Share a layer package
Layer packages
(.lpkx files) allow you to share layers. A layer package is a file that contains both the layer properties and the dataset referenced by the layer. With a layer package, you can save and share everything about the layer—its symbology, labeling, field properties, and associated data. You can include multiple layers in a layer package.
Other users can add layer packages directly into their maps without needing to access the database or set layer properties.
Additionally, a layer can be saved as a schema-only layer package. This type of package allows you to share a layer design and the corresponding data model design without sharing the data. When you unpack a schema-only layer package, the data model for the layers is loaded into the project's default geodatabase. You can then load your own datasets for the layers in that geodatabase.
Tip:
For a finer degree of control over how data is packaged, you can use the Package Layer geoprocessing tool. For example, you can specify that only data within the current map extent is packaged or that network datasets be excluded when packaging network analysis layers.
Create a layer package
Complete the following steps to create a layer package:
Select the layers you want to package in the Contents pane.
On the Share tab, in the Package group, click Layer
. Alternatively, right-click the selected layers, point to the Sharing menu, and click Share As Layer Package
.The Package Layers pane appears.
Specify where to save the package, either to your online account or as a file on disk.
Provide the name and, if saving the package to a file, the location for the new package on disk.
Optionally, complete the Summary and Tags fields.
A summary and tags are required when sharing to an ArcGIS Enterprise 10.9 or earlier portal.
If you save the package to your online account, you can use the Tags drop-down menu to select existing tags. You can enter a maximum of 128 tags.
If you choose to save the package to your online account, you can use the Categories drop-down menu to assign content categories.
You can assign a maximum of 20 categories.
Check the Include Enterprise and UNC Path Data check box if you want data from enterprise databases, UNC path folders, and feature services to be copied to file geodatabases.
If this option is not checked, layers will continue to reference enterprise geodatabase and UNC path data.
If you are uploading the package to an online account, use the Folder menu to specify where the package will be stored in your portal content. The package is stored in the root of your content by default. Optionally, click the Browse button
to create a folder or choose an existing one. You can also type the name of the folder in the text box.If you are uploading a package to an online account, specify how it will be shared:
Owner—Only the owner (and organization members with privileges to view content owned by other members) can access the item. This is the default option.
Organization—Share your content with all authenticated users in your organization. This option is available when you are signed in with an organizational account.
Everyone (public)—Share your content with the public. Anyone can access and see it.
- Optionally, under Groups, select groups to which you belong to share your content with their members.
Add the items you want to include to Attachments.
This option allows you to include other content, such as detailed documentation, reports, and graphs. The following types of files are not supported:
.js,.vbs,.py,.pyc,.pyo,.bat, and.ocx. Also, only signed.dlland.exefiles are allowed.Under Finish Sharing, click Analyze
to review for potential problems.Errors and warnings are listed on the Messages tab. Right-click a message to open its help topic or take corrective action in the software. Errors
must be resolved before you can share your GIS resource. Resolving warnings
is recommended but not required.Once the package is validated, click Package to create the package.
Create a schema-only layer package
The Package Schema Only option allows you to share a layer without its data.
The steps for creating a schema-only layer package are the same as those outlined above for saving a layer data package, except you choose the Package Schema Only option to create a schema-only layer package.
See Add layers to a map or scene to learn how to unpack a layer package.
