View centerline properties
Available with Location Referencing license.
You can view the properties of a centerline as either a map layer or a feature class.
Centerline properties
The following tables describe the centerline properties:
Centerline Name
The Centerline Name property appears at the top of the Location Referencing tab.
Property |
Description |
Centerline Name |
The name of the centerline feature class. |
Fields
You can view the following Fields properties for the centerline feature class:
Property |
Description |
Centerline ID |
The unique ID for the centerline geometry. |
Utility Network
If the centerline feature class is part of an ArcGIS Utility Network configuration, you can view the following Utility Network properties for the centerline feature class:
Property |
Description |
Route ID |
The route ID field configured in a utility network |
From Measure |
The start measure field configured in a utility network |
To Measure |
The end measure field configured in a utility network |
View centerline properties by map layer
You can view the properties of a centerline map layer from the Contents pane:
Open the Contents pane in ArcGIS Pro.
Right-click the centerline layer, and click Properties.
The Layer Properties dialog box appears with the selected centerline layer name in the title bar.
The tabs on the dialog box are specific to the selected layer type.
Click the Location Referencing tab.
Scroll down if the tab isn't visible in the list.
The Location Referencing tab displays general properties for the selection at the top, with additional nodes below.
Click the arrow for a node to expand or collapse its properties.
If the value or field name is longer than the field, hover over the property to view its details, or resize the dialog box to view additional details.
Tip:
You can copy the read-only properties to the clipboard.
Click OK to close the Layer Properties dialog box.
View centerline properties by feature class
You can view the properties of a centerline feature class from the Catalog pane:
Open the Catalog pane in ArcGIS Pro.
Expand the geodatabase connection and the feature dataset to browse to the feature class.
Right-click the centerline feature class, and click Properties.
The Feature Class Properties dialog box appears with the selected feature class name in the title bar.
Tip:
Click OK to close the Feature Class Properties dialog box.
