ProSnippets Migrating to 2.0
ProSnippets: Migrating to 2.0
Language:      C#
Subject:       Framework
Contributor:   ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:  Esri, https://www.esri.com
Date:          9/28/2021
ArcGIS Pro:    2.9
Visual Studio: 2017, 2019
Find the Visual Basic migration document here: ProSnippets: Migrating to 2.0 Visual Basic
The upgrade from ArcGIS Pro SDK 1.4 to ArcGIS Pro SDK 2.0 is a 'code breaking' change. This means that you have to change, recompile, rebuild, and redistribute any 1.x (SDK 1.4 and earlier) add-ins and configurations so that they work with ArcGIS Pro 2.0. This document lists the most common changes in the config.DAML and various API classes and interfaces.
With 2.0 the ItemFactory pattern changed notably as documented in ProConcepts Content and Items.
In this topic
Upgrading the Config.daml to Pro SDK 2.0
All add-ins and configurations require that the "desktopVersion" attribute under the AddInInfo tag in the config.daml file is updated to the 2.0.0 version as shown below:
1.4 and earlier has a 1.x.x desktopVersion attribute under the AddInInfo tag:
<ArcGIS defaultAssembly="....dll" defaultNamespace="..." xmlns="...">
  <AddInInfo id="{...}" version="1.0" desktopVersion="1.4.7198">
    <Name>...</Name>
    <Description>...</Description>
    <Image>...</Image>
2.0 requires a 2.0.0 (or higher) desktopVersion attribute under the AddInInfo tag:
  <AddInInfo id="{...}" version="1.0" desktopVersion="2.0.0">
    <Name>...</Name>
    <Image>...</Image>
ArcGIS.Core.dll
ArcGIS.Core.Data
  • ArcGIS.Core.Data.FileSystemConnectionPath
  • ArcGIS.Core.Data.FileSystemDatastore
// before:
using (Shapefile shapefile = new Shapefile(new ShapefileConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"))))
  FeatureClass taxLotsFeatureClass      = shapefile.OpenTable("TaxLots") as FeatureClass;
  FeatureClass manHolesFeatureClass     = shapefile.OpenTable("ManHoles.shp") as FeatureClass; // Can use the .shp extension, but its not needed.
  Table taxDetailsTableWithoutExtension = shapefile.OpenTable("TaxDetails");
  Table taxDetailsTable                 = shapefile.OpenTable("TaxDetails.dbf");
// now:
using (FileSystemDatastore shapefile = new FileSystemDatastore(new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"), FileSystemDatastoreType.Shapefile)))
  FeatureClass taxLotsFeatureClass      = shapefile.OpenDataset<FeatureClass>("TaxLots");
  FeatureClass manHolesFeatureClass     = shapefile.OpenDataset<FeatureClass>("ManHoles.shp"); // Can use the .shp extension, but its not needed.
  Table taxDetailsTableWithoutExtension = shapefile.OpenDataset<Table>("TaxDetails");
  Table taxDetailsTable                 = shapefile.OpenDataset<Table>("TaxDetails.dbf");
  • ArcGIS.Core.Data.DatabaseConnectionFile
string connection = "C:\\Work\\temp.sde";
// before:
Geodatabase sde = new Geodatabase(connection);
// now:
var dbGdbConnection = new DatabaseConnectionFile(new Uri(connection, UriKind.Absolute));
Geodatabase sde = new Geodatabase(dbGdbConnection);
  • ArcGIS.Core.Data.Geodatabase.GetEnterpriseDatabaseType
// before:
EnterpriseDatabaseType enterpriseDatabaseType = geodatabase.GetEnterpriseDatabaseType();
// now:
var enterpriseDatabaseType = (geodatabase.GetConnector() as DatabaseConnectionProperties).DBMS;
ArcGIS.Core.Geometry
  • ArcGIS.Core.Geometry.CubicBezierBuilder Constructor
ArcGIS.Core.Geometry.Coordinate2D controlPt12D;
ArcGIS.Core.Geometry.Coordinate2D controlPt22D;
ArcGIS.Core.Geometry.SpatialReference spatialReference;
// before:
ArcGIS.Core.Geometry.Coordinate startPt;
ArcGIS.Core.Geometry.Coordinate endPt;
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Coordinate> coordinates;
var cubicbezierbuilder = new CubicBezierBuilder (startPt, controlPt12D, controlPt22D, endPt, spatialReference);
var cubicbezierbuilder = new CubicBezierBuilder (coordinates, spatialReference);
// now:
ArcGIS.Core.Geometry.Coordinate2D startPt2D;
ArcGIS.Core.Geometry.Coordinate2D endPt2D;
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Coordinate2D> coordinates;
var cubicbezierbuilder = new CubicBezierBuilder (startPt2D, controlPt12D, controlPt22D, endPt2D, spatialReference);
  • ArcGIS.Core.Geometry.CubicBezierBuilder.CreateCubicBezierSegment
// before:
ArcGIS.Core.Geometry.CubicBezierBuilder cubicbezierbuilder;
ArcGIS.Core.Geometry.CubicBezierSegment result = cubicbezierbuilder.CreateCubicBezierSegment (startPt, controlPt12D, controlPt22D, endPt, spatialReference);
