Save a layer file
A layer can exist outside of the map or project as a layer file Layer File (.lyrx). This allows others to access the layers you've built. You can share layers over the network or by email, or upload them to your ArcGIS Online or ArcGIS Enterprise portal.
When you add a layer file to a map, it draws exactly as it was saved, provided the data referenced by the layer is accessible. To save the layer and its data together, create a layer package instead. You can also save and share stand-alone tables as layer files.
  1. Select the layer or table you want to save as a layer file in the Contents pane.
  2. On the Share tab, in the Save As group, click Layer File . Alternatively, right-click the selected layer or table, point to the Sharing menu, and click Save As Layer File .
  3. On the Save Layer(s) As LYRX File dialog box, browse to a folder location or accept the default location. Provide a name for the new layer file or accept the default name.
  4. Click Save.
