ProSnippets Migrating to 2.0 vb
ProSnippets: Migrating to 2.0 Visual Basic
Language:      Visual Basic
Subject:       Framework
Contributor:   ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:  Esri, https://www.esri.com
Date:          9/28/2021
ArcGIS Pro:    2.9
Visual Studio: 2017, 2019
Find the C# migration document here: ProSnippets: Migrating to 2.0
The upgrade from ArcGIS Pro SDK 1.4 to ArcGIS Pro SDK 2.0 is a 'code breaking' change. This means that you have to change, recompile, rebuild, and redistribute any 1.x (SDK 1.4 and earlier) add-ins and configurations so that they work with ArcGIS Pro 2.0. This document lists the most common changes in the config.DAML and various API classes and interfaces.
In this topic
Upgrading the Config.daml to Pro SDK 2.0
All add-ins and configurations require that the "desktopVersion" attribute under the AddInInfo tag in the config.daml file is updated to the 2.0.0 version as shown below:
1.4 and earlier has a 1.x.x desktopVersion attribute under the AddInInfo tag:
<ArcGIS defaultAssembly="....dll" defaultNamespace="..." xmlns="...">
  <AddInInfo id="{...}" version="1.0" desktopVersion="1.4.7198">
    <Name>...</Name>
    <Description>...</Description>
    <Image>...</Image>
2.0 requires a 2.0.0 (or higher) desktopVersion attribute under the AddInInfo tag:
  <AddInInfo id="{...}" version="1.0" desktopVersion="2.0.0">
    <Name>...</Name>
    <Image>...</Image>
ArcGIS.Core.dll
ArcGIS.Core.Data
  • ArcGIS.Core.Data.FileSystemConnectionPath
  • ArcGIS.Core.Data.FileSystemDatastore
' before:
Using shapefile As New Shapefile(New ShapefileConnectionPath(New Uri("path\to\folder\containing\shapefiles")))
	Dim taxLotsFeatureClass As FeatureClass = TryCast(shapefile.OpenTable("TaxLots"), FeatureClass)
	Dim manHolesFeatureClass As FeatureClass = TryCast(shapefile.OpenTable("ManHoles.shp"), FeatureClass)
	' Can use the .shp extension, but its not needed.
	Dim taxDetailsTableWithoutExtension As Table = shapefile.OpenTable("TaxDetails")
	Dim taxDetailsTable As Table = shapefile.OpenTable("TaxDetails.dbf")
End Using
' now:
Using shapefile As New FileSystemDatastore(New FileSystemConnectionPath(New Uri("path\to\folder\containing\shapefiles"), FileSystemDatastoreType.Shapefile))
    Dim taxLotsFeatureClass As FeatureClass = shapefile.OpenDataset(Of FeatureClass)("TaxLots")
    Dim manHolesFeatureClass As FeatureClass = shapefile.OpenDataset(Of FeatureClass)("ManHoles.shp")
    Dim taxDetailsTableWithoutExtension As Table = shapefile.OpenDataset(Of Table)("TaxDetails")
    Dim taxDetailsTable As Table = shapefile.OpenDataset(Of Table)("TaxDetails.dbf")
End Using
  • ArcGIS.Core.Data.DatabaseConnectionFile
Dim connection As String = "C:\Work\temp.sde"
' before:
Dim sde As New Geodatabase(connection)
' now:
Dim dbGdbConnection = New DatabaseConnectionFile(New Uri(connection, UriKind.Absolute))
Dim sde As New Geodatabase(dbGdbConnection)
  • ArcGIS.Core.Data.Geodatabase.GetEnterpriseDatabaseType
' before:
Dim enterpriseDatabaseType As EnterpriseDatabaseType = geodatabase.GetEnterpriseDatabaseType()
' now:
Dim enterpriseDatabaseType = TryCast(geodatabase.GetConnector(), DatabaseConnectionProperties).DBMS
ArcGIS.Core.Geometry
  • ArcGIS.Core.Geometry.CubicBezierBuilder Constructor
Dim controlPt12D As ArcGIS.Core.Geometry.Coordinate2D
Dim controlPt22D As ArcGIS.Core.Geometry.Coordinate2D
Dim spatialReference As ArcGIS.Core.Geometry.SpatialReference
' before:
Dim startPt As ArcGIS.Core.Geometry.Coordinate
Dim endPt As ArcGIS.Core.Geometry.Coordinate
Dim coordinates As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Coordinate)
Dim cubicbezierbuilder = New CubicBezierBuilder(startPt, controlPt12D, controlPt22D, endPt, spatialReference)
Dim cubicbezierbuilder = New CubicBezierBuilder(coordinates, spatialReference)
' now:
Dim startPt2D As ArcGIS.Core.Geometry.Coordinate2D
Dim endPt2D As ArcGIS.Core.Geometry.Coordinate2D
Dim coordinates As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Coordinate2D)
Dim cubicbezierbuilder = New CubicBezierBuilder(startPt2D, controlPt12D, controlPt22D, endPt2D, spatialReference)
  • ArcGIS.Core.Geometry.CubicBezierBuilder.CreateCubicBezierSegment
' before:
Dim cubicbezierbuilder As ArcGIS.Core.Geometry.CubicBezierBuilder
Dim result As ArcGIS.Core.Geometry.CubicBezierSegment = cubicbezierbuilder.CreateCubicBezierSegment(startPt, controlPt12D, controlPt22D, endPt, spatialReference)
Dim result As ArcGIS.Core.Geometry.CubicBezierSegment = cubicbezierbuilder.CreateCubicBezierSegment(coordinates, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.CubicBezierSegment = CubicBezierBuilder.CreateCubicBezierSegment(startPt2D, controlPt12D, controlPt22D, endPt2D, spatialReference)
  • ArcGIS.Core.Geometry.EllipticArcBuilder Constructor
Dim centerPt2D As ArcGIS.Core.Geometry.Coordinate2D
Dim rotationAngle As Double
Dim semiMajorAxis As Double
Dim minorMajorRatio As Double
Dim radius As Double
Dim interiorPt2D As ArcGIS.Core.Geometry.Coordinate2D
Dim orientation As ArcGIS.Core.Geometry.esriArcOrientation
Dim centralAngle As Double
Dim chordLength As Double
Dim chordBearing As Double
Dim minorOrMajor As ArcGIS.Core.Geometry.MinorOrMajor
' before:
Dim orientation As ArcGIS.Core.Geometry.esriArcOrientation = 1
Dim fromPt As ArcGIS.Core.Geometry.MapPoint
Dim toPt As ArcGIS.Core.Geometry.MapPoint
Dim fromAngle As Double
Dim ellipticarcbuilder = New EllipticArcBuilder(centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, 1, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(centerPt2D, radius, 1, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(fromPt, toPt, interiorPt2D)
Dim ellipticarcbuilder = New EllipticArcBuilder(fromPt, toPt, centerPt2D, orientation, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(fromAngle, centralAngle, centerPt2D, radius, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor,
spatialReference)
' now:
Dim segment1 As ArcGIS.Core.Geometry.Segment
Dim segment2 As ArcGIS.Core.Geometry.Segment
Dim hintPoint2D As ArcGIS.Core.Geometry.Coordinate2D
Dim startPt As ArcGIS.Core.Geometry.MapPoint
Dim arcLength As Double
Dim endPt As ArcGIS.Core.Geometry.MapPoint
Dim startAngle As Double
Dim ellipticarcbuilder = New EllipticArcBuilder(centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, orientation, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(segment1, segment2, radius, hintPoint2D, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(startPt, chordLength, chordBearing, arcLength, orientation, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(centerPt2D, radius, orientation, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(startPt, endPt, interiorPt2D)
Dim ellipticarcbuilder = New EllipticArcBuilder(startPt, endPt, centerPt2D, orientation, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(startAngle, centralAngle, centerPt2D, radius, spatialReference)
Dim ellipticarcbuilder = New EllipticArcBuilder(startPt, chordLength, chordBearing, radius, orientation, minorOrMajor,
spatialReference)
  • ArcGIS.Core.Geometry.EllipticArcBuilder.CreateEllipticArcSegment
' before:
Dim ellipticarcbuilder As ArcGIS.Core.Geometry.EllipticArcBuilder
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(fromAngle, centralAngle, centerPt2D, radius, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor,
spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(centerPt2D, radius, 1, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, 1, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, toPt, centerPt2D, orientation, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(fromPt, toPt, interiorPt2D, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(startAngle, centralAngle, centerPt2D, radius, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(startPt, chordLength, chordBearing, radius, orientation, minorOrMajor,
spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(centerPt2D, radius, orientation, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(segment1, segment2, radius, hintPoint2D, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(startPt, chordLength, chordBearing, arcLength, orientation, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, orientation, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(startPt, endPt, centerPt2D, orientation, spatialReference)
Dim result As ArcGIS.Core.Geometry.EllipticArcSegment = EllipticArcBuilder.CreateEllipticArcSegment(startPt, endPt, interiorPt2D, spatialReference)
  • ArcGIS.Core.Geometry.EnvelopeBuilder.CreateEnvelope
' before:
Dim minCoord As ArcGIS.Core.Geometry.Coordinate
Dim maxCoord As ArcGIS.Core.Geometry.Coordinate
Dim envelopebuilder As ArcGIS.Core.Geometry.EnvelopeBuilder
Dim result As ArcGIS.Core.Geometry.Envelope = envelopebuilder.CreateEnvelope(minCoord, maxCoord, spatialReference)
' now:
Dim minCoord3D As ArcGIS.Core.Geometry.Coordinate3D
Dim maxCoord3D As ArcGIS.Core.Geometry.Coordinate3D