ArcGIS.Core.Geometry.CubicBezierSegment result = cubicbezierbuilder.CreateCubicBezierSegment (coordinates, spatialReference);
// now:
ArcGIS.Core.Geometry.CubicBezierSegment result = cubicbezierbuilder.CreateCubicBezierSegment (startPt2D, controlPt12D, controlPt22D, endPt2D, spatialReference);
  • ArcGIS.Core.Geometry.EllipticArcBuilder Constructor
ArcGIS.Core.Geometry.Coordinate2D centerPt2D;
double rotationAngle;
double semiMajorAxis;
double minorMajorRatio;
double radius;
ArcGIS.Core.Geometry.Coordinate2D interiorPt2D;
ArcGIS.Core.Geometry.esriArcOrientation orientation;
double centralAngle;
double chordLength;
double chordBearing;
ArcGIS.Core.Geometry.MinorOrMajor minorOrMajor;
// before:
ArcGIS.Core.Geometry.esriArcOrientation orientation = 1;
ArcGIS.Core.Geometry.MapPoint fromPt;
ArcGIS.Core.Geometry.MapPoint toPt;
double fromAngle;
var ellipticarcbuilder = new EllipticArcBuilder (centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, 1, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (centerPt2D, radius, 1, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (fromPt, toPt, interiorPt2D);
var ellipticarcbuilder = new EllipticArcBuilder (fromPt, toPt, centerPt2D, orientation, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (fromAngle, centralAngle, centerPt2D, radius, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor, spatialReference);
// now:
ArcGIS.Core.Geometry.Segment segment1;
ArcGIS.Core.Geometry.Segment segment2;
ArcGIS.Core.Geometry.Coordinate2D hintPoint2D;
ArcGIS.Core.Geometry.MapPoint startPt;
double arcLength;
ArcGIS.Core.Geometry.MapPoint endPt;
double startAngle;
var ellipticarcbuilder = new EllipticArcBuilder (centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, orientation, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (segment1, segment2, radius, hintPoint2D, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (startPt, chordLength, chordBearing, arcLength, orientation, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (centerPt2D, radius, orientation, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (startPt, endPt, interiorPt2D);
var ellipticarcbuilder = new EllipticArcBuilder (startPt, endPt, centerPt2D, orientation, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (startAngle, centralAngle, centerPt2D, radius, spatialReference);
var ellipticarcbuilder = new EllipticArcBuilder (startPt, chordLength, chordBearing, radius, orientation, minorOrMajor, spatialReference);
  • ArcGIS.Core.Geometry.EllipticArcBuilder.CreateEllipticArcSegment
double radius;
double chordLength;
// before:
double fromAngle;
ArcGIS.Core.Geometry.EllipticArcBuilder ellipticarcbuilder;
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (fromAngle, centralAngle, centerPt2D, radius, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (fromPt, chordLength, chordBearing, radius, orientation, minorOrMajor, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (centerPt2D, radius, 1, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, 1, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (fromPt, toPt, centerPt2D, orientation, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (fromPt, toPt, interiorPt2D, spatialReference);
// now:
double startAngle;
double arcLength;
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (startAngle, centralAngle, centerPt2D, radius, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (startPt, chordLength, chordBearing, radius, orientation, minorOrMajor, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (centerPt2D, radius, orientation, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (segment1, segment2, radius, hintPoint2D, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (startPt, chordLength, chordBearing, arcLength, orientation, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (centerPt2D, rotationAngle, semiMajorAxis, minorMajorRatio, orientation, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (startPt, endPt, centerPt2D, orientation, spatialReference);
ArcGIS.Core.Geometry.EllipticArcSegment result = ellipticarcbuilder.CreateEllipticArcSegment (startPt, endPt, interiorPt2D, spatialReference);
  • ArcGIS.Core.Geometry.EnvelopeBuilder.CreateEnvelope
// before:
ArcGIS.Core.Geometry.Coordinate minCoord;
ArcGIS.Core.Geometry.Coordinate maxCoord;
ArcGIS.Core.Geometry.EnvelopeBuilder envelopebuilder;
ArcGIS.Core.Geometry.Envelope result = envelopebuilder.CreateEnvelope (minCoord, maxCoord, spatialReference);
// now:
ArcGIS.Core.Geometry.Coordinate3D minCoord3D;
