Feature attribute to graphic text mapping information
Licensing Portal Available with an ArcGIS Topographic Mapping license.
The Populate Map Sheet Info tool populates text in graphic elements on an ArcGIS Pro layout. Text populates with feature attribute values from a selected area of interest (AOI) feature in the map. The tool searches each graphic element for tagged (<tag> </tag>) text. The tool compares tagged text to values in the PopMapInfo table. Any matching values are replaced in the graphic element with an attribute value from the selected AOI feature.
Populating graphic text elements with attribute values
The Populate Map Sheet Info tool scans each graphic element for tagged (<tag> </tag>) text on an ArcGIS Pro layout. The tool compares tagged text to the DM_Tag value listed in the table below. If it finds a match, it reads the attribute value from the corresponding Field_Name. It replaces the tagged text with the attribute value. If no match is found, the tool skips the text and continues processing.
Custom Field_Name and DM_Tag attributes can be added to the table to allow for use of new feature attributes and associated graphic elements. The PopMapInfo table is in the MapIndex database stored in the ReferenceData folder, located in the ArcGIS Topographic Mapping product file folders.
ArcGIS Topographic Mapping map templates often use graphic elements with bracketed ([ ]) text to indicate text that should be updated to meet the product specification. However, brackets are not required by the Populate Map Sheet Info tool.
Field name
DM_Tag
Classification
dm001
Contour_Interval
dm002
Contour_Interval_Supp
dm003
Coord_Conv_Datum
dm004
Coord_Conv_Geog_Lat
dm005
Coord_Conv_Geog_Long
dm006
Coord_Conv_Grid_East
dm007
Coord_Conv_Grid_North
dm008
Country
dm009
Edition
dm010
Edition_Barcode
dm011
JOG_Sheet
dm012
NRN
dm013
NSN
dm014
OneSecLatMeters_East
dm015
OneSecLatMeters_West
dm016
OneSecLongMeters_North
dm017
OneSecLongMeters_South
dm018
Printed_By
dm019
SERIES
dm020
Sheet
dm021
Sheet_Name
dm022
Sheet_Roman
dm023
UTM_Zone
dm024
Year_Copyright
dm025
Year_Map_Info
dm026
AirInfo_Date
dm027
Contour_Interval_Depth
dm028
ICM_Sheet
dm029
ICM_North
dm030
ICM_North_Scale
dm031
Image_Date
dm032
Image_Date_Inset1
dm033
Image_Date_Inset2
dm034
MagVar_Rate
dm035
Scale
dm036
Year_Intl_Bnd
dm037
Year_MagVar
dm038
ISFAR
dm039
PlaceName1
dm040
PlaceName2
dm041
PlaceName3
dm042
PlaceName4
dm043
PlaceName5
dm044
Railroad_Gauge
dm045
UTM_Zone2
dm046
VO_AboveGroundLevel_1
dm047
VO_AboveGroundLevel_2
dm048
VO_AboveSeaLevel_1
dm049
VO_AboveSeaLevel_2
dm050
Year_LimitedUpdates
dm051
Year_Veg_Info
dm052
Layout element to attribute name cross-reference