Dim envelope As ArcGIS.Core.Geometry.Envelope
Dim result As ArcGIS.Core.Geometry.Envelope = EnvelopeBuilder.CreateEnvelope(minCoord3D, maxCoord3D, spatialReference)
Dim result As ArcGIS.Core.Geometry.Envelope = EnvelopeBuilder.CreateEnvelope(spatialReference)
Dim result As ArcGIS.Core.Geometry.Envelope = EnvelopeBuilder.CreateEnvelope(envelope, spatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.Area
Imports geometryengine = ArcGIS.Core.Geometry.GeometryEngine
Dim geometry As ArcGIS.Core.Geometry.Geometry
' before:
Dim result As Double = geometryengine.Area(geometry)
' now:
Dim result As Double = GeometryEngine.Instance.Area(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.AutoComplete
Dim inputPolygon As ArcGIS.Core.Geometry.Polygon
Dim completionLine As ArcGIS.Core.Geometry.Polyline
' before:
Dim result As ArcGIS.Core.Geometry.Polygon = geometryengine.AutoComplete(inputPolygon, completionLine)
' now:
Dim result As ArcGIS.Core.Geometry.Polygon = GeometryEngine.Instance.AutoComplete(inputPolygon, completionLine)
  • ArcGIS.Core.Geometry.GeometryEngine.Boundary
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Boundary(geometry)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Boundary(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Buffer
Dim geometries As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Geometry)
Dim distance As Double
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Buffer(geometries, distance)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Buffer(geometry, distance)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Buffer(geometries, distance)
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Buffer(geometry, distance)
  • ArcGIS.Core.Geometry.GeometryEngine.CalculateNonSimpleMs
Dim multipart As ArcGIS.Core.Geometry.Multipart
Dim defaultMValue As Double
' before:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryengine.CalculateNonSimpleMs(multipart, defaultMValue)
' now:
Dim result As ArcGIS.Core.Geometry.Multipart = GeometryEngine.Instance.CalculateNonSimpleMs(multipart, defaultMValue)
  • ArcGIS.Core.Geometry.GeometryEngine.CalculateNonSimpleZs
Dim defaultZValue As Double
' before:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryengine.CalculateNonSimpleZs(multipart, defaultZValue)
' now:
Dim result As ArcGIS.Core.Geometry.Multipart = GeometryEngine.Instance.CalculateNonSimpleZs(multipart, defaultZValue)
  • ArcGIS.Core.Geometry.GeometryEngine.CenterAt
Dim x As Double
Dim y As Double
' before:
Dim result As ArcGIS.Core.Geometry.Envelope = geometryengine.CenterAt(envelope, x, y)
' now:
Dim result As ArcGIS.Core.Geometry.Envelope = GeometryEngine.Instance.CenterAt(envelope, x, y)
  • ArcGIS.Core.Geometry.GeometryEngine.Centroid
' before:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryengine.Centroid(geometry)
' now:
Dim result As ArcGIS.Core.Geometry.MapPoint = GeometryEngine.Instance.Centroid(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Clip
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Clip(geometry, envelope)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Clip(geometry, envelope)
  • ArcGIS.Core.Geometry.GeometryEngine.Contains
Dim geometry1 As ArcGIS.Core.Geometry.Geometry
Dim geometry2 As ArcGIS.Core.Geometry.Geometry
' before:
Dim result As Boolean = geometryengine.Contains(geometry1, geometry2)
' now:
Dim result As Boolean = GeometryEngine.Instance.Contains(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.ConvexHull
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.ConvexHull(geometry)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.ConvexHull(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Crosses
' before:
Dim result As Boolean = geometryengine.Crosses(geometry1, geometry2)
' now:
Dim result As Boolean = GeometryEngine.Instance.Crosses(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Cut
Dim cutter As ArcGIS.Core.Geometry.Polyline
' before:
Dim result As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Geometry) = geometryengine.Cut(geometry, cutter)
' now:
Dim result As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Geometry) = GeometryEngine.Instance.Cut(multipart, cutter)
  • ArcGIS.Core.Geometry.GeometryEngine.DensifyByDeviation
Dim maxDeviationMeters As Double
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.DensifyByDeviation(geometry, maxDeviationMeters)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.DensifyByDeviation(geometry, maxDeviationMeters)
  • ArcGIS.Core.Geometry.GeometryEngine.DensifyByLength
Dim maxSegmentLength As Double
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.DensifyByLength(geometry, maxSegmentLength)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.DensifyByLength(geometry, maxSegmentLength)
  • ArcGIS.Core.Geometry.GeometryEngine.Difference
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Difference(geometry1, geometry2)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Difference(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Disjoint
' before:
Dim result As Boolean = geometryengine.Disjoint(geometry1, geometry2)
' now:
Dim result As Boolean = GeometryEngine.Instance.Disjoint(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Disjoint3D
' before:
Dim result As Boolean = geometryengine.Disjoint3D(geometry1, geometry2)
' now:
Dim result As Boolean = GeometryEngine.Instance.Disjoint3D(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Distance
' before:
Dim result As Double = geometryengine.Distance(geometry1, geometry2)
' now:
Dim result As Double = GeometryEngine.Instance.Distance(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Distance3D
' before:
Dim result As Double = geometryengine.Distance3D(geometry1, geometry2)
' now:
Dim result As Double = GeometryEngine.Instance.Distance3D(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Equals
' before:
Dim result As Boolean = geometryengine.Equals(geometry1, geometry2)
' now:
Dim result As Boolean = GeometryEngine.Instance.Equals(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Expand
Dim dx As Double
Dim dy As Double
Dim dz As Double
Dim asRatio As Boolean
' before:
Dim result As ArcGIS.Core.Geometry.Envelope = geometryengine.Expand(envelope, dx, dy, dz, asRatio)
Dim result As ArcGIS.Core.Geometry.Envelope = geometryengine.Expand(envelope, dx, dy, asRatio)
' now:
Dim result As ArcGIS.Core.Geometry.Envelope = GeometryEngine.Instance.Expand(envelope, dx, dy, dz, asRatio)
Dim result As ArcGIS.Core.Geometry.Envelope = GeometryEngine.Instance.Expand(envelope, dx, dy, asRatio)
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToEsriShape
Dim exportFlags As ArcGIS.Core.Geometry.EsriShapeExportFlags
Dim buffer As System.Byte()
' before:
Dim result As Integer = geometryengine.ExportToEsriShape(exportFlags, geometry, buffer)
Dim result As System.Byte() = geometryengine.ExportToEsriShape(exportFlags, geometry)
' now:
Dim result As Integer = GeometryEngine.Instance.ExportToEsriShape(exportFlags, geometry, buffer)
Dim result As System.Byte() = GeometryEngine.Instance.ExportToEsriShape(exportFlags, geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToJSON
Dim exportFlags As ArcGIS.Core.Geometry.JSONExportFlags
' before:
Dim result As String = geometryengine.ExportToJSON(exportFlags, geometry)
' now:
Dim result As String = GeometryEngine.Instance.ExportToJSON(exportFlags, geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToWKB
Dim exportFlags As ArcGIS.Core.Geometry.WKBExportFlags
' before:
Dim result As Integer = geometryengine.ExportToWKB(exportFlags, geometry, buffer)
Dim result As System.Byte() = geometryengine.ExportToWKB(exportFlags, geometry)
' now:
Dim result As Integer = GeometryEngine.Instance.ExportToWKB(exportFlags, geometry, buffer)
Dim result As System.Byte() = GeometryEngine.Instance.ExportToWKB(exportFlags, geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToWKT
Dim exportFlags As ArcGIS.Core.Geometry.WKTExportFlags
' before:
Dim result As String = geometryengine.ExportToWKT(exportFlags, geometry)
' now:
Dim result As String = GeometryEngine.Instance.ExportToWKT(exportFlags, geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Extend
Dim polyline As ArcGIS.Core.Geometry.Polyline
Dim extender As ArcGIS.Core.Geometry.Polyline
Dim ExtendFlags As ArcGIS.Core.Geometry.ExtendFlags
' before:
Dim result As ArcGIS.Core.Geometry.Polyline = geometryengine.Extend(polyline, extender, ExtendFlags)
' now:
Dim result As ArcGIS.Core.Geometry.Polyline = GeometryEngine.Instance.Extend(polyline, extender, ExtendFlags)
  • ArcGIS.Core.Geometry.GeometryEngine.Generalize
Dim maxDeviation As Double
' before:
Dim removeDegenerateParts As Boolean = [False]
Dim preserveCurves As Boolean = [False]
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Generalize(geometry, maxDeviation, [False], [False])
