Export to BMP
BMP format files are native Windows raster images. .bmp files can store pixel data at several bit depths and can be compressed using the lossless RLE method. BMP images are typically much larger than formats such as JPEG or PNG.
To export a .bmp file, ensure that a map or layout view is active. On the Share tab, click Export Map or Export Layout , depending on the active view, to open the Export pane. Change the File Type option to BMP. Set a name and location for the file, and any other properties, and click Export.
Certain options are only available when exporting a map or layout. When exporting a map, you can set the size of the map export. When exporting a layout, you can clip to graphics extent.
The following properties are available when exporting to a .bmp file:
Property
Show selection symbology
Show selected features in the map or map frame as selected in the output file. Unchecking this option does not affect selection within the view, only in the output file.
Raster resolution
The resolution of the export file in dots per inch (dpi). DPI is only available when exporting a layout. When exporting a map, the dpi is calculated automatically. For map exports, increase the Width and Height values to add more pixels and get a higher-resolution output.
Write world file
In the same location as the exported map, generate a separate world file that contains georeference information. This allows the exported image to be used as raster data in ArcGIS Pro or other GIS applications.
When exporting a layout, set Map frame to the 2D map frame you want the world file georeferenced information to be based on.
This option is not available in 3D views.
Color depth
The number of bits to describe color in a pixel. Choose from the following:
  • 1-bit Monochrome Threshold— 2 possible colors, black and white. The areas which are white and black are determined by the Threshold value
  • 8-bit Grayscale—256 shades of gray. All colors are converted to grayscale.
  • 24-bit True Color—16,777,216 possible colors. This option is good for maximum color fidelity.
