Transfer to another line method
Available with Location Referencing license.
During route reassignment, events are impacted in the edit section and upstream and downstream of the reassignment, depending on the configured event behavior for the event layer.
Events are not updated until the Apply Event Behaviors tool is run after route edits. If you are using conflict prevention on branch versioned data, you are prompted to run Apply Event Behaviors before posting to the default version.
When Recalibrate route downstream is chosen for an LRS route edit, the configured calibrate event behavior is applied to downstream sections. You can review configured event behaviors by viewing LRS event properties.
The reassignment method, route edit, and event behaviors are described below.
This method is for line networks only.
Routes are transferred to a new line if a new line name is provided.
Routes are transferred to an adjacent line if an existing line name is provided.
Upstream and downstream sections
Route editing impacts upstream and downstream sections differently.
The following image shows the upstream and downstream section for the route reassignment scenario:
The following table details how the reassignment editing activity impacts upstream and downstream events according to the configured event behavior:
Behavior |
Events upstream reassignment |
Events intersecting reassignment |
Events downstream reassignment |
Stay Put |
No action |
Retire event. Line events crossing the edit section are split and the original event is retired. |
If route calibration is changed, the calibrate event behavior is applied; otherwise, no action is taken. |
Move |
Shape regenerated, if needed, to new location of route measures |
Shape regenerated to the new location of route measures. |
Retire |
No action |
Retire event. Line events crossing the reassignment region do not split. |
Snap |
No action |
Geographic location (x,y) is maintained. The event is migrated to the reassigned route. Line events crossing the edit section are split. |
The network can contain events that span routes in a line network. The behaviors are still applied in the same manner.
Because the LRS is time aware, routes and events are time sliced with edit activities, such as reassigning a route.
Transfer routes to a new line
In this example, there are two lines, each with three routes that are active from 1/1/2000. On 1/1/2005, all three routes within LineA are transferred to a new line, LineNew.
Route2 has changed its name.
Route3 has changed measures in the reassignment.
The graphics and tables below demonstrate the route information before and after the reassignment.
Before route reassignment
The following image shows the routes before reassignment:
The following table provides details about the routes before reassignment:
Route Name |
Line Name |
Line Order |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
LineA |
100 |
1/1/2000 |
<Null> |
0 |
10 |
Route2 |
LineA |
200 |
1/1/2000 |
<Null> |
5 |
15 |
Route3 |
LineA |
300 |
1/1/2000 |
<Null> |
20 |
40 |
RouteA |
LineB |
100 |
1/1/2000 |
<Null> |
5 |
15 |
RouteB |
LineB |
200 |
1/1/2000 |
<Null> |
0 |
10 |
RouteC |
LineB |
300 |
1/1/2000 |
<Null> |
25 |
45 |
After route reassignment
The following image shows the routes after reassignment:
The following table provides details about the routes after reassignment:
Route Name |
Line Name |
Line Order |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
LineA |
100 |
1/1/2000 |
1/1/2005 |
0 |
10 |
Route1 |
LineNew |
100 |
1/1/2005 |
<Null> |
0 |
10 |
Route2 |
LineA |
200 |
1/1/2000 |
1/1/2005 |
5 |
15 |
Route2_new |
LineNew |
200 |
1/1/2005 |
<Null> |
5 |
15 |
Route3 |
LineA |
300 |
1/1/2000 |
1/1/2005 |
20 |
40 |
Route3 |
LineNew |
300 |
1/1/2005 |
<Null> |
20 |
60 |
RouteA |
LineB |
100 |
1/1/2000 |
<Null> |
5 |
15 |
RouteB |
LineB |
200 |
1/1/2000 |
<Null> |
0 |
10 |
RouteC |
LineB |
300 |
1/1/2000 |
<Null> |
25 |
45 |
Events before reassignment
The following image shows the routes and events before reassignment:
The following table provides details about the events before reassignment:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
Route3 |
1/1/2000 |
<Null> |
5 |
40 |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
The following sections detail how event behavior rules are enforced after running the Apply Event Behaviors tool, when the routes on LineA are transferred to a new line, LineNew.
Stay Put event behavior
Although the geographic location of the event outside the reassign region is maintained, the measures can change. The event can also split if it crosses the reassign region. Portions in the reassign region are retired.
The route reassignment described above has the following effects:
Event1 is retired on the date of reassignment because it fell entirely within the edit section.
Event2 is not affected by the reassignment as it is in part of routes in LineB.
The following image shows the routes and events after reassignment:
It is important to note that the retired event is not drawn in the graphic above.
The following table provides details about the events after reassignment when Stay Put is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Move event behavior
Although the measures of the event are maintained, the geographic location can change.
Event1 was entirely in the edit section; it is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. Because the measures do not change for the Move behavior, this new event still spans from measure 5 on Route1 to measure 40 on Route3, but its location has changed due to change in the underlying measures in Route3.
Event2 is not affected by the reassignment as it is in LineB.
The following table provides details about the events after reassignment when Move is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Event1 |
Route1 |
Route3 |
1/1/2005 |
<Null> |
5 |
40 |
No Error |
The new Event1 exists after the Apply Event Behaviors tool is run but has no shape.
Retire event behavior
Events intersecting the reassignment region are retired.