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Generalize(geometry, maxDeviation, removeDegenerateParts, preserveCurves)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicArea
' before:
Dim result As Double = geometryengine.GeodesicArea(geometry)
' now:
Dim result As Double = GeometryEngine.Instance.GeodesicArea(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicBuffer
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.GeodesicBuffer(geometries, distance)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.GeodesicBuffer(geometry, distance)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.GeodesicBuffer(geometries, distance)
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.GeodesicBuffer(geometry, distance)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicDistance
' before:
Dim result As Double = geometryengine.GeodesicDistance(geometry1, geometry2)
' now:
Dim result As Double = GeometryEngine.Instance.GeodesicDistance(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicEllipse
Dim parameter As ArcGIS.Core.Geometry.GeodesicEllipseParameter
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.GeodesicEllipse(parameter, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.GeodesicEllipse(parameter, spatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicLength
' before:
Dim result As Double = geometryengine.GeodesicLength(geometry)
' now:
Dim result As Double = GeometryEngine.Instance.GeodesicLength(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicSector
Dim parameter As ArcGIS.Core.Geometry.GeodesicSectorParameter
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.GeodesicSector(parameter, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.GeodesicSector(parameter, spatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodeticDensifyByDeviation
Dim deviationUnit As ArcGIS.Core.Geometry.LinearUnit
' before:
Dim curveType As ArcGIS.Core.Geometry.CurveType
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.GeodeticDensifyByDeviation(geometry, maxDeviation, deviationUnit, curveType)
' now:
Dim curveType As ArcGIS.Core.Geometry.GeodeticCurveType
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.GeodeticDensifyByDeviation(geometry, maxDeviation, deviationUnit, curveType)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodeticDensifyByLength
Dim lengthUnit As ArcGIS.Core.Geometry.LinearUnit
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.GeodeticDensifyByLength(geometry, maxSegmentLength, lengthUnit, curveType)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.GeodeticDensifyByLength(geometry, maxSegmentLength, lengthUnit, curveType)
  • ArcGIS.Core.Geometry.GeometryEngine.GeodeticMove
Dim points As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.MapPoint)
Dim unit As ArcGIS.Core.Geometry.LinearUnit
Dim azimuth As Double
' before:
Dim result As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.MapPoint) = geometryengine.GeodeticMove(points, spatialReference, distance, unit, azimuth, curveType)
' now:
Dim result As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.MapPoint) = GeometryEngine.Instance.GeodeticMove(points, spatialReference, distance, unit, azimuth, curveType)
  • ArcGIS.Core.Geometry.GeometryEngine.GetEsriShapeSize
' before:
Dim result As Integer = geometryengine.GetEsriShapeSize(exportFlags, geometry)
' now:
Dim result As Integer = GeometryEngine.Instance.GetEsriShapeSize(exportFlags, geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.GetPredefinedCoordinateSystemList
Dim filter As ArcGIS.Core.Geometry.CoordinateSystemFilter
' before:
Dim result As System.Collections.Generic.IReadOnlyList(Of ArcGIS.Core.Geometry.CoordinateSystemListEntry) = geometryengine.GetPredefinedCoordinateSystemList(filter)
' now:
Dim result As System.Collections.Generic.IReadOnlyList(Of ArcGIS.Core.Geometry.CoordinateSystemListEntry) = GeometryEngine.Instance.GetPredefinedCoordinateSystemList(filter)
  • ArcGIS.Core.Geometry.GeometryEngine.GetSubCurve
Dim fromDistance As Double
Dim toDistance As Double
Dim asRatioOrLength As ArcGIS.Core.Geometry.AsRatioOrLength
' before:
Dim result As ArcGIS.Core.Geometry.Polyline = geometryengine.GetSubCurve(multipart, fromDistance, toDistance, asRatioOrLength)
' now:
Dim result As ArcGIS.Core.Geometry.Polyline = GeometryEngine.Instance.GetSubCurve(multipart, fromDistance, toDistance, asRatioOrLength)
  • ArcGIS.Core.Geometry.GeometryEngine.GetSubCurve3D
' before:
Dim result As ArcGIS.Core.Geometry.Polyline = geometryengine.GetSubCurve3D(multipart, fromDistance, toDistance, asRatioOrLength)
' now:
Dim result As ArcGIS.Core.Geometry.Polyline = GeometryEngine.Instance.GetSubCurve3D(multipart, fromDistance, toDistance, asRatioOrLength)
  • ArcGIS.Core.Geometry.GeometryEngine.GetWKBSize
' before:
Dim result As Integer = geometryengine.GetWKBSize(exportFlags, geometry)
' now:
Dim result As Integer = GeometryEngine.Instance.GetWKBSize(exportFlags, geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromEsriShape
Dim importFlags As ArcGIS.Core.Geometry.EsriShapeImportFlags
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.ImportFromEsriShape(importFlags, buffer, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.ImportFromEsriShape(importFlags, buffer, spatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromJSON
Dim importFlags As ArcGIS.Core.Geometry.JSONImportFlags
Dim jsonString As String
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.ImportFromJSON(importFlags, jsonString)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.ImportFromJSON(importFlags, jsonString)
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromWKB
Dim importFlags As ArcGIS.Core.Geometry.WKBImportFlags
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.ImportFromWKB(importFlags, buffer, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.ImportFromWKB(importFlags, buffer, spatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromWKT
Dim importFlags As ArcGIS.Core.Geometry.WKTImportFlags
Dim wktString As String
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.ImportFromWKT(importFlags, wktString, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.ImportFromWKT(importFlags, wktString, spatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.Intersection
Dim resultDimension As ArcGIS.Core.Geometry.GeometryDimension
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Intersection(geometry1, geometry2, resultDimension)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Intersection(geometry1, geometry2)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Intersection(geometry1, geometry2, resultDimension)
Dim result As ArcGIS.Core.Geometry.Geometry = GeometryEngine.Instance.Intersection(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Intersects
' before:
Dim result As Boolean = geometryengine.Intersects(geometry1, geometry2)
' now:
Dim result As Boolean = GeometryEngine.Instance.Intersects(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.IsSimpleAsFeature
' before:
Dim forceIsSimple As Boolean = [False]
Dim result As Boolean = geometryengine.IsSimpleAsFeature(geometry, [False])
' now:
Dim result As Boolean = GeometryEngine.Instance.IsSimpleAsFeature(geometry, forceIsSimple)
  • ArcGIS.Core.Geometry.GeometryEngine.LabelPoint
' before:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryengine.LabelPoint(geometry)
' now:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryEngine.Instance.LabelPoint(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Length
' before:
Dim result As Double = geometryengine.Length(geometry)
' now:
Dim result As Double = geometryEngine.Instance.Length(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Length3D
' before:
Dim result As Double = geometryengine.Length3D(geometry)
' now:
Dim result As Double = geometryEngine.Instance.Length3D(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Move
Dim dx As Double
Dim dy As Double
Dim dz As Double
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Move(geometry, dx, dy)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Move(geometry, dx, dy, dz)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Move(geometry, dx, dy)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Move(geometry, dx, dy, dz)
  • ArcGIS.Core.Geometry.GeometryEngine.MovePointAlongLine
Dim distanceAlong As Double
Dim offset As Double
Dim extension As ArcGIS.Core.Geometry.SegmentExtension
' before:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryengine.MovePointAlongLine(multipart, distanceAlong, asRatio, offset, extension)
' now:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryEngine.Instance.MovePointAlongLine(multipart, distanceAlong, asRatio, offset, extension)
  • ArcGIS.Core.Geometry.GeometryEngine.NearestPoint
Dim point As ArcGIS.Core.Geometry.MapPoint
' before:
Dim result As ArcGIS.Core.Geometry.ProximityResult = geometryengine.NearestPoint(geometry, point)
' now:
Dim result As ArcGIS.Core.Geometry.ProximityResult = geometryEngine.Instance.NearestPoint(geometry, point)