ArcGIS.Core.Geometry.Coordinate3D maxCoord3D;
ArcGIS.Core.Geometry.Envelope envelope;
ArcGIS.Core.Geometry.Envelope result = envelopebuilder.CreateEnvelope (minCoord3D, maxCoord3D, spatialReference);
ArcGIS.Core.Geometry.Envelope result = envelopebuilder.CreateEnvelope (spatialReference);
ArcGIS.Core.Geometry.Envelope result = envelopebuilder.CreateEnvelope (envelope, spatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.Area
using geometryengine = ArcGIS.Core.Geometry.GeometryEngine;
ArcGIS.Core.Geometry.Geometry geometry;
// before:
double result = geometryengine.Area (geometry);
// now:
double result = geometryengine.Instance.Area (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.AutoComplete
ArcGIS.Core.Geometry.Polygon inputPolygon;
ArcGIS.Core.Geometry.Polyline completionLine;
// before:
ArcGIS.Core.Geometry.Polygon result = geometryengine.AutoComplete (inputPolygon, completionLine);
// now:
ArcGIS.Core.Geometry.Polygon result = geometryengine.Instance.AutoComplete (inputPolygon, completionLine);
  • ArcGIS.Core.Geometry.GeometryEngine.Boundary
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Boundary (geometry);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Boundary (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Buffer
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Geometry> geometries;
double distance;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Buffer (geometries, distance);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Buffer (geometry, distance);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Buffer (geometries, distance);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Buffer (geometry, distance);
  • ArcGIS.Core.Geometry.GeometryEngine.CalculateNonSimpleMs
ArcGIS.Core.Geometry.Multipart multipart;
double defaultMValue;
// before:
ArcGIS.Core.Geometry.Multipart result = geometryengine.CalculateNonSimpleMs (multipart, defaultMValue);
// now:
ArcGIS.Core.Geometry.Multipart result = geometryengine.Instance.CalculateNonSimpleMs (multipart, defaultMValue);
  • ArcGIS.Core.Geometry.GeometryEngine.CalculateNonSimpleZs
double defaultZValue;
// before:
ArcGIS.Core.Geometry.Multipart result = geometryengine.CalculateNonSimpleZs (multipart, defaultZValue);
// now:
ArcGIS.Core.Geometry.Multipart result = geometryengine.Instance.CalculateNonSimpleZs (multipart, defaultZValue);
  • ArcGIS.Core.Geometry.GeometryEngine.CenterAt
double x;
double y;
// before:
ArcGIS.Core.Geometry.Envelope result = geometryengine.CenterAt (envelope, x, y);
// now:
ArcGIS.Core.Geometry.Envelope result = geometryengine.Instance.CenterAt (envelope, x, y);
  • ArcGIS.Core.Geometry.GeometryEngine.Centroid
// before:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.Centroid (geometry);
// now:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.Instance.Centroid (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Clip
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Clip (geometry, envelope);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Clip (geometry, envelope);
  • ArcGIS.Core.Geometry.GeometryEngine.Contains
ArcGIS.Core.Geometry.Geometry geometry1;
ArcGIS.Core.Geometry.Geometry geometry2;
// before:
bool result = geometryengine.Contains (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Contains (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.ConvexHull
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.ConvexHull (geometry);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ConvexHull (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Crosses
// before:
bool result = geometryengine.Crosses (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Crosses (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Cut
ArcGIS.Core.Geometry.Polyline cutter;
// before:
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Geometry> result = geometryengine.Cut (geometry, cutter);
// now:
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Geometry> result = geometryengine.Instance.Cut (multipart, cutter);
  • ArcGIS.Core.Geometry.GeometryEngine.DensifyByDeviation
double maxDeviationMeters;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.DensifyByDeviation (geometry, maxDeviationMeters);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.DensifyByDeviation (geometry, maxDeviationMeters);
  • ArcGIS.Core.Geometry.GeometryEngine.DensifyByLength
double maxSegmentLength;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.DensifyByLength (geometry, maxSegmentLength);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.DensifyByLength (geometry, maxSegmentLength);