Event1 was present in the edit section; it is retired on the date of reassignment.
Event2 is not affected by the reassignment as it is in Line B.
The following table provides details about the events after reassignment when Retire is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Snap event behavior
Although the geographic location of the event is maintained by snapping to the route that it was reassigned to, the measures can change. The event gets a new time slice when the route it belongs to has reassigned to another line, whether or not the Route Name or measure change in the reassignment. The event can also split if it crosses the reassign region.
Event1 was present in the edit section; it is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created on the new routes with the new underlying measures to maintain its geographic location.
The following table provides details about the events after reassignment when Snap is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event1 |
Route1 |
Route3 |
1/1/2005 |
<Null> |
5 |
60 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Transfer routes to an existing, adjacent line
In this example, there are two lines, each with three routes that are active from 1/1/2000. On 1/1/2005, a portion of Route2 and the entire Route3 within LineA are transferred to an existing line, LineB.
The reassigned portion of Route2 has got a new route name.
Route Name |
Line Name |
Line Order |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
LineA |
100 |
1/1/2000 |
<Null> |
0 |
10 |
Route2 |
LineA |
200 |
1/1/2000 |
<Null> |
5 |
15 |
Route3 |
LineA |
300 |
1/1/2000 |
<Null> |
20 |
40 |
RouteA |
LineB |
100 |
1/1/2000 |
<Null> |
5 |
15 |
RouteB |
LineB |
200 |
1/1/2000 |
<Null> |
0 |
10 |
RouteC |
LineB |
300 |
1/1/2000 |
<Null> |
25 |
45 |
Route Name |
Line Name |
Line Order |
From Date |
To Date |
From Measure |
To Measure |
Route1 |
LineA |
100 |
1/1/2000 |
<Null> |
0 |
10 |
Route2 |
LineA |
200 |
1/1/2000 |
1/1/2005 |
5 |
15 |
Route2 |
LineA |
200 |
1/1/2005 |
<Null> |
5 |
10 |
Route2_reassign |
LineB |
100 |
1/1/2005 |
<Null> |
10 |
15 |
Route3 |
LineA |
300 |
1/1/2000 |
1/1/2005 |
20 |
40 |
Route3 |
LineB |
200 |
1/1/2005 |
<Null> |
20 |
60 |
RouteA |
LineB |
100 |
1/1/2000 |
1/1/2005 |
5 |
15 |
RouteA |
LineB |
300 |
1/1/2005 |
<Null> |
5 |
15 |
RouteB |
LineB |
200 |
1/1/2000 |
1/1/2005 |
0 |
10 |
RouteB |
LineB |
400 |
1/1/2005 |
<Null> |
0 |
10 |
RouteC |
LineB |
300 |
1/1/2000 |
1/1/2005 |
25 |
45 |
RouteC |
LineB |
500 |
1/1/2005 |
<Null> |
25 |
45 |
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Event1 |
Route1 |
Route3 |
1/1/2000 |
<Null> |
5 |
40 |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
The following sections detail how event behavior rules are enforced after running the Apply Event Behaviors tool, when the routes on LineA are transferred to LineB.
Although the geographic location of the event outside the reassign region is maintained, the measures can change. The event can also split if it crosses the reassign region. Portions in the reassign region are removed.
Event1 falls in the edit section; it is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. The new event is located only on Route1 and part of Route2 that were not impacted by the edit.
Even though the line orders have changed on the three routes on LineB, Event2 is not affected by the reassignment, because it can still locate the From and To routes and measures.
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event1 |
Route1 |
Route2 |
1/1/2005 |
<Null> |
5 |
10 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Move event behavior
Event1 was partially in the edit section; it is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created. The move behavior does not allow changing the From and To route IDs or measures of the event. It returns a location error because Route1 and Route3 are now on different lines, but the event cannot span across lines.
The following table provide details about the events after reassignment when Move is the configured event behavior:
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Event1 |
Route1 |
Route3 |
1/1/2005 |
<Null> |
5 |
40 |
Different From and To Route Line IDs |
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Loc Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
Snap event behavior
Although the geographic location of the event is maintained by snapping to the route that it was reassigned to, the measures can change. The event gets a new time slice when the route it belongs to has reassigned to another line, no matter the Route Name or measures change or not in the reassignment. The event can also split if it crosses the reassign region.
Event1 was partially in the edit section; it is retired on the date of reassignment, and a new event with the reassignment date as the From Date is created on the non-impacted portion from Route1 to the measure 10 of Route2.
Part of Event1, that was in the impacted portion, is snapped to the new routes with the new measures: from measure 10 of Route2_reassign to measure 60 of Route3. It gets its From Date from the date of reassignment.
Event |
From Route Name |
To Route Name |
From Date |
To Date |
From Measure |
To Measure |
Location Error |
Event1 |
Route1 |
Route3 |
1/1/2000 |
1/1/2005 |
5 |
40 |
No Error |
Event1 |
Route1 |
Route2 |
1/1/2005 |
<Null> |
5 |
10 |
No Error |
Event1 |
Route2_reassign |
Route3 |
1/1/2005 |
<Null> |
10 |
60 |
No Error |
Event2 |
RouteA |
RouteB |
1/1/2000 |
<Null> |
5 |
5 |
No Error |