  • ArcGIS.Core.Geometry.GeometryEngine.NearestPoint3D
' before:
Dim result As ArcGIS.Core.Geometry.ProximityResult = geometryengine.NearestPoint3D(geometry, point)
' now:
Dim result As ArcGIS.Core.Geometry.ProximityResult = geometryEngine.Instance.NearestPoint3D(geometry, point)
  • ArcGIS.Core.Geometry.GeometryEngine.NearestVertex
' before:
Dim result As ArcGIS.Core.Geometry.ProximityResult = geometryengine.NearestVertex(geometry, point)
' now:
Dim result As ArcGIS.Core.Geometry.ProximityResult = geometryEngine.Instance.NearestVertex(geometry, point)
  • ArcGIS.Core.Geometry.GeometryEngine.NormalizeCentralMeridian
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.NormalizeCentralMeridian(geometry)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.NormalizeCentralMeridian(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.Offset
Dim offsetType As ArcGIS.Core.Geometry.OffsetType
Dim bevelRatio As Double
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Offset(geometry, distance, offsetType, bevelRatio)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Offset(geometry, distance, offsetType, bevelRatio)
  • ArcGIS.Core.Geometry.GeometryEngine.Overlaps
' before:
Dim result As Boolean = geometryengine.Overlaps(geometry1, geometry2)
' now:
Dim result As Boolean = geometryEngine.Instance.Overlaps(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Project
Dim outputSpatialReference As ArcGIS.Core.Geometry.SpatialReference
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Project(geometry, outputSpatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Project(geometry, outputSpatialReference)
  • ArcGIS.Core.Geometry.GeometryEngine.ProjectEx
Dim projTransformation As ArcGIS.Core.Geometry.ProjectionTransformation
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.ProjectEx(geometry, projTransformation)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.ProjectEx(geometry, projTransformation)
  • ArcGIS.Core.Geometry.GeometryEngine.QueryPointAndDistance
Dim inPoint As ArcGIS.Core.Geometry.MapPoint
Dim distanceAlongCurve As System.Double
Dim distanceFromCurve As System.Double
Dim whichSide As ArcGIS.Core.Geometry.LeftOrRightSide
' before:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryengine.QueryPointAndDistance(multipart, extension, inPoint, asRatioOrLength, distanceAlongCurve, distanceFromCurve,
whichSide)
' now:
Dim result As ArcGIS.Core.Geometry.MapPoint = geometryEngine.Instance.QueryPointAndDistance(multipart, extension, inPoint, asRatioOrLength, distanceAlongCurve, distanceFromCurve,
whichSide)
  • ArcGIS.Core.Geometry.GeometryEngine.Relate
Dim relateString As String
' before:
Dim result As Boolean = geometryengine.Relate(geometry1, geometry2, relateString)
' now:
Dim result As Boolean = geometryEngine.Instance.Relate(geometry1, geometry2, relateString)
  • ArcGIS.Core.Geometry.GeometryEngine.ReplaceNaNZs
Dim zValue As Double
' before:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryengine.ReplaceNaNZs(multipart, zValue)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.ReplaceNaNZs(geometry, zValue)
  • ArcGIS.Core.Geometry.GeometryEngine.Reshape
Dim reshaper As ArcGIS.Core.Geometry.Polyline
' before:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryengine.Reshape(multipart, reshaper)
' now:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryEngine.Instance.Reshape(multipart, reshaper)
  • ArcGIS.Core.Geometry.GeometryEngine.ReverseOrientation
' before:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryengine.ReverseOrientation(multipart)
' now:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryEngine.Instance.ReverseOrientation(multipart)
  • ArcGIS.Core.Geometry.GeometryEngine.Rotate
Dim origin As ArcGIS.Core.Geometry.MapPoint
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Rotate(geometry, origin, rotationAngle)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Rotate(geometry, origin, rotationAngle)
  • ArcGIS.Core.Geometry.GeometryEngine.Scale
Dim sx As Double
Dim sy As Double
Dim sz As Double
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Scale(geometry, origin, sx, sy, sz)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Scale(geometry, origin, sx, sy)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Scale(geometry, origin, sx, sy, sz)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Scale(geometry, origin, sx, sy)
  • ArcGIS.Core.Geometry.GeometryEngine.SetConstantZ
' before:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryengine.SetConstantZ(multipart, zValue)
' now:
Dim result As ArcGIS.Core.Geometry.Multipart = geometryEngine.Instance.SetConstantZ(multipart, zValue)
  • ArcGIS.Core.Geometry.GeometryEngine.ShapePreservingArea
' before:
Dim result As Double = geometryengine.ShapePreservingArea(geometry)
' now:
Dim result As Double = geometryEngine.Instance.ShapePreservingArea(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.ShapePreservingLength
' before:
Dim result As Double = geometryengine.ShapePreservingLength(geometry)
' now:
Dim result As Double = geometryEngine.Instance.ShapePreservingLength(geometry)
  • ArcGIS.Core.Geometry.GeometryEngine.SimplifyAsFeature
' before:
Dim forceSimplify As Boolean = [False]
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.SimplifyAsFeature(geometry, [False])
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.SimplifyAsFeature(geometry, forceSimplify)
  • ArcGIS.Core.Geometry.GeometryEngine.SimplifyPolyline
Dim simplifyType As ArcGIS.Core.Geometry.SimplifyType
' before:
Dim result As ArcGIS.Core.Geometry.Polyline = geometryengine.SimplifyPolyline(polyline, simplifyType, [False])
' now:
Dim result As ArcGIS.Core.Geometry.Polyline = geometryEngine.Instance.SimplifyPolyline(polyline, simplifyType, forceSimplify)
  • ArcGIS.Core.Geometry.GeometryEngine.SymmetricDifference
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.SymmetricDifference(geometry1, geometry2)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.SymmetricDifference(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Touches
' before:
Dim result As Boolean = geometryengine.Touches(geometry1, geometry2)
' now:
Dim result As Boolean = geometryEngine.Instance.Touches(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Union
' before:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Union(geometries)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryengine.Union(geometry1, geometry2)
' now:
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Union(geometries)
Dim result As ArcGIS.Core.Geometry.Geometry = geometryEngine.Instance.Union(geometry1, geometry2)
  • ArcGIS.Core.Geometry.GeometryEngine.Within
' before:
Dim result As Boolean = geometryengine.Within(geometry1, geometry2)
' now:
Dim result As Boolean = geometryEngine.Instance.Within(geometry1, geometry2)
  • ArcGIS.Core.Geometry.LineBuilder Constructor
' before:
Dim startCoord As ArcGIS.Core.Geometry.Coordinate
Dim endCoord As ArcGIS.Core.Geometry.Coordinate
Dim linebuilder = New LineBuilder(startCoord, endCoord, spatialReference)
' now:
Dim startCoord2D As ArcGIS.Core.Geometry.Coordinate2D
Dim endCoord2D As ArcGIS.Core.Geometry.Coordinate2D
Dim startCoord3D As ArcGIS.Core.Geometry.Coordinate3D
Dim endCoord3D As ArcGIS.Core.Geometry.Coordinate3D
Dim linebuilder = New LineBuilder(startCoord2D, endCoord2D, spatialReference)
Dim linebuilder = New LineBuilder(startCoord3D, endCoord3D, spatialReference)
  • ArcGIS.Core.Geometry.LineBuilder.CreateLineSegment
' before:
Dim linebuilder As ArcGIS.Core.Geometry.LineBuilder
Dim result As ArcGIS.Core.Geometry.LineSegment = linebuilder.CreateLineSegment(startCoord, endCoord, spatialReference)
' now:
Dim result As ArcGIS.Core.Geometry.LineSegment = LineBuilder.CreateLineSegment(startCoord2D, endCoord2D, spatialReference)
Dim result As ArcGIS.Core.Geometry.LineSegment = LineBuilder.CreateLineSegment(startCoord3D, endCoord3D, spatialReference)
  • ArcGIS.Core.Geometry.MapPointBuilder Constructor
Dim x As Double
Dim y As Double
Dim z As Double
Dim m As Double
' before:
Dim hasZ As Boolean = [False]
Dim coordinate As ArcGIS.Core.Geometry.Coordinate
Dim hasM As Boolean = [False]
Dim mappointbuilder = New MapPointBuilder(x, y, z, spatialReference, [False])
Dim mappointbuilder = New MapPointBuilder(coordinate, spatialReference)
Dim mappointbuilder = New MapPointBuilder()
Dim mappointbuilder = New MapPointBuilder(x, y, z, m, spatialReference, [False],
[False])
' now:
Dim coordinate3D As ArcGIS.Core.Geometry.Coordinate3D
Dim id As Integer
Dim mappointbuilder = New MapPointBuilder(x, y, z, m, spatialReference)
Dim mappointbuilder = New MapPointBuilder(coordinate3D, spatialReference)
Dim mappointbuilder = New MapPointBuilder(x, y, z, spatialReference)
Dim mappointbuilder = New MapPointBuilder(x, y, z, m, id, spatialReference)
  • ArcGIS.Core.Geometry.MapPointBuilder.CreateMapPoint
' before:
