Manage S-100 products
You can use the S-100 Product Manager tool in to organize and manage S-100 products and their exports. You can access the tool from the Maritime S-100 tab, in the S-100 Editing group. To activate the tab, you must add a feature class from a maritime S-100 geodatabase to the map.
The S-100 Product Manager tool only supports S-101 products starting at ArcGIS Pro 3.8.
You can do the following from the S-100 Product Manager pane:
Manage a system of series and series types to organize products in a database.
Move products from one series to another.
View product footprints.
Export a product from a geodatabase.
Publish exported products.
Reject exported products.
View the export history of a product.
Save exported products.
View associated S-57 products in a co-production database. To support co-production, the database must use the supplementary S-57 co-production schema.
Important:
If you are working with an enterprise geodatabase, you must use the data owner connection to create and rename a series, and to move products between series.
Each action is described in the following sections.
Create a product series
You can use the S-100 Product Manager tool to create and organize products into series. Series are similar to folders; each series can be named, nested, and contain as many products as you choose. The S-100 Product Manager tool contains a default series named DEFAULT for any products that are not sorted into a named series. When new products are added to the source database, they are placed in the default series.
You can create root-level series and subseries under each root series.
To create a series, complete the following steps:
Start ArcGIS Pro.
Open a new or existing project.
Add data from a maritime S-100 geodatabase to the map if necessary.
The Maritime S-100 tab appears.
On the Maritime S-100 tab, in the S-100 Editing group, click S-100 Product Manager
.The S-100 Product Manager pane appears.
If the map contains layers from more than one data source, click the Data Source drop-down arrow, and choose a source.
The list of data sources is based on the data sources of the layers added to the map.
Right-click in the S-100 Product Manager pane and click New Root Series.
Provide a name for the series and press Enter.
The series is created in the S-100 Product Manager pane.
Tip:
Click Refresh to sort the series alphabetically.
To create a subseries under a series, right-click the name of the existing series and click New Series.
Provide a name for the subseries and press Enter.
The subseries is created under the existing series.
Rename a series
You can rename any series or subseries that you add to the S-100 Product Manager pane.
To rename a series, complete the following steps:
Start ArcGIS Pro.
Right-click the series you want to rename and click Rename from the context menu.
Provide a new name for the series and press Enter.
The series is renamed.
Organize products by series types
Series types allow you to sort products using multiple categorization methods, such as by regions, states, and districts. Each series type can have its own hierarchy and all products are assigned to the DEFAULT series in a new series type. You can manage series types in the SeriesTypes table.
To organize products by series types, complete the following steps:
Start ArcGIS Pro.
From the Catalog pane, expand the S-100 database and open the SeriesTypes table.
Add a new row to the table and provide a name for the series type in the Name field.
Important:
Do not delete the Sample Type row in the SeriesTypes table. The Sample Type GUID is used to store all series that are not organized within a specific series type. You can reuse the GUID by editing the
NameandDescriptionfields.Optionally, add a description in the
Descriptionfield.Press Enter.
The series type is created. It will appear in the Series Type drop-down list when the S-100 Product Manager pane is refreshed.
Save the table edits.
Click the map to activate the map contents and contextual tabs on the ribbon.
Choose a data source from the Data Source drop-down list, if necessary.
Choose a series type from the Series Type drop-down list.
The specified series type is loaded in the S-100 Product Manager pane. When you create a new series type, all products appear under the DEFAULT series until they are sorted. You can create root series and subseries that are specific to each series type. When a product is moved within one series type, it does not change its placement in a different series type.
Move products
Products can be moved from one series to another using the Cut Product(s) option from the context menu to cut one or more products from one series and the Paste Product(s) option to paste them to another series.
To move a product, complete the following steps:
Start ArcGIS Pro.
In the S-100 Product Manager pane, right-click the product that you want to move and click Cut Product(s).
Tip:
To select multiple products in the same series, press and hold the Ctrl key while clicking each product you want to move. To select a range of products, press and hold the Shift key while clicking the first and last products in the range.
Right-click the name of the series that you want to move the product to and click Paste Product(s).
The product is moved to the specified series.
Products cannot be moved between series types.
You can use the S-100 Product Manager pane to view product footprints on the map. When viewing a product footprint, it is added to the Product Footprints group layer. You can turn the footprint layers off and on in the Contents pane.
