Export to EPS
EPS format files use the PostScript page description language to describe vector and raster objects. PostScript is the publishing industry standard for high-end graphics files, cartography, and printing. .eps files can be edited in many drawing applications or placed as a graphic in most page layout applications. EPS format supports font embedding and can define colors in CMYK or RGB values.
To export an .eps file, ensure that a map or layout view is active. On the Share tab, click Export Map or Export Layout , depending on the active view, to open the Export pane. Change the File Type value to EPS. Set a name and location for the file, as well as any other properties, and click Export.
Certain options are only available when exporting a map or layout. When exporting a map, you can set the size of the map export. When exporting a layout, you can clip to graphics extent.
The following properties are available when exporting to an .eps file:
Property
Show selection symbology
Show selected features in the map or map frame as selected in the output file. Unchecking this option does not affect selection within the view, only in the output file.
Output as image
Export vector content as an image. For maps or layouts containing vector layers with a high density of vertices, this can drastically reduce the output file size.
Image compression
The compression scheme used to compress image or raster data in the output file. Choose from the following:
  • None—Compression is not applied.
  • Adaptive—JPEG and Deflate compression are combined, depending on the contents of the stream. This works well for most cases.
  • Deflate—Lossless compression method.
  • JPEG—Lossy compression method that works well for photographic-type images.
  • LZW—Lossless compression method using a code table.
  • RLE—Run-length encoded compression, a lossless compression method.
Vector resolution
The effective dpi of the vector data in the layout. DPI is available only when exporting a layout. When exporting a map, the dpi is calculated automatically.
Raster resample
The amount of image resampling. The control determines the effective resolution of raster content on output. For instance, if the output image quality ratio is set to 1:2 and the output resolution is set to 300 dpi, the raster content is output at approximately 150 dpi. In many cases, the raster data can be included at a lower dpi than the vector data without visibly affecting quality, reducing the output file size.
Embed fonts
Include embeddable fonts in the exported file to maintain font consistency across different platforms. Fonts that do not support embedding are not included, regardless of this setting.
Convert character marker symbols to polygon
Controls whether marker symbols based on font characters are exported as font characters or as polygons. Check this option to view the output on a machine that does not have the appropriate fonts installed when you cannot embed the fonts due to licensing or file format restrictions. This does not apply to text, only marker symbols based on fonts.
EPS format files do not natively support transparency. If there is transparent content in the map or layout, the data is automatically rasterized and no vector content is exported.