Dim coord2D As ArcGIS.Core.Geometry.Coordinate2D
Dim mappointbuilder As ArcGIS.Core.Geometry.MapPointBuilder
Dim result As ArcGIS.Core.Geometry.MapPoint = MapPointBuilder.CreateMapPoint(coord2D, spatialReference)
Dim result As ArcGIS.Core.Geometry.MapPoint = mappointbuilder.CreateMapPoint(coordinate, spatialReference)
' now:
Dim coordinate2D As ArcGIS.Core.Geometry.Coordinate2D
Dim result As ArcGIS.Core.Geometry.MapPoint = MapPointBuilder.CreateMapPoint(coordinate2D, spatialReference)
Dim result As ArcGIS.Core.Geometry.MapPoint = MapPointBuilder.CreateMapPoint(coordinate3D, spatialReference)
  • ArcGIS.Core.Geometry.MultipartBuilder.AddPart
' before:
Dim multipartbuilder As ArcGIS.Core.Geometry.MultipartBuilder(Of T)
multipartbuilder.AddPart(coordinates)
' now:
Dim coordinates As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Coordinate3D)
  • ArcGIS.Core.Geometry.MultipartBuilder.InsertPart
Dim beforePartIndex As Integer
' before:
multipartbuilder.InsertPart(beforePartIndex, coordinates)
' now:
  • ArcGIS.Core.Geometry.MultipointBuilder Constructor
' before:
Dim multipointbuilder = New MultipointBuilder(coordinates, spatialReference)
' now:
  • ArcGIS.Core.Geometry.MultipointBuilder.Add
' before:
Dim point As ArcGIS.Core.Geometry.Coordinate
Dim points As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Coordinate)
Dim multipointbuilder As ArcGIS.Core.Geometry.MultipointBuilder
multipointbuilder.Add(point)
multipointbuilder.Add(points)
' now:
Dim point3D As ArcGIS.Core.Geometry.Coordinate3D
Dim points As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.Geometry.Coordinate3D)
multipointbuilder.Add(point3D)
  • ArcGIS.Core.Geometry.MultipointBuilder.CreateMultipoint
' before:
Dim result As ArcGIS.Core.Geometry.Multipoint = multipointbuilder.CreateMultipoint(coordinates, spatialReference)
' now:
  • ArcGIS.Core.Geometry.MultipointBuilder.Insert
Dim beforePointIndex As Integer
' before:
multipointbuilder.Insert(beforePointIndex, coordinate)
multipointbuilder.Insert(beforePointIndex, coordinates)
' now:
multipointbuilder.Insert(beforePointIndex, coordinate3D)
  • ArcGIS.Core.Geometry.PolygonBuilder Constructor
' before:
Dim polygonbuilder = New PolygonBuilder(coordinates, spatialReference)
' now:
  • ArcGIS.Core.Geometry.PolygonBuilder.CreatePolygon
' before:
Dim polygonbuilder As ArcGIS.Core.Geometry.PolygonBuilder
Dim result As ArcGIS.Core.Geometry.Polygon = polygonbuilder.CreatePolygon(coordinates, spatialReference)
' now:
  • ArcGIS.Core.Geometry.PolylineBuilder Constructor
' before:
Dim polylinebuilder = New PolylineBuilder(coordinates, spatialReference)
' now:
  • ArcGIS.Core.Geometry.PolylineBuilder.CreatePolyline
' before:
Dim polylinebuilder As ArcGIS.Core.Geometry.PolylineBuilder
Dim result As ArcGIS.Core.Geometry.Polyline = polylinebuilder.CreatePolyline(coordinates, spatialReference)
' now:
ArcGIS.Desktop.Core.dll
ArcGIS.Desktop.Core
  • ArcGIS.Desktop.Core.IProjectWindow.SelectedItems
' before:
Dim iprojectwindow As ArcGIS.Desktop.Core.IProjectWindow
Dim result As System.Collections.Generic.IEnumerable(Of ArcGIS.Desktop.Core.ProjectItem) = iprojectwindow.SelectedItems
' now:
Dim result As System.Collections.Generic.IEnumerable(Of ArcGIS.Desktop.Core.Item) = iprojectwindow.SelectedItems
  • ArcGIS.Desktop.Core.Item.IsContainer
' before:
Dim item As ArcGIS.Desktop.Core.Item
Dim result As Boolean = item.IsContainer
' now:
  • ArcGIS.Desktop.Core.ItemFactory.Create
Imports itemfactory = ArcGIS.Desktop.Core.ItemFactory
Dim uri As String
Dim itemType As ArcGIS.Desktop.Core.ItemType = 0
' before:
Dim result As ArcGIS.Desktop.Core.Item = itemfactory.Create(uri, 0)
' now:
Dim result As ArcGIS.Desktop.Core.Item = ItemFactory.Instance.Create(uri, 0)
  • ArcGIS.Desktop.Core.Project.Current.AddItem
Dim addFolderPath as String;
// before:
Dim theFolderToAdd = ItemFactory.Create(addFolderPath)
Await Project.Current.AddAsync(theFolderToAdd)
// now:
Dim theFolderToAdd = ItemFactory.Instance.Create(addFolderPath)
Await QueuedTask.Run(Function() Project.Current.AddItem(TryCast(theFolderToAdd, IProjectItem)))
  • ArcGIS.Desktop.Core.Project.Current.RemoveItem
// before:
Dim folderToRemove As FolderConnectionProjectItem = Project.Current.GetItems(Of FolderConnectionProjectItem)().FirstOrDefault(Function(myfolder) myfolder.Name.Equals("PlantSpecies"))
If folderToRemove IsNot Nothing Then
	Await Project.Current.RemoveAsync(folderToRemove)
End If
// now:
    Project.Current.RemoveItem(TryCast(folderToRemove, IProjectItem))
End If
  • ArcGIS.Desktop.Core.Project.GetItems
' before:
Dim project As ArcGIS.Desktop.Core.Project
Dim result As System.Collections.Generic.IEnumerable(Of Item) = project.GetItems(Of Item)()
Dim result As System.Collections.Generic.IEnumerable(Of Item) = Await gdb.GetItemsAsync()
' now:
  • ArcGIS.Desktop.Core.Project.Items
' before:
Dim result As System.Collections.ObjectModel.ReadOnlyObservableCollection(Of ArcGIS.Desktop.Core.ProjectItem) = project.Items
' now:
Dim result As System.Collections.ObjectModel.ReadOnlyObservableCollection(Of ArcGIS.Desktop.Core.Item) = project.Items
  • ArcGIS.Desktop.Core.Project.SearchAsync
Dim _mxd As New List(Of Item)()
'Gets all the folder connections in the current project
// before:
Dim allFoldersItem = Project.Current.GetItems(Of FolderConnectionProjectItem)()
If allFoldersItem IsNot Nothing Then
	'iterate through all the FolderConnectionProjectItems found
   For Each folderItem As var In allFoldersItem
		_mxd.AddRange(Await folderItem.SearchAsync(".mxd"))
End If
// now:
_mxd.AddRange(Await Project.Current.SearchAsync(".mxd"))
ArcGIS.Desktop.Core.Events
  • ArcGIS.Desktop.Core.Events.ProjectItemsChangedEventArgs.ProjectItem
' before:
Dim projectitemschangedeventargs As ArcGIS.Desktop.Core.Events.ProjectItemsChangedEventArgs
Dim result As ArcGIS.Desktop.Core.ProjectItem = projectitemschangedeventargs.ProjectItem
' now:
Dim result As ArcGIS.Desktop.Core.Item = projectitemschangedeventargs.ProjectItem
ArcGIS.Desktop.Core.Geoprocessing
  • ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.ShowMessageBox
Dim messages As System.Collections.Generic.IEnumerable(Of ArcGIS.Desktop.Core.Geoprocessing.IGPMessage)
Dim content_header As String
Dim style As ArcGIS.Desktop.Core.Geoprocessing.GPMessageBoxStyle
Dim window_title As String
Dim icon_source As String
' before:
Dim geoprocessing As ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing
geoprocessing.ShowMessageBox(messages, content_header, style, window_title, icon_source)
' now:
Dim parentViewModel As ArcGIS.Desktop.Framework.Contracts.ViewModelBase
geoprocessing.ShowMessageBox(messages, content_header, style, window_title, icon_source, parentViewModel)
ArcGIS.Desktop.Editing.dll
  • ArcGIS.Desktop.Editing.EditOperation.Planarize
Dim sourceLayer As ArcGIS.Desktop.Mapping.Layer
Dim sourceOIDs As System.Collections.Generic.IEnumerable(Of Long)
' before:
Dim clusterTolerance As Double
Dim editoperation As ArcGIS.Desktop.Editing.EditOperation
editoperation.Planarize(sourceLayer, sourceOIDs, clusterTolerance)
' now:
Dim clusterTolerance As System.Nullable(Of Double)
ArcGIS.Desktop.Editing.Attributes
  • ArcGIS.Desktop.Editing.Attributes.Attribute.SetOriginalValue
Dim value As Object
' before:
Dim attribute As ArcGIS.Desktop.Editing.Attributes.Attribute
attribute.SetOriginalValue(value)
' now:
Dim didEditFail As Boolean = [False]
attribute.SetOriginalValue(value, [False])
ArcGIS.Desktop.Editing.Events
  • ArcGIS.Desktop.Editing.Events.TopologyEventArgs Constructor
Dim newUseTopology As System.Tuple(Of stringbooldouble)
Dim oldUseTopology As System.Tuple(Of stringbooldouble)
' before:
Dim topologyeventargs = New TopologyEventArgs(newUseTopology, oldUseTopology)
' now:
Dim map As ArcGIS.Desktop.Mapping.Map
Dim topologyeventargs = New TopologyEventArgs(map, newUseTopology, oldUseTopology)
ArcGIS.Desktop.Framework.dll
ArcGIS.Desktop.Framework.Controls
  • ArcGIS.Desktop.Framework.Controls.EmbeddableControl Constructor
Dim options As System.Xml.Linq.XElement
' before:
Dim embeddablecontrol = New EmbeddableControl(options)
' now:
Dim canChangeOptions As Boolean
Dim embeddablecontrol = New EmbeddableControl(options, canChangeOptions)
  • ArcGIS.Desktop.Framework.Controls.EmbeddableControl.Create
Dim damlID As String
' before:
Dim embeddablecontrol As ArcGIS.Desktop.Framework.Controls.EmbeddableControl
Dim result As System.Tuple(Of ArcGIS.Desktop.Framework.Controls.EmbeddableControl, System.Windows.Controls.UserControl) = embeddablecontrol.Create(damlID, options)
' now:
Dim result As System.Tuple(Of ArcGIS.Desktop.Framework.Controls.EmbeddableControl, System.Windows.Controls.UserControl) = EmbeddableControl.Create(damlID)
ArcGIS.Desktop.Layouts.dll
  • ArcGIS.Desktop.Layouts.GroupElement.Elements
' before:
Dim groupelement As ArcGIS.Desktop.Layouts.GroupElement
Dim result As System.Collections.ObjectModel.ObservableCollection(Of ArcGIS.Desktop.Layouts.Element) = groupelement.Elements
