Enable Referent Fields (Location Referencing Tools)
Summary
Enables or modifies the referent fields so that you can manage referent information for the registered LRS event.
Learn more about event referent fields
Usage
  • The tool enables the referent fields by allowing you to register the existing fields as the referent fields.
  • If referent fields are already enabled, the tool will populate the existing fields by default so that they can be modified.
  • The existing data in the referent fields is not validated or updated when you enable or modify the referent fields.
  • To disable the referent fields, use the Disable Referent Fields tool.
Parameters
Label Explanation Data type
Event Feature Class
The feature class that will be used for the LRS event.
Feature Layer
Referent Method Field
(Optional)
The From referent method field.
Field
Referent Location Field
(Optional)
The From referent location field.
Field
Referent Offset Field
(Optional)
The From referent offset field.
Field
To Referent Method Field
(Optional)
The To referent method field.
Field
To Referent Location Field
(Optional)
The To referent location field.
Field
To Referent Offset Field
(Optional)
The To referent offset field.
Field
Offset Units
(Optional)
Specifies the offset unit of measure that will be used.
  • Miles (US Survey)—The unit of measure will be miles. This is the default.
  • Inches (US Survey)—The unit of measure will be inches.
  • Feet (US Survey)—The unit of measure will be feet.
  • Yards (US Survey)—The unit of measure will be yards.
  • Nautical Miles (US Survey)—The unit of measure will be nautical miles.
  • Feet (International)—The unit of measure will be international feet.
  • Statute Miles—The unit of measure will be statute miles.
  • Millimeters—The unit of measure will be millimeters.
  • Centimeters—The unit of measure will be centimeters.
  • Meters—The unit of measure will be meters.
  • Kilometers—The unit of measure will be kilometers.
  • Decimeters—The unit of measure will be decimeters.
String
Derived output
Output Event Feature Class
The updated event feature layer.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Standard: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
  • Advanced: Requires ArcGIS Location Referencing (ArcGIS Pipeline Referencing or ArcGIS Roads and Highways)
