LRS Network
Available with Location Referencing license.
ArcGIS Roads and Highways supports three types of networks: linear referencing system (LRS) networks, LRS line networks, and LRS derived networks.
LRS Network
An LRS Network is a collection of routes measured to a specific linear referencing method (LRM).
Example
Odometer networks and county networks.
LRS Network
LRS line network
An LRS line network is a logical grouping of routes to a line where the measure can increase or decrease monotonically. This type of network supports events that span routes and also supports equations.
Example
An Engineering Station Network feature class holds the required fields to be modeled as a line network.
LRS Line Network
Route ID
Route Name
Line Order
Line ID
Line Name
{1838BE01-0BC9-4C58-9829-0F1D77717DCB}
Route 1
100
{C043CAF0-2BF7-4598-8AC8-B382647AD490}
Line A
{26710A05-C499-42C1-BB73-D3A8D402B109}
Route 2
200
Line A
{5582FB08-84E3-49D4-8781-1D3EF7B4F2E2}
Route 3
300
Line A
LRS derived network
A derived network is a network generated from a line network. In a derived network, routes that belong to the same line are merged to create one route with a starting measure of zero.
Example
Using an Engineering Station Network feature class as the parent network, the continuous network routes can be derived. A derived network is a collection of routes where the measures are continuous, such as a nonbranching run of a physical pipe. These measures can then be used for length reporting and dynamic segmentation analysis.
LRS Derived Network
Why different types of LRS Networks are needed
Roads and Highways supports multiple linear referencing in a single geodatabase. Business units in an organization may need to report measures in many different LRMs. For example, engineering and construction may need to collect, maintain, and report events in engineering measures (also known as engineering stations), whereas other business entities need to report measures based on continuous length.
Location Referencing currently does not have a limit for the number of networks that you can create in a linear referencing system (LRS). However, the type of LRS Networks you need depends on your organization’s business process.
When different types of LRS Networks are required
Every organization's business processes are different. If your business process only requires one type of network, you do not have to configure multiple LRS Networks. For example, if your business process requires continuous measures to be maintained and reported, you can configure your LRS to only support a non-line LRS Network. Similarly, if your business process collects and maintains data with equation points or other engineering stationing, you can configure an LRS line network to maintain the data as it is collected and an LRS derived network for continuous measure reporting. In this scenario, you can also configure events to store derived measures.
The LRS derived network is generated from the LRS line network. If you don't configure an LRS line network, the LRS derived network can't be configured.