' now:
Dim result As System.Collections.ObjectModel.ReadOnlyObservableCollection(Of ArcGIS.Desktop.Layouts.Element) = groupelement.Elements
  • ArcGIS.Desktop.Layouts.TextProperties Constructor
Dim text As String
Dim font As String
Dim fontSize As Double
' before:
Dim textproperties = New TextProperties(text, font, fontSize)
' now:
Dim fontStyle As String
Dim textproperties = New TextProperties(text, font, fontSize, fontStyle)
ArcGIS.Desktop.Mapping.dll
  • ArcGIS.Desktop.Mapping.ColorFactory.BlackRGB
Imports colorfactory = ArcGIS.Desktop.Mapping.ColorFactory
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.BlackRGB
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.BlackRGB
  • ArcGIS.Desktop.Mapping.ColorFactory.BlueRGB
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.BlueRGB
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.BlueRGB
  • ArcGIS.Desktop.Mapping.ColorFactory.CreateColor
Dim color As System.Drawing.Color
Dim color As System.Windows.Media.Color
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.CreateColor(color)
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.CreateColor(color)
  • ArcGIS.Desktop.Mapping.ColorFactory.CreateRGBColor
' before:
Dim R As System.Single
Dim G As System.Single
Dim B As System.Single
Dim A As System.Single = 100
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.CreateRGBColor(R, G, B, 100)
' now:
Dim R As Double
Dim G As Double
Dim B As Double
Dim A As Double = 100
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.CreateRGBColor(R, G, B, 100)
  • ArcGIS.Desktop.Mapping.ColorFactory.GreenRGB
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.GreenRGB
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.GreenRGB
  • ArcGIS.Desktop.Mapping.ColorFactory.GreyRGB
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.GreyRGB
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.GreyRGB
  • ArcGIS.Desktop.Mapping.ColorFactory.RedRGB
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.RedRGB
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.RedRGB
  • ArcGIS.Desktop.Mapping.ColorFactory.WhiteRGB
' before:
Dim result As ArcGIS.Core.CIM.CIMColor = colorfactory.WhiteRGB
' now:
Dim result As ArcGIS.Core.CIM.CIMColor = ColorFactory.Instance.WhiteRGB
  • ArcGIS.Desktop.Mapping.LayerFactory.CanCreateLayerFrom
Imports layerfactory = ArcGIS.Desktop.Mapping.LayerFactory
' before:
Dim result As Boolean = layerfactory.CanCreateLayerFrom(item)
' now:
Dim result As Boolean = LayerFactory.Instance.CanCreateLayerFrom(item)
  • ArcGIS.Desktop.Mapping.LayerFactory.CreateFeatureLayer
Dim dataUri As System.Uri
Dim mapOrGroupLayer As ArcGIS.Desktop.Mapping.ILayerContainerEdit
Dim position As ArcGIS.Desktop.Mapping.LayerPosition = 0
Dim layerName As String = ""
Dim rendererDefinition As ArcGIS.Desktop.Mapping.RendererDefinition
Dim index As Integer
Dim dataConnection As ArcGIS.Core.CIM.CIMDataConnection
Dim featureClass As ArcGIS.Core.Data.FeatureClass
' before:
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(dataUri, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(dataUri, mapOrGroupLayer, index, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(dataConnection, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(dataConnection, mapOrGroupLayer, index, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(featureClass, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(featureClass, mapOrGroupLayer, index, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(item, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = layerfactory.CreateFeatureLayer(item, mapOrGroupLayer, index, "", rendererDefinition)
' now:
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(dataUri, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(dataUri, mapOrGroupLayer, index, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(dataConnection, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(dataConnection, mapOrGroupLayer, index, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(featureClass, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(featureClass, mapOrGroupLayer, index, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(item, mapOrGroupLayer, 0, "", rendererDefinition)
Dim result As ArcGIS.Desktop.Mapping.FeatureLayer = LayerFactory.Instance.CreateFeatureLayer(item, mapOrGroupLayer, index, "", rendererDefinition)
  • ArcGIS.Desktop.Mapping.LayerFactory.CreateGroupLayer
Dim container As ArcGIS.Desktop.Mapping.ILayerContainerEdit
' before:
Dim result As ArcGIS.Desktop.Mapping.GroupLayer = layerfactory.CreateGroupLayer(container, index, "")
' now:
Dim result As ArcGIS.Desktop.Mapping.GroupLayer = LayerFactory.Instance.CreateGroupLayer(container, index, "")
  • ArcGIS.Desktop.Mapping.LayerFactory.CreateLayer
' before:
Dim result As ArcGIS.Desktop.Mapping.Layer = layerfactory.CreateLayer(dataUri, mapOrGroupLayer, 0, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = layerfactory.CreateLayer(dataConnection, mapOrGroupLayer, index, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = layerfactory.CreateLayer(dataConnection, mapOrGroupLayer, 0, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = layerfactory.CreateLayer(item, mapOrGroupLayer, index, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = layerfactory.CreateLayer(item, mapOrGroupLayer, 0, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = layerfactory.CreateLayer(dataUri, mapOrGroupLayer, index, "")
' now:
Dim result As ArcGIS.Desktop.Mapping.Layer = LayerFactory.Instance.CreateLayer(dataUri, mapOrGroupLayer, 0, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = LayerFactory.Instance.CreateLayer(dataConnection, mapOrGroupLayer, index, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = LayerFactory.Instance.CreateLayer(dataConnection, mapOrGroupLayer, 0, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = LayerFactory.Instance.CreateLayer(item, mapOrGroupLayer, index, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = LayerFactory.Instance.CreateLayer(item, mapOrGroupLayer, 0, "")
Dim result As ArcGIS.Desktop.Mapping.Layer = LayerFactory.Instance.CreateLayer(dataUri, mapOrGroupLayer, index, "")
  • ArcGIS.Desktop.Mapping.MapFactory.CanCreateMapFrom
Imports mapfactory = ArcGIS.Desktop.Mapping.MapFactory
' before:
Dim result As Boolean = mapfactory.CanCreateMapFrom(item)
' now:
Dim result As Boolean = MapFactory.Instance.CanCreateMapFrom(item)
  • ArcGIS.Desktop.Mapping.MapFactory.CreateMap
Dim name As String
Dim mapType As ArcGIS.Core.CIM.MapType = 0
Dim defaultViewingMode As ArcGIS.Core.CIM.MapViewingMode = 0
Dim basemap As ArcGIS.Desktop.Mapping.Basemap = 1
' before:
Dim result As ArcGIS.Desktop.Mapping.Map = mapfactory.CreateMap(name, 0, 0, 1)
' now:
Dim result As ArcGIS.Desktop.Mapping.Map = MapFactory.Instance.CreateMap(name, 0, 0, 1)
  • ArcGIS.Desktop.Mapping.StandaloneTableFactory.CanCreateStandaloneTableFrom
Imports standalonetablefactory = ArcGIS.Desktop.Mapping.StandaloneTableFactory
' before:
Dim result As Boolean = standalonetablefactory.CanCreateStandaloneTableFrom(item)
' now:
Dim result As Boolean = StandaloneTableFactory.Instance.CanCreateStandaloneTableFrom(item)
  • ArcGIS.Desktop.Mapping.StandaloneTableFactory.CreateStandaloneTable
Dim container As ArcGIS.Desktop.Mapping.IStandaloneTableContainerEdit
Dim tableName As String = ""
Dim table As ArcGIS.Core.Data.Table
Dim tableUri As System.Uri
' before:
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = standalonetablefactory.CreateStandaloneTable(dataConnection, container, "")
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = standalonetablefactory.CreateStandaloneTable(table, container, "")
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = standalonetablefactory.CreateStandaloneTable(item, container, "")
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = standalonetablefactory.CreateStandaloneTable(tableUri, container, "")
' now:
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = StandaloneTableFactory.Instance.CreateStandaloneTable(dataConnection, container, "")
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = StandaloneTableFactory.Instance.CreateStandaloneTable(table, container, "")
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = StandaloneTableFactory.Instance.CreateStandaloneTable(item, container, "")
Dim result As ArcGIS.Desktop.Mapping.StandaloneTable = StandaloneTableFactory.Instance.CreateStandaloneTable(tableUri, container, "")
  • ArcGIS.Desktop.Mapping.StyleHelper.AddStyle
Dim customStyleToAdd As String = "C:\Temp\CustomStyle.stylx"
// before:
Await Project.Current.AddStyleAsync(customStyleToAdd)
// now:
Await QueuedTask.Run(Sub() StyleHelper.AddStyle(Project.Current, customStyleToAdd))
  • ArcGIS.Desktop.Mapping.StyleHelper.CreateStyle
Dim styleToCreate As String = "C:\Temp\CustomStyle.stylx"
// before:
Await Project.Current.AddStyleAsync(styleToCreate)
