Lines
Available with Location Referencing license.
In ArcGIS Pipeline Referencing, a logical grouping of more than one nonbranching route is called a line. The concept of a line can be used for a continuous section of the pipeline such as a mainline pipe, lateral or discharge section, or a piggable segment such as launcher to receiver. While routes are a continuing, uninterrupted range of measure, a line can handle discontinuities in measure (equations).
Line information in the LRS data model
The LRS data model does not have a separate line feature class. In Pipeline Referencing, line information is stored with the LRS Network feature class that uses it. Lines are supported only for LRS line networks.
Learn more about using multiple linear referencing methods
Lines can be configured during LRS Network creation using either the Create LRS Network or Create LRS Network From Existing geoprocessing tools.
Learn more about creating and modifying an LRS Network
The Line ID is a system-generated, global unique identifier (GUID) that Pipeline Referencing uses to associate multiple routes to a single logical group called a line. Line Order then indicates the sequence in which the routes in the line are connected end-to-end. As route editing activities are performed, Pipeline Referencing tools regenerate the line order as needed. Line Name is a unique defined name given to a line.
LRS line network configuration
LRS line networks are optional. If your business needs require you to handle discontinuities in measure (equations), an LRS line network is the provided mechanism to support this. For example, when a pipeline is realigned (rerouted), discontinuities are introduced in measures. These discontinuities in measure are needed to correlate measures between different time lines of pipeline surveys (before realignment and after realignment). This also allows you to restrict change in measures that are downstream of the affected area.
Another advantage of configuring a line network is that you can model events that span routes. Using the principle of an LRS line network, you can track, locate, and manage the events that occur on the pipeline by their measure (engineering stations), even if the measures span routes on a line. Examples of events spanning routes are DOT Class and Operating Pressure.