  • ArcGIS.Core.Geometry.GeometryEngine.Difference
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Difference (geometry1, geometry2);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Difference (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Disjoint
// before:
bool result = geometryengine.Disjoint (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Disjoint (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Disjoint3D
// before:
bool result = geometryengine.Disjoint3D (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Disjoint3D (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Distance
// before:
double result = geometryengine.Distance (geometry1, geometry2);
// now:
double result = geometryengine.Instance.Distance (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Distance3D
// before:
double result = geometryengine.Distance3D (geometry1, geometry2);
// now:
double result = geometryengine.Instance.Distance3D (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Equals
// before:
bool result = geometryengine.Equals (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Equals (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Expand
double dx;
double dy;
double dz;
bool asRatio;
// before:
ArcGIS.Core.Geometry.Envelope result = geometryengine.Expand (envelope, dx, dy, dz, asRatio);
ArcGIS.Core.Geometry.Envelope result = geometryengine.Expand (envelope, dx, dy, asRatio);
// now:
ArcGIS.Core.Geometry.Envelope result = geometryengine.Instance.Expand (envelope, dx, dy, dz, asRatio);
ArcGIS.Core.Geometry.Envelope result = geometryengine.Instance.Expand (envelope, dx, dy, asRatio);
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToEsriShape
ArcGIS.Core.Geometry.EsriShapeExportFlags exportFlags;
System.Byte[] buffer;
// before:
int result = geometryengine.ExportToEsriShape (exportFlags, geometry, ref buffer);
System.Byte[] result = geometryengine.ExportToEsriShape (exportFlags, geometry);
// now:
int result = geometryengine.Instance.ExportToEsriShape (exportFlags, geometry, ref buffer);
System.Byte[] result = geometryengine.Instance.ExportToEsriShape (exportFlags, geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToJSON
ArcGIS.Core.Geometry.JSONExportFlags exportFlags;
// before:
string result = geometryengine.ExportToJSON (exportFlags, geometry);
// now:
string result = geometryengine.Instance.ExportToJSON (exportFlags, geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToWKB
ArcGIS.Core.Geometry.WKBExportFlags exportFlags;
// before:
int result = geometryengine.ExportToWKB (exportFlags, geometry, ref buffer);
System.Byte[] result = geometryengine.ExportToWKB (exportFlags, geometry);
// now:
int result = geometryengine.Instance.ExportToWKB (exportFlags, geometry, ref buffer);
System.Byte[] result = geometryengine.Instance.ExportToWKB (exportFlags, geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.ExportToWKT
ArcGIS.Core.Geometry.WKTExportFlags exportFlags;
// before:
string result = geometryengine.ExportToWKT (exportFlags, geometry);
// now:
string result = geometryengine.Instance.ExportToWKT (exportFlags, geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Extend
ArcGIS.Core.Geometry.Polyline polyline;
ArcGIS.Core.Geometry.Polyline extender;
ArcGIS.Core.Geometry.ExtendFlags ExtendFlags;
// before:
ArcGIS.Core.Geometry.Polyline result = geometryengine.Extend (polyline, extender, ExtendFlags);
// now:
ArcGIS.Core.Geometry.Polyline result = geometryengine.Instance.Extend (polyline, extender, ExtendFlags);
  • ArcGIS.Core.Geometry.GeometryEngine.Generalize
double maxDeviation;
// before:
bool removeDegenerateParts = False;
bool preserveCurves = False;
ArcGIS.Core.Geometry.Geometry result = geometryengine.Generalize (geometry, maxDeviation, False, False);
// now:
bool removeDegenerateParts;
bool preserveCurves;
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Generalize (geometry, maxDeviation, removeDegenerateParts, preserveCurves);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicArea
// before:
double result = geometryengine.GeodesicArea (geometry);
// now:
double result = geometryengine.Instance.GeodesicArea (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicBuffer
double distance;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.GeodesicBuffer (geometries, distance);
