<Null>
20
No Error
Snap event behavior
Although the geographic location of the event is maintained by snapping to the new route location of retirement, the measures can change. The event can also split if it crosses the retirement where concurrent routes exist.
In this example, there is a Route2 that is concurrent with Route1. Route2 is in reversed direction and has the start measure value of 0 and end measure value of 55.
Edit activity
Event behavior
Retire
Snap
Calibrate
Stay Put
The route retirement described has the following effects:
  • Event1 is retired on the date of the retirement because it is completely in the edit section. As a concurrent route exists in the realignment section, Event1 snaps to Route2, the concurrent route, after retirement. It is also reversed to accommodate the direction of Route2. The new event record has the retirement date as the starting date. The new start measure value of Event1 became 35 and the end measure value remained 55 on Route2 to maintain Event1's geographic location.
  • Event2 is retired on the date of retirement since part of it is in the edit section. It then splits into two event records on the post-retirement routes with the retirement date as the starting date. This is because a concurrent route exists in the retirement section, and the portion of Event2 in the retirement section snaps to Route2, the concurrent route, after retirement. This portion of Event2 is also reversed to accommodate the direction of Route2. As a result, Event2 splits into two pieces to maintain its geographic location. The first event record has the start measure value of 0 and end measure value of 5 on Route1 when the calibrate Stay Put behavior is applied. The second event record snaps to Route2 and has the start measure value of 30 and end measure value of 35 on Route2.
  • Event3 is not in the retirement region, so retire event behavior does not apply to it. As Route1 is recalcitrated, the calibrate Stay Put behavior is applied to maintain Event3's geographic location. Event3's start measure value changes to 5 and end measure value changes to 20 to accommodate the new measures of Route1.
Route1 and associated events after realignment when Snap is the configured event behavior and a concurrent route exists
The following table provides details about the events after retirement:
Event
Route ID
From Date
To Date
From Measure
To Measure
Location Error
Event1
Route1
1/1/2000
1/1/2005
No Error
Event1
Route2
1/1/2005
<Null>
35
55
No Error
Event2
Route1
1/1/2000
1/1/2005
20
30
No Error
Event2
Route1
1/1/2005
<Null>
No Error
Event2
Route2
1/1/2005
<Null>
30
35
No Error
Event3
Route1
1/1/2000
1/1/2005
30
45
No Error
Event3
Route1
1/1/2005
<Null>
20
No Error
Detailed behavior on routes in a line network with events that span routes
In this example, there are four routes on the same line and the routes are active from 1/1/2000. The retirement is set to occur on 1/1/2005 where the entire Route1 and half of Route2 are retired. The Recalibrate route downstream option is chosen, and Route2 is recalibrated after retirement. The images and tables below demonstrate the route information before and after the retirement.
The following image shows the routes before the retirement:
The four routes on LineA before retirement
The following table provides details about the routes before the retirement:
Route Name
Line Name
Line Order
From Date
To Date
From Measure
To Measure
Route1
LineA
100
1/1/2000
<Null>
Route2
LineA
200
1/1/2000
<Null>
12
22
Route3
LineA
300
1/1/2000
<Null>
25
35
Route4
LineA
400
1/1/2000
<Null>
38
48
The following image shows the routes after the retirement:
The three routes on LineA after retirement
The following table provides details about the routes after the retirement:
Route Name
Line Name
Line Order
From Date
To Date
From Measure
To Measure
Route1
LineA
100
1/1/2000
1/1/2005
Route2
LineA
200
1/1/2000
1/1/2005
12
22
Route2
LineA
100
1/1/2005
<Null>
12
17
Route3
LineA
300
1/1/2000
1/1/2005
25
35
Route3
LineA
200
1/1/2005
<Null>
25
25
Route4
LineA
400
1/1/2000
1/1/2005
38
48
Route4
LineA
300
1/1/2005
<Null>
38
48
Events before retirement
There are two spanning events on routes on LineA. The following image shows the routes and events before the retirement:
The four routes and associated events before retirement
Event ID
From Date
To Date
From Route Name
To Route Name
From Measure
To Measure
Event1
1/1/2000
<Null>
Route1
Route3
Event2
1/1/2000
<Null>
Route3
Route4
30
48
The following sections describe how event behavior rules are enforced when routes on a line in a line network are retired.
