Reverse Line Orders (Location Referencing Tools)
Summary
Reverses the line order for all the routes in a line.
Illustration
Reverse Line Orders tool illustration
This diagram shows the reversed line orders for routes in a line.
Usage
  • Use a line network feature class registered with an LRS Network or a line network feature service as input to the tool.
  • Select at least one route for the line whose line order values must be reversed before running the tool. The tool reverses the line order for all the routes in the line.
  • If only a few routes are selected within a given time range, the line order of all routes that overlap with the selected routes time range will be reversed.
  • After running this tool, route time slices may be created for routes (with different time ranges) where line orders were reversed. Run the Generate Events tool to update the events on the routes that include those line orders.
  • After running this tool, run the Generate Routes tool to update the derived network based on the reversed line order values.
  • The tool supports conflict prevention and will attempt to acquire and transfer locks.
    Learn more about conflict prevention in ArcGIS Pipeline Referencing or conflict prevention in ArcGIS Roads and Highways.
Parameters
Label Explanation Data type
Input Route Features
The LRS line network for which line order values will be reversed.
Feature Layer
Derived output
Updated Route Features
The updated route features feature layer.
Feature Layer
Output Details File
The file that contains the output details.
Text File
Output Derived Route Features
The output derived route features.
Feature Layer
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