ArcGIS.Core.Geometry.Geometry result = geometryengine.GeodesicBuffer (geometry, distance);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.GeodesicBuffer (geometries, distance);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.GeodesicBuffer (geometry, distance);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicDistance
// before:
double result = geometryengine.GeodesicDistance (geometry1, geometry2);
// now:
double result = geometryengine.Instance.GeodesicDistance (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicEllipse
ArcGIS.Core.Geometry.GeodesicEllipseParameter parameter;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.GeodesicEllipse (parameter, spatialReference);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.GeodesicEllipse (parameter, spatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicLength
// before:
double result = geometryengine.GeodesicLength (geometry);
// now:
double result = geometryengine.Instance.GeodesicLength (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodesicSector
ArcGIS.Core.Geometry.GeodesicSectorParameter parameter;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.GeodesicSector (parameter, spatialReference);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.GeodesicSector (parameter, spatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodeticDensifyByDeviation
ArcGIS.Core.Geometry.LinearUnit deviationUnit;
// before:
ArcGIS.Core.Geometry.CurveType curveType;
ArcGIS.Core.Geometry.Geometry result = geometryengine.GeodeticDensifyByDeviation (geometry, maxDeviation, deviationUnit, curveType);
// now:
ArcGIS.Core.Geometry.GeodeticCurveType curveType;
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.GeodeticDensifyByDeviation (geometry, maxDeviation, deviationUnit, curveType);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodeticDensifyByLength
ArcGIS.Core.Geometry.LinearUnit lengthUnit;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.GeodeticDensifyByLength (geometry, maxSegmentLength, lengthUnit, curveType);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.GeodeticDensifyByLength (geometry, maxSegmentLength, lengthUnit, curveType);
  • ArcGIS.Core.Geometry.GeometryEngine.GeodeticMove
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.MapPoint> points;
double distance;
ArcGIS.Core.Geometry.LinearUnit unit;
double azimuth;
// before:
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.MapPoint> result = geometryengine.GeodeticMove (points, spatialReference, distance, unit, azimuth, curveType);
// now:
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.MapPoint> result = geometryengine.Instance.GeodeticMove (points, spatialReference, distance, unit, azimuth, curveType);
  • ArcGIS.Core.Geometry.GeometryEngine.GetEsriShapeSize
// before:
int result = geometryengine.GetEsriShapeSize (exportFlags, geometry);
// now:
int result = geometryengine.Instance.GetEsriShapeSize (exportFlags, geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.GetPredefinedCoordinateSystemList
ArcGIS.Core.Geometry.CoordinateSystemFilter filter;
// before:
System.Collections.Generic.IReadOnlyList<ArcGIS.Core.Geometry.CoordinateSystemListEntry> result = geometryengine.GetPredefinedCoordinateSystemList (filter);
// now:
System.Collections.Generic.IReadOnlyList<ArcGIS.Core.Geometry.CoordinateSystemListEntry> result = geometryengine.Instance.GetPredefinedCoordinateSystemList (filter);
  • ArcGIS.Core.Geometry.GeometryEngine.GetSubCurve
double fromDistance;
double toDistance;
ArcGIS.Core.Geometry.AsRatioOrLength asRatioOrLength;
// before:
ArcGIS.Core.Geometry.Polyline result = geometryengine.GetSubCurve (multipart, fromDistance, toDistance, asRatioOrLength);
// now:
ArcGIS.Core.Geometry.Polyline result = geometryengine.Instance.GetSubCurve (multipart, fromDistance, toDistance, asRatioOrLength);
  • ArcGIS.Core.Geometry.GeometryEngine.GetSubCurve3D
double toDistance;
// before:
ArcGIS.Core.Geometry.Polyline result = geometryengine.GetSubCurve3D (multipart, fromDistance, toDistance, asRatioOrLength);
// now:
ArcGIS.Core.Geometry.Polyline result = geometryengine.Instance.GetSubCurve3D (multipart, fromDistance, toDistance, asRatioOrLength);
  • ArcGIS.Core.Geometry.GeometryEngine.GetWKBSize
// before:
int result = geometryengine.GetWKBSize (exportFlags, geometry);
// now:
int result = geometryengine.Instance.GetWKBSize (exportFlags, geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromEsriShape
ArcGIS.Core.Geometry.EsriShapeImportFlags importFlags;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.ImportFromEsriShape (importFlags, buffer, spatialReference);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ImportFromEsriShape (importFlags, buffer, spatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromJSON
