Retire routes
Available with Location Referencing license.
During the life span of a roadway, major changes such as environmental concerns, age, erosion, or repair work, can require retirement of a route segment or an entire route for a specific period of time.
When you specify that a section of a route should be retired, that section is removed from the route in the LRS Network for the specified time frame. When a route is retired using the Retire tool, the route's To Date field in the LRS Network feature class is populated with the retirement date.
When sections of a route are retired, the centerline features are split to accommodate the precise location of the retire operation. Calibration points are also added to ensure that the remainder of the route is calibrated properly.
Route retirement scenarios
Route retirement scenarios are described below.
Retirement on a route without recalibration
Retirement is from the start of the route to the middle portion of the route.
From Route |
RouteX |
From Measure |
0 |
To Measure |
5 |
Recalibrate Downstream |
No |
After retirement, the route is not recalibrated, leaving the downstream measures intact.
Retirement on a route with downstream recalibration
Retirement is from the start of the route to the middle portion of the route. The route is recalibrated downstream and the downstream measures are updated.
From Route |
RouteX |
From Measure |
0 |
To Measure |
5 |
Yes |
The start measure of the remaining route is updated to the same value as the start measure of the route before its retirement.
Complex route retirement scenarios
Route retirement scenarios for complex routes including loop, lollipop, branch, alpha, and infinity routes are described below.
Retirement on a loop route
In the following example, RouteX has a start measure of 0 and an end measure of 12. Retirement takes place from the middle to the end of a loop route:
From Route |
Route X |
From Measure |
9 |
To Measure |
12 |
Yes |
After retirement, RouteX becomes a simple route.
Retirement takes place in the middle of the lollipop route. In the following example, RouteX has a start measure of 0 and an end measure of 15:
From Route |
Route X |
From Measure |
4 |
To Measure |
8 |
Yes |
After retirement, RouteX becomes a branch route.
In the second example, retirement takes place from the middle to the end of the lollipop route.
From Route |
Route X |
From Measure |
12 |
To Measure |
15 |
Yes |
After retirement, RouteX becomes a loop route.
Retirement on a branch route
In the following example, RouteX has a start measure of 0 and an end measure of 9. Retirement takes place from the beginning to the middle of the branch route:
From Route |
Route X |
From Measure |
0 |
To Measure |
3 |
Yes |
In the second example, retirement takes place from the middle to the end of the branch route.
From Route |
Route X |
From Measure |
6 |
To Measure |
9 |
Yes |
Retirement on an alpha route
Retirement takes place from the start to the middle portion of the alpha route. In the following example, RouteX has a start measure of 0 and an end measure of 18:
From Route |
Route X |
From Measure |
0 |
To Measure |
6 |
Yes |
Retirement on an infinity route
Retirement takes place from the middle to the end of the infinity route. In the following example, RouteX has a start measure of 0 and an end measure of 24:
From Route |
Route X |
From Measure |
18 |
To Measure |
24 |
Yes |
After retirement, RouteX becomes an alpha route.
Retire routes in a line network
The examples below demonstrate how routes in a line network can be retired. Line orders are updated if needed.
The first example shows the before and after retirement at the beginning.
Example 1 input
Route ID |
Line Order |
RouteX |
100 |
RouteA |
200 |
RouteY |
300 |
The first part of RouteX at the beginning will be retired.
After retirement of the first part of RouteX, line order is updated. RouteA now has line order 100, while RouteX is now 200.
Example 1 output
Route ID |
Line Order |
RouteA |
100 |
RouteX |
200 |
RouteY |
300 |
The second example shows before and after retirement at the end.
Example 2 input
Route ID |
Line Order |
Route X |
100 |
Route Y |
200 |
The second part of RouteY will be retired.
Example 2 output
Route ID |
Line Order |
Route X |
100 |
Route Y |
200 |
Line order is unaffected when retiring a route or part of a route at the end.
Retire route parameters
The following table lists the parameters used in the Retire tool:
Parameter |
Description |
Network |
The network in which the routes exist. |
Retire Date |
The date when the retirement takes place. |
Route ID |
The route on which the retirement takes place. |
From Measure |
The measure on the route where the retirement starts. This is displayed as a green dot. |
Use route start measure |
The starting measure of the route. |
To Measure |
The measure on the target route where the retirement ends. This is displayed as a red dot. |
Use route end measure |
The end measure of the target route. |
Recalibrate route downstream |
Remove the length of the retired route from the overall set of measures. |
To retire a route, complete the following steps:
Gap calibration rules are followed when editing routes.
Add the centerline and network feature class to a map.
Alternatively, open a map in which the centerline and network feature class are present.
In the data model, only one centerline is expected at any given location. Ensure that the centerlines you're using for your edit do not overlap other centerlines in the LRS.
Branch versioned networks, including any network configured with a user-generated route ID, must be edited through a feature service.
Zoom in to the location where you want to retire the route.
Click the Retire button
on the Location Referencing tab.The Retire Route pane appears.
For Network, choose the network in which you want to retire the route.
To edit using feature services, the LRS Network must be published with Linear Referencing and Version Management capabilities.
Click the Calendar button
next to the Retire Date text box and choose or provide a retirement date.Tip:
You can also double-click the Retire Date text box to automatically populate it with today's date.
Click the Choose route from map button
next to the Route ID parameter and select a route on the map to retire.Note:
After clicking Choose route from map
or Choose measure from map
, you can hover over the route to see the route and measure at the location of the pointer.If only one applicable route exists at the edit location on the map, click to select it. If multiple routes are applicable, click the location and choose one of the applicable routes from the Select Route dialog box.
You can set map scale options for the display of route and measure information on the Options dialog box, on the Location Referencing tab.
Provide the start measure value in the From Measure text box or click the Choose measure from map button
to populate the start measure.A green dot appears at the location of the start measure on the route.
Tip:
You can also check the Use route start measure check box to choose the start measure of the route.
Provide the end measure value in the To Measure text box or click the Choose measure from map button
to populate the end measure.A red dot appears at the location of the end measure on the route.
Tip:
You can also check the Use route end measure check box to choose the end measure of the route.
Optionally, check the Recalibrate route downstream check box to remove the length of the retired route from the overall set of measures.
If the Recalibrate route downstream check box is unchecked, the start measure of the modified route is the end measure of the retired section, and the end measure of the modified route remains unchanged.
You can't retire the route if the From Measure and To Measure values for the route are the same.
Click Run.
If the route edit will result in the introduction of one or more physical gaps on the route, a prompt appears to alert you before the tool is run. If you don't plan to create a gapped route, click No.
If the route being edited already had one or more physical gaps, and no more physical gaps were introduced by the edit, no prompt will appear.
To disable this prompt, uncheck the Warn before allowing route edits that can create physical gaps check box in Location Referencing options.
The selected section of the route is retired.
As a result of the retire route activity, only routes or sections of a route are retired; centerlines are not retired.
If a message regarding acquiring locks or reconciling appears, conflict prevention is enabled.
After a route is selected, the tool will attempt to release the route lock if the route lock is acquired by the active user in a different version and its releasable status value is Yes.