// now:
Await QueuedTask.Run(Sub() StyleHelper.AddStyle(Project.Current, styleToCreate))
  • ArcGIS.Desktop.Mapping.StyleHelper.RemoveStyle
// before:
Await Project.Current.RemoveStyleAsync("3D Vehicles")
// now:
Await QueuedTask.Run(Sub() StyleHelper.RemoveStyle(Project.Current, "3D Vehicles"))
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructFill
Imports symbolfactory = ArcGIS.Desktop.Mapping.SymbolFactory
' before:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolfactory.ConstructFill()
' now:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolFactory.Instance.ConstructFill()
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructHatchFill
Dim color As ArcGIS.Core.CIM.CIMColor
Dim angle As Double
Dim separation As Double
' before:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolfactory.ConstructHatchFill(color, angle, separation)
' now:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolFactory.Instance.ConstructHatchFill(color, angle, separation)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructLineSymbol
Dim width As Double
Dim lineStyle As ArcGIS.Desktop.Mapping.SimpleLineStyle
Dim stroke As ArcGIS.Core.CIM.CIMStroke
' before:
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolfactory.ConstructLineSymbol(color, width, lineStyle)
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolfactory.ConstructLineSymbol(stroke)
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolfactory.ConstructLineSymbol(color, width)
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolfactory.ConstructLineSymbol()
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolfactory.ConstructLineSymbol(color)
' now:
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolFactory.Instance.ConstructLineSymbol(color, width, lineStyle)
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolFactory.Instance.ConstructLineSymbol(stroke)
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolFactory.Instance.ConstructLineSymbol(color, width)
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolFactory.Instance.ConstructLineSymbol()
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolFactory.Instance.ConstructLineSymbol(color)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarker
Dim characterIndex As Integer
Dim fontFamily As String
Dim size As Integer
Dim size As Double
Dim markerStyle As ArcGIS.Desktop.Mapping.SimpleMarkerStyle
' before:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(characterIndex, fontFamily, fontStyle)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(characterIndex, fontFamily)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(characterIndex, fontFamily, fontStyle, size, color)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(characterIndex, fontFamily, fontStyle, size)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(color)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker()
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(color, size, markerStyle)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarker(color, size)
' now:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(characterIndex, fontFamily, fontStyle)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(characterIndex, fontFamily)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(characterIndex, fontFamily, fontStyle, size, color)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(characterIndex, fontFamily, fontStyle, size)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(color)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker()
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(color, size, markerStyle)
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarker(color, size)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarkerFromBitmapSource
Dim bitmapSource As System.Windows.Media.Imaging.BitmapSource
' before:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarkerFromBitmapSource(bitmapSource)
' now:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarkerFromBitmapSource(bitmapSource)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarkerFromStream
Dim stream As System.IO.Stream
' before:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.ConstructMarkerFromStream(stream)
' now:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.ConstructMarkerFromStream(stream)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructPointSymbol
Dim size As Double
Dim style As ArcGIS.Desktop.Mapping.SimpleMarkerStyle
Dim marker As ArcGIS.Core.CIM.CIMMarker
' before:
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolfactory.ConstructPointSymbol(color, size, style)
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolfactory.ConstructPointSymbol(marker)
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolfactory.ConstructPointSymbol(color, size)
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolfactory.ConstructPointSymbol()
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolfactory.ConstructPointSymbol(color)
' now:
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolFactory.Instance.ConstructPointSymbol(color, size, style)
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolFactory.Instance.ConstructPointSymbol(marker)
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolFactory.Instance.ConstructPointSymbol(color, size)
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolFactory.Instance.ConstructPointSymbol()
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolFactory.Instance.ConstructPointSymbol(color)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructPolygonSymbol
Dim fillStyle As ArcGIS.Desktop.Mapping.SimpleFillStyle
Dim outline As ArcGIS.Core.CIM.CIMStroke
Dim fill As ArcGIS.Core.CIM.CIMFill
' before:
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolfactory.ConstructPolygonSymbol(color, fillStyle, outline)
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolfactory.ConstructPolygonSymbol(fill, outline)
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolfactory.ConstructPolygonSymbol(color, fillStyle)
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolfactory.ConstructPolygonSymbol()
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolfactory.ConstructPolygonSymbol(color)
' now:
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolFactory.Instance.ConstructPolygonSymbol(color, fillStyle, outline)
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolFactory.Instance.ConstructPolygonSymbol(fill, outline)
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolFactory.Instance.ConstructPolygonSymbol(color, fillStyle)
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolFactory.Instance.ConstructPolygonSymbol()
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolFactory.Instance.ConstructPolygonSymbol(color)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructProceduralSymbol
Dim rulePackagePath As String
Dim featureLayer As ArcGIS.Desktop.Mapping.FeatureLayer
Dim [overrides] As System.Collections.Generic.IEnumerable(Of ArcGIS.Core.CIM.CIMPrimitiveOverride)
' before:
Dim result As ArcGIS.Core.CIM.CIMSymbolReference = symbolfactory.ConstructProceduralSymbol(rulePackagePath, featureLayer, [overrides])
' now:
Dim result As ArcGIS.Core.CIM.CIMSymbolReference = symbolfactory.Instance.ConstructProceduralSymbol(rulePackagePath, featureLayer, [overrides])
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructSolidFill
' before:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolfactory.ConstructSolidFill(color)
' now:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolFactory.Instance.ConstructSolidFill(color)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructStroke
Dim width As Double
' before:
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolfactory.ConstructStroke(color, width)
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolfactory.ConstructStroke(color, width, lineStyle)
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolfactory.ConstructStroke()
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolfactory.ConstructStroke(color)
' now:
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolFactory.Instance.ConstructStroke(color, width)
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolFactory.Instance.ConstructStroke(color, width, lineStyle)
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolFactory.Instance.ConstructStroke()
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolFactory.Instance.ConstructStroke(color)
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructTextSymbol
Dim size As Double
Dim fontFamilyName As String
Dim fontStyleName As String
Dim symbol As ArcGIS.Core.CIM.CIMPolygonSymbol
' before:
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolfactory.ConstructTextSymbol(color)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolfactory.ConstructTextSymbol(color, size, fontFamilyName, fontStyleName)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolfactory.ConstructTextSymbol(symbol, size, fontFamilyName, fontStyleName)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolfactory.ConstructTextSymbol()