ArcGIS.Core.Geometry.JSONImportFlags importFlags;
string jsonString;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.ImportFromJSON (importFlags, jsonString);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ImportFromJSON (importFlags, jsonString);
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromWKB
ArcGIS.Core.Geometry.WKBImportFlags importFlags;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.ImportFromWKB (importFlags, buffer, spatialReference);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ImportFromWKB (importFlags, buffer, spatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.ImportFromWKT
ArcGIS.Core.Geometry.WKTImportFlags importFlags;
string wktString;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.ImportFromWKT (importFlags, wktString, spatialReference);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ImportFromWKT (importFlags, wktString, spatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.Intersection
ArcGIS.Core.Geometry.GeometryDimension resultDimension;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Intersection (geometry1, geometry2, resultDimension);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Intersection (geometry1, geometry2);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Intersection (geometry1, geometry2, resultDimension);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Intersection (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Intersects
// before:
bool result = geometryengine.Intersects (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Intersects (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.IsSimpleAsFeature
// before:
bool forceIsSimple = False;
bool result = geometryengine.IsSimpleAsFeature (geometry, False);
// now:
bool forceIsSimple;
bool result = geometryengine.Instance.IsSimpleAsFeature (geometry, forceIsSimple);
  • ArcGIS.Core.Geometry.GeometryEngine.LabelPoint
// before:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.LabelPoint (geometry);
// now:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.Instance.LabelPoint (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Length
// before:
double result = geometryengine.Length (geometry);
// now:
double result = geometryengine.Instance.Length (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Length3D
// before:
double result = geometryengine.Length3D (geometry);
// now:
double result = geometryengine.Instance.Length3D (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Move
double dx;
double dy;
double dz;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Move (geometry, dx, dy);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Move (geometry, dx, dy, dz);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Move (geometry, dx, dy);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Move (geometry, dx, dy, dz);
  • ArcGIS.Core.Geometry.GeometryEngine.MovePointAlongLine
double distanceAlong;
bool asRatio;
double offset;
ArcGIS.Core.Geometry.SegmentExtension extension;
// before:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.MovePointAlongLine (multipart, distanceAlong, asRatio, offset, extension);
// now:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.Instance.MovePointAlongLine (multipart, distanceAlong, asRatio, offset, extension);
  • ArcGIS.Core.Geometry.GeometryEngine.NearestPoint
ArcGIS.Core.Geometry.MapPoint point;
// before:
ArcGIS.Core.Geometry.ProximityResult result = geometryengine.NearestPoint (geometry, point);
// now:
ArcGIS.Core.Geometry.ProximityResult result = geometryengine.Instance.NearestPoint (geometry, point);
  • ArcGIS.Core.Geometry.GeometryEngine.NearestPoint3D
// before:
ArcGIS.Core.Geometry.ProximityResult result = geometryengine.NearestPoint3D (geometry, point);
// now:
ArcGIS.Core.Geometry.ProximityResult result = geometryengine.Instance.NearestPoint3D (geometry, point);
  • ArcGIS.Core.Geometry.GeometryEngine.NearestVertex
// before:
ArcGIS.Core.Geometry.ProximityResult result = geometryengine.NearestVertex (geometry, point);
// now:
ArcGIS.Core.Geometry.ProximityResult result = geometryengine.Instance.NearestVertex (geometry, point);
  • ArcGIS.Core.Geometry.GeometryEngine.NormalizeCentralMeridian
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.NormalizeCentralMeridian (geometry);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.NormalizeCentralMeridian (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.Offset
