Essential vocabulary
The terms and abbreviations defined below are used in ArcGIS Topographic Mapping.
BUA
Acronym for built-up area.
CTM
Initialism for Civilian Topographic Map (CTM). The Topographic Mapping extension supports CTM map products at the following map scales:
  • CTM25—1:25,000
  • CTM50—1:50,000
EC
Initialism for entity catalog.
Extraction guide
A document that provides extraction guidance for all the features in a data specification. The instructions in the guide may include information about the dimensions for features for a specific feature class as well as their attributes. The purpose of the extraction guide is to provide a logical approach to feature extraction that results in consistent data collection.
EVC
Initialism for Evasion Chart.
GAIT
Acronym for Geospatial Analysis Integrity Tool.
ICM
Initialism for Image City Map.
JNC
Initialism for Jet Navigation Chart.
JOG
Initialism for Joint Operations Graphic.
MGCP
Initialism for Multinational Geospatial Co-production Program.
MTM
Initialism for MGCP Topographic Map. The Topographic Mapping extension supports MTM map products at the following map scales:
  • MTM25—1:25,000
  • MTM50—1:50,000
  • MTM100—1:100,000
NGA
Initialism for National Geospatial-Intelligence Agency.
NRN
Initialism for NGA reference number.
ONC
Initialism for Operational Navigation Chart.
Shapefile
A shapefile is a vector data storage format for storing the location, shape, and attributes of geographic features. A shapefile is stored in a set of related files and contains one feature class.
TDS
Initialism for topographic data store. A TDS is a digital repository that stores information, at different map scales, about land area, including elevation, contours, rivers, roads, and other landmarks. The topographic features collected adhere to the TDS EC, a structured list that defines all the different types of geographic features that can be stored. It is a subset of the National System for Geospatial Intelligence (NSG) EC.
TM
Initialism for Topographic Map. The Topographic Mapping extension supports TM map products at the following map scales:
  • TM25—1:25,000
  • TM50—1:50,000
  • TM100—1:100,000
TPC
Initialism for Tactical Pilotage Chart.
TRD
Initialism for Technical Reference Document. The MGCP TRD includes documentation for the MGCP Data Model, MGCP Data Extraction, and MGCP Quality.
Vertex
A vertex is a point of x,y coordinate pairs that define the shape of a line or polygon feature.
Z-value
The value for a surface location that represents an attribute other than position. In an elevation or terrain model, the z-value represents elevation; in other surface models, it represents the density or quantity of a particular attribute.