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolfactory.ConstructTextSymbol(size)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolfactory.ConstructTextSymbol(color, size)
' now:
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolFactory.Instance.ConstructTextSymbol(color)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolFactory.Instance.ConstructTextSymbol(color, size, fontFamilyName, fontStyleName)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolFactory.Instance.ConstructTextSymbol(symbol, size, fontFamilyName, fontStyleName)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolFactory.Instance.ConstructTextSymbol()
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolFactory.Instance.ConstructTextSymbol(size)
Dim result As ArcGIS.Core.CIM.CIMTextSymbol = symbolFactory.Instance.ConstructTextSymbol(color, size)
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultFill
' before:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolfactory.DefaultFill
' now:
Dim result As ArcGIS.Core.CIM.CIMFill = symbolFactory.Instance.DefaultFill
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultLineSymbol
' before:
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolfactory.DefaultLineSymbol
' now:
Dim result As ArcGIS.Core.CIM.CIMLineSymbol = symbolFactory.Instance.DefaultLineSymbol
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultMarker
' before:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolfactory.DefaultMarker
' now:
Dim result As ArcGIS.Core.CIM.CIMMarker = symbolFactory.Instance.DefaultMarker
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultPointSymbol
' before:
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolfactory.DefaultPointSymbol
' now:
Dim result As ArcGIS.Core.CIM.CIMPointSymbol = symbolFactory.Instance.DefaultPointSymbol
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultPolygonSymbol
' before:
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolfactory.DefaultPolygonSymbol
' now:
Dim result As ArcGIS.Core.CIM.CIMPolygonSymbol = symbolFactory.Instance.DefaultPolygonSymbol
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultStroke
' before:
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolfactory.DefaultStroke
' now:
Dim result As ArcGIS.Core.CIM.CIMStroke = symbolFactory.Instance.DefaultStroke
  • ArcGIS.Desktop.Mapping.SymbolFactory.GetDictionarySymbol
Dim dictionaryName As String
Dim values As System.Collections.Generic.Dictionary(Of stringobject)
' before:
Dim result As ArcGIS.Core.CIM.CIMSymbol = symbolfactory.GetDictionarySymbol(dictionaryName, values)
' now:
Dim result As ArcGIS.Core.CIM.CIMSymbol = symbolFactory.Instance.GetDictionarySymbol(dictionaryName, values)
ArcGIS.Desktop.TaskAssistant.dll
  • ArcGIS.Desktop.TaskAssistant.TaskAssistantModule.CloseTaskAsync
' before:
Dim taskGuid As System.Guid
Dim taskassistantmodule As ArcGIS.Desktop.TaskAssistant.TaskAssistantModule
Dim result As System.Threading.Tasks.Task = TaskAssistantModule.CloseTaskAsync(taskGuid)
' now:
Dim taskItemGuid As System.Guid
Dim result As System.Threading.Tasks.Task = TaskAssistantModule.CloseTaskAsync(taskItemGuid)
  • ArcGIS.Desktop.TaskAssistant.TaskAssistantModule.ExportTaskAsync
Dim path As String
' before:
Dim result As System.Threading.Tasks.Task(Of String) = TaskAssistantModule.ExportTaskAsync(taskGuid, path)
' now:
Dim result As System.Threading.Tasks.Task(Of String) = TaskAssistantModule.ExportTaskAsync(taskItemGuid, path)
  • ArcGIS.Desktop.TaskAssistant.TaskAssistantModule.OpenTaskItemAsync
' before:
Dim result As System.Threading.Tasks.Task(Of System.Guid) = TaskAssistantModule.OpenTaskItemAsync(taskGuid)
' now:
Dim result As System.Threading.Tasks.Task(Of System.Guid) = TaskAssistantModule.OpenTaskItemAsync(taskItemGuid)
ArcGIS.Desktop.Workflow.dll
  • ArcGIS.Desktop.Workflow.WorkflowModule.ConnectAsync
' before:
Dim workflowmodule As ArcGIS.Desktop.Workflow.WorkflowModule
Dim result As System.Threading.Tasks.Task(Of ArcGIS.Desktop.Workflow.Models.WorkflowConnectionStatus) = WorkflowModule.ConnectAsync()
' now:
Dim result As System.Threading.Tasks.Task(Of ArcGIS.Desktop.Workflow.Models.WorkflowConnection) = WorkflowModule.ConnectAsync()
  • ArcGIS.Desktop.Workflow.Models.JobsManager.CloseJobs
' before:
Dim jobIDs As System.Collections.Generic.IReadOnlyList(Of Integer)
Dim jobsmanager As ArcGIS.Desktop.Workflow.Models.JobsManager
Dim result As System.Collections.Generic.IReadOnlyList(Of Integer) = jobsmanager.CloseJobs(jobIDs)
' now:
Dim jobIDs As System.Collections.Generic.IReadOnlyList(Of String)
Dim result As System.Collections.Generic.IReadOnlyList(Of String) = jobsmanager.CloseJobs(jobIDs)
  • ArcGIS.Desktop.Workflow.Models.JobsManager.DeleteJobs
Dim deleteVersion As Boolean
Dim deleteHistory As Boolean
' before:
Dim jobIDs As System.Int32()
Dim result As System.Int32() = jobsmanager.DeleteJobs(jobIDs, deleteVersion, deleteHistory)
' now:
Dim jobIDs As System.String()
Dim result As System.String() = jobsmanager.DeleteJobs(jobIDs, deleteVersion, deleteHistory)
  • ArcGIS.Desktop.Workflow.Models.JobsManager.DeleteMaps
' before:
Dim result As System.Int32() = jobsmanager.DeleteMaps(jobIDs)
' now:
Dim result As System.String() = jobsmanager.DeleteMaps(jobIDs)
  • ArcGIS.Desktop.Workflow.Models.JobsManager.DeleteVersions
' before:
Dim result As System.Int32() = jobsmanager.DeleteVersions(jobIDs)
' now:
Dim result As System.String() = jobsmanager.DeleteVersions(jobIDs)
  • ArcGIS.Desktop.Workflow.Models.JobsManager.GetJob
' before:
Dim jobID2 As String
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.Job = jobsmanager.GetJob(jobID2)
' now:
Dim jobID As String
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.Job = jobsmanager.GetJob(jobID)
ArcGIS.Desktop.Workflow.Models.ConfigItems
  • ArcGIS.Desktop.Workflow.Models.ConfigItems.JobTypeDescription.ID
' before:
Dim jobtypedescription As ArcGIS.Desktop.Workflow.Models.ConfigItems.JobTypeDescription
Dim result As Integer = jobtypedescription.ID
' now:
Dim result As String = jobtypedescription.ID
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CanCompleteStep
' before:
Dim stepID As Integer = -1
Dim job As ArcGIS.Desktop.Workflow.Models.JobModels.Job
Dim result As System.Tuple(Of Boolean, String) = job.CanCompleteStep(-1)
' now:
Dim stepID As String
Dim result As System.Tuple(Of Boolean, String) = job.CanCompleteStep(stepID)
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CanExecuteStep
' before:
Dim result As System.Tuple(Of Boolean, String) = job.CanExecuteStep(-1)
' now:
Dim result As System.Tuple(Of Boolean, String) = job.CanExecuteStep(stepID)
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CanSetCurrentStep
' before:
Dim result As Boolean = job.CanSetCurrentStep(stepID)
' now:
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CompleteStep
' before:
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult = job.CompleteStep(-1)
' now:
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult = job.CompleteStep(stepID)
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.ExecuteStep
' before:
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult = job.ExecuteStep(-1)
' now:
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult = job.ExecuteStep(stepID)
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.FinishSplitExecutionStep
Dim args As System.Collections.Generic.IReadOnlyList(Of String)
' before:
Dim result As ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult = job.FinishSplitExecutionStep(stepID, args)
' now:
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.GetCurrentSteps
' before:
Dim result As System.Collections.Generic.IReadOnlyList(Of Integer) = job.GetCurrentSteps()
' now:
Dim result As System.Collections.Generic.IReadOnlyList(Of String) = job.GetCurrentSteps()
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.ID
' before:
Dim result As Integer = job.ID
' now:
Dim result As String = job.ID
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.ParentJobID
' before:
Dim result As Integer = job.ParentJobID
' now:
Dim result As String = job.ParentJobID
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.SetCurrentStep
' before:
job.SetCurrentStep(stepID)
' now:
  • ArcGIS.Desktop.Workflow.Models.JobModels.JobIdentifier.ID
' before:
Dim jobidentifier As ArcGIS.Desktop.Workflow.Models.JobModels.JobIdentifier
Dim result As Integer = jobidentifier.ID
' now:
Dim result As String = jobidentifier.ID
ArcGIS.Desktop.Workflow.Models.Queries
  • ArcGIS.Desktop.Workflow.Models.Queries.JobQueryRow.JobID
' before:
Dim jobqueryrow As ArcGIS.Desktop.Workflow.Models.Queries.JobQueryRow
Dim result As Integer = jobqueryrow.JobID
' now:
Dim result As String = jobqueryrow.JobID