double distance;
ArcGIS.Core.Geometry.OffsetType offsetType;
double bevelRatio;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Offset (geometry, distance, offsetType, bevelRatio);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Offset (geometry, distance, offsetType, bevelRatio);
  • ArcGIS.Core.Geometry.GeometryEngine.Overlaps
// before:
bool result = geometryengine.Overlaps (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Overlaps (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Project
ArcGIS.Core.Geometry.SpatialReference outputSpatialReference;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Project (geometry, outputSpatialReference);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Project (geometry, outputSpatialReference);
  • ArcGIS.Core.Geometry.GeometryEngine.ProjectEx
ArcGIS.Core.Geometry.ProjectionTransformation projTransformation;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.ProjectEx (geometry, projTransformation);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ProjectEx (geometry, projTransformation);
  • ArcGIS.Core.Geometry.GeometryEngine.QueryPointAndDistance
ArcGIS.Core.Geometry.MapPoint inPoint;
System.Double distanceAlongCurve;
System.Double distanceFromCurve;
ArcGIS.Core.Geometry.LeftOrRightSide whichSide;
// before:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.QueryPointAndDistance (multipart, extension, inPoint, asRatioOrLength, out distanceAlongCurve, out distanceFromCurve, out whichSide);
// now:
ArcGIS.Core.Geometry.MapPoint result = geometryengine.Instance.QueryPointAndDistance (multipart, extension, inPoint, asRatioOrLength, out distanceAlongCurve, out distanceFromCurve, out whichSide);
  • ArcGIS.Core.Geometry.GeometryEngine.Relate
string relateString;
// before:
bool result = geometryengine.Relate (geometry1, geometry2, relateString);
// now:
bool result = geometryengine.Instance.Relate (geometry1, geometry2, relateString);
  • ArcGIS.Core.Geometry.GeometryEngine.ReplaceNaNZs
double zValue;
// before:
ArcGIS.Core.Geometry.Multipart result = geometryengine.ReplaceNaNZs (multipart, zValue);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.ReplaceNaNZs (geometry, zValue);
  • ArcGIS.Core.Geometry.GeometryEngine.Reshape
ArcGIS.Core.Geometry.Polyline reshaper;
// before:
ArcGIS.Core.Geometry.Multipart result = geometryengine.Reshape (multipart, reshaper);
// now:
ArcGIS.Core.Geometry.Multipart result = geometryengine.Instance.Reshape (multipart, reshaper);
  • ArcGIS.Core.Geometry.GeometryEngine.ReverseOrientation
// before:
ArcGIS.Core.Geometry.Multipart result = geometryengine.ReverseOrientation (multipart);
// now:
ArcGIS.Core.Geometry.Multipart result = geometryengine.Instance.ReverseOrientation (multipart);
  • ArcGIS.Core.Geometry.GeometryEngine.Rotate
ArcGIS.Core.Geometry.MapPoint origin;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Rotate (geometry, origin, rotationAngle);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Rotate (geometry, origin, rotationAngle);
  • ArcGIS.Core.Geometry.GeometryEngine.Scale
double sx;
double sy;
double sz;
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Scale (geometry, origin, sx, sy, sz);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Scale (geometry, origin, sx, sy);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Scale (geometry, origin, sx, sy, sz);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Scale (geometry, origin, sx, sy);
  • ArcGIS.Core.Geometry.GeometryEngine.SetConstantZ
double zValue;
// before:
ArcGIS.Core.Geometry.Multipart result = geometryengine.SetConstantZ (multipart, zValue);
// now:
ArcGIS.Core.Geometry.Multipart result = geometryengine.Instance.SetConstantZ (multipart, zValue);
  • ArcGIS.Core.Geometry.GeometryEngine.ShapePreservingArea
// before:
double result = geometryengine.ShapePreservingArea (geometry);
// now:
double result = geometryengine.Instance.ShapePreservingArea (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.ShapePreservingLength
// before:
double result = geometryengine.ShapePreservingLength (geometry);
// now:
double result = geometryengine.Instance.ShapePreservingLength (geometry);
  • ArcGIS.Core.Geometry.GeometryEngine.SimplifyAsFeature
// before:
bool forceSimplify = False;
ArcGIS.Core.Geometry.Geometry result = geometryengine.SimplifyAsFeature (geometry, False);
// now:
bool forceSimplify;