Although the geographic location of the event is maintained, the measures can change. The event can also split if it crosses the retire region, and portions within the retirement region are retired.
Edit activity
Event behavior
Retire
Stay Put
Calibrate
Stay Put
  • Event1 is retired on the date of the retirement because part of it is in the edit section. A new event is created on the post-retirement route with the retirement date as the starting date. The length of the new Event1 is shorter because its start measure value changes to 17 on Route2 and the end measure value changes to 30 on Route3 to accommodate the new measures of Route2.
  • Event2 is not affected because it is not in the retirement region.
The following image shows the routes and events after the retirement:
The three routes and associated events after retirement when Stay Put is the configured event behavior
The retired event is not drawn in the image above.
Event ID
From Date
To Date
From Route Name
To Route Name
From Measure
To Measure
Location Error
Event1
1/1/2000
1/1/2005
Route1
Route3
No Error
Event1
1/1/2005
<Null>
Route2
Route3
12
30
No Error
Event2
1/1/2000
<Null>
Route3
Route4
30
48
No Error
Move event behavior
Edit activity
Event behavior
Retire
Move
Calibrate
Stay Put
  • Event1 is retired on the date of the retirement because part of it is in the edit section. A new event is created on the post-retirement route with the retirement date as the starting date. Because the measures do not change for the Move behavior, the new Event1 gets a location error while trying to locate Route1 for its start measure but Route1 no longer exists. There is a record for the new Event1 in the event table, but it is not drawn because it does not have a length due to the location error.
The three routes and associated events after retirement when Move is the configured event behavior
Event ID
From Date
To Date
From Route Name
To Route Name
From Measure
To Measure
Location Error
Event1
1/1/2000
1/1/2005
Route1
Route3
No Error
Event1
1/1/2005
<Null>
Route1
Route3
Route Not Found
Event2
1/1/2000
<Null>
Route3
Route4
30
48
No Error
Edit activity
Event behavior
Retire
Retire
Calibrate
Stay Put
  • Event1 retires on the date of the retirement because it intersects the retired region.
The three routes and associated events after retirement when Retire is the configured event behavior
Event ID
From Date
To Date
From Route Name
To Route Name
From Measure
To Measure
Location Error
Event1
1/1/2000
1/1/2005
Route1
Route3
No Error
Event2
1/1/2000
<Null>
Route3
Route4
30
48
No Error
Snap event behavior
In this example, there is a Route5 that is concurrent with the routes on LineA. Route5 is on LineB and is in the reversed direction. It has the start measure value of 0 and end measure value of 40.
Edit activity
Event behavior
Retire
Snap
Calibrate
Stay Put
  • Event1 is retired on the date of retirement because part of it is in the edit section. It then splits into two event records on the post-retirement routes with the retirement date as the starting date. This is because a concurrent route exists in the retirement section, and the portion of Event1 in the retirement section snaps to Route5, the concurrent route, after retirement. This portion of Event1 is also reversed to accommodate the direction of Route5. As a result, Event1 splits into two pieces to maintain its geographic location. The first event record has the start measure value of 12 on Route2 and end measure value of 30 on Route3 when the calibrate Stay Put behavior is applied. The second event records snaps to Route5 and has the start measure value of 25 and end measure value of 40 on Route5.
The three routes and associated events after retirement when Snap is the configured event behavior and a concurrent route exists
Event ID
From Date
To Date
From Route Name
To Route Name
From Measure
To Measure
Location Error
Event1
1/1/2000
1/1/2005
Route1
Route3
No Error
Event1
1/1/2005
<Null>
Route2
Route3
12
30
No Error
Event1
1/1/2005
<Null>
Route5
Route5
25
40
No Error
Event2
1/1/2000
<Null>
Route3
Route4
30
48
No Error