To view a product footprint, complete the following steps:
Start ArcGIS Pro.
In the S-100 Product Manager pane, right-click the product with the footprint you want to view and click Show Product Footprint.
The product footprint is added to the Product Footprints group layer and the footprint is displayed on the map.
Export products
You can use the Export S-101 Cell tool to export products from the S-100 Product Manager pane. You can view export history of products in the lower half of the pane, where export history is ordered by date, with the most recent export listed first.
You can export the following product types:
New Dataset—A new dataset that contains information not previously distributed by updates.
New Edition—A new edition of a dataset that contains information not previously distributed by updates.
Update—An edition that records changes to a dataset since the last export.
Reissue—A reissue of a dataset that includes all updates applied up to the reissue date. A reissue does not contain information that has not been previously issued by updates.
Cancel—When you delete a dataset, an updated cell file is created that contains only the Dataset General Information record with the Dataset Identifier (DSID) field. The Dataset Edition (DSED) subfield must be set to 0. Canceled products cannot be published.
When exporting products, keep the following in mind:
When a product is exported, its status changes from published to unpublished.
You can only generate sample exports from unpublished products.
Sample exports are not stored.
To export a product from the S-100 Product Manager pane, complete the following steps:
In the S-100 Product Manager pane, right-click the product that you want to export and click Export.
The Export S-101 Cell tool opens in the Geoprocessing pane. The S-101 Workspace and S-101 Product parameters are populated with information from the product selected in the S-100 Product Manager pane.
Provide an S-100 Feature Catalogue file for the S-100 Feature Catalogue parameter.
The default file location is
<ArcGIS Maritime installation location>\ArcGIS Maritime\Product Files\<version>\S-101.Choose an export type.
Provide a location to store the export for the Output Location parameter, if necessary.
The default location is the project's home folder.
Optionally, check the Sample Export check box to export a sample cell.
Optionally, check the Suppress Exchange Set check box to export a product without generating an exchange set.
Click Run.
The product is exported and stored in the ProductExports table as a BLOB. Product metadata is updated with the latest export details in the ProductDefinitions table.
After a product is exported, you can either publish or reject the export. To publish or reject an exported product, follow the steps in the following section.
Publish or reject products
When S-100 products are imported to a geodatabase, they are published as part of the import process. However, when the product is exported, it is unpublished. You can publish exported products from the S-100 Product Manager pane.
To publish or reject an exported product, complete the following steps:
In the S-100 Product Manager pane, do one of the following:
Right-click the product and click Publish Exported Cell.
When a product export is published, the
Publishedfield is updated toTruein the ProductDefinitions table, and a green check mark appears next to the product name in the S-100 Product Manager pane.
Right-click the product name and click Reject Export to delete the last export.
The export is deleted from the ProductExports table and the metadata in the ProductDefinitions table rolls back to the last export.
Optionally, enable automatic publishing for exported products by doing the following:
In the Catalog pane, right-click the ProductDefinitions table and click Data Design > Fields.
In the
Publishedrow, set theDefaultfield value toTrue.Save the table edits.
Close the Fields: ProductDefinitions table.
View export history
You can view the export history for a selected product in the export history section of the S-100 Product Manager pane. To view details about a particular export, hover over the export that you want to view details for. Details about the dataset edition, application profile, dataset reference date, and who initiated the export are provided in the pop-up that appears.
You can save exported products from the export history section of the S-100 Product Manager pane.
To save an exported product, complete the following steps:
In the S-100 Product Manager pane, click a product to view its export history.
The export history of the selected product appears in the lower half of the pane.
Right-click the row for the version you want to save and click Save this version.
On the Save S-101 Cell dialog box, browse to the location where you want to save the product.
Optionally, edit the name of the S-100 cell file in the File name text box.
Click Save.
The exported product is saved as a
.zipfile at the specified location.
S-57 product associations for co-production
You can view products in a co-production database by product type. To switch the Product Type view, click the Menu button in the S-100 Product Manager pane and choose the product type you want to view as the primary nodes.
When viewing by S-101 product type, related S-57 products appear as child items of the S-101 product node. If an S-57 product is related to multiple S-101 products, the other S-101 products appear under the S-57 product node.
When viewing by S-57 product type, the S-101 products appear as child items of the S-57 product node. You can perform all S-57-related operations from the context menu of an S-57 product node.
The S-57 Product Manager tool is disabled for co-production databases.
