Disable Stationing Fields (Location Referencing Tools)
Summary
Disables stationing fields for the registered LRS event.
Learn more about stationing in the ArcGIS Pipeline Referencing events data model or stationing in the ArcGIS Roads and Highways events data model.
Usage
  • The stationing fields must be enabled for the event prior to running this tool.
Parameters
Label Explanation Data type
Event Feature Class
An existing event feature class or feature layer that is registered to an LRS.
Feature Layer
Derived output
Output Event Feature Class
The updated feature layer for the event.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