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.SimplifyAsFeature (geometry, forceSimplify);
  • ArcGIS.Core.Geometry.GeometryEngine.SimplifyPolyline
ArcGIS.Core.Geometry.SimplifyType simplifyType;
// before:
ArcGIS.Core.Geometry.Polyline result = geometryengine.SimplifyPolyline (polyline, simplifyType, False);
// now:
bool forceSimplify;
ArcGIS.Core.Geometry.Polyline result = geometryengine.Instance.SimplifyPolyline (polyline, simplifyType, forceSimplify);
  • ArcGIS.Core.Geometry.GeometryEngine.SymmetricDifference
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.SymmetricDifference (geometry1, geometry2);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.SymmetricDifference (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Touches
// before:
bool result = geometryengine.Touches (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Touches (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Union
// before:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Union (geometries);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Union (geometry1, geometry2);
// now:
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Union (geometries);
ArcGIS.Core.Geometry.Geometry result = geometryengine.Instance.Union (geometry1, geometry2);
  • ArcGIS.Core.Geometry.GeometryEngine.Within
// before:
bool result = geometryengine.Within (geometry1, geometry2);
// now:
bool result = geometryengine.Instance.Within (geometry1, geometry2);
  • ArcGIS.Core.Geometry.LineBuilder Constructor
// before:
ArcGIS.Core.Geometry.Coordinate startCoord;
ArcGIS.Core.Geometry.Coordinate endCoord;
var linebuilder = new LineBuilder (startCoord, endCoord, spatialReference);
// now:
ArcGIS.Core.Geometry.Coordinate2D startCoord2D;
ArcGIS.Core.Geometry.Coordinate2D endCoord2D;
ArcGIS.Core.Geometry.Coordinate3D startCoord3D;
ArcGIS.Core.Geometry.Coordinate3D endCoord3D;
var linebuilder = new LineBuilder (startCoord2D, endCoord2D, spatialReference);
var linebuilder = new LineBuilder (startCoord3D, endCoord3D, spatialReference);
  • ArcGIS.Core.Geometry.LineBuilder.CreateLineSegment
// before:
ArcGIS.Core.Geometry.LineBuilder linebuilder;
ArcGIS.Core.Geometry.LineSegment result = linebuilder.CreateLineSegment (startCoord, endCoord, spatialReference);
// now:
ArcGIS.Core.Geometry.LineSegment result = linebuilder.CreateLineSegment (startCoord2D, endCoord2D, spatialReference);
ArcGIS.Core.Geometry.LineSegment result = linebuilder.CreateLineSegment (startCoord3D, endCoord3D, spatialReference);
  • ArcGIS.Core.Geometry.MapPointBuilder Constructor
double x;
double y;
double z;
double m;
// before:
bool hasZ = False;
ArcGIS.Core.Geometry.Coordinate coordinate;
bool hasM = False;
var mappointbuilder = new MapPointBuilder (x, y, z, spatialReference, False);
var mappointbuilder = new MapPointBuilder (coordinate, spatialReference);
var mappointbuilder = new MapPointBuilder ();
var mappointbuilder = new MapPointBuilder (x, y, z, m, spatialReference, False, False);
// now:
ArcGIS.Core.Geometry.Coordinate3D coordinate3D;
int id;
var mappointbuilder = new MapPointBuilder (x, y, z, m, spatialReference);
var mappointbuilder = new MapPointBuilder (coordinate3D, spatialReference);
var mappointbuilder = new MapPointBuilder (x, y, z, spatialReference);
var mappointbuilder = new MapPointBuilder (x, y, z, m, id, spatialReference);
  • ArcGIS.Core.Geometry.MapPointBuilder.CreateMapPoint
// before:
ArcGIS.Core.Geometry.Coordinate2D coord2D;
ArcGIS.Core.Geometry.MapPointBuilder mappointbuilder;
ArcGIS.Core.Geometry.MapPoint result = mappointbuilder.CreateMapPoint (coord2D, spatialReference);
ArcGIS.Core.Geometry.MapPoint result = mappointbuilder.CreateMapPoint (coordinate, spatialReference);
// now:
ArcGIS.Core.Geometry.Coordinate2D coordinate2D;
ArcGIS.Core.Geometry.MapPoint result = mappointbuilder.CreateMapPoint (coordinate2D, spatialReference);
ArcGIS.Core.Geometry.MapPoint result = mappointbuilder.CreateMapPoint (coordinate3D, spatialReference);
  • ArcGIS.Core.Geometry.MultipartBuilder.AddPart
// before:
ArcGIS.Core.Geometry.MultipartBuilder<T> multipartbuilder;
multipartbuilder.AddPart (coordinates);
// now:
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Coordinate3D> coordinates;
  • ArcGIS.Core.Geometry.MultipartBuilder.InsertPart
int beforePartIndex;
// before:
multipartbuilder.InsertPart (beforePartIndex, coordinates);
// now:
  • ArcGIS.Core.Geometry.MultipointBuilder Constructor
// before:
var multipointbuilder = new MultipointBuilder (coordinates, spatialReference);
// now:
  • ArcGIS.Core.Geometry.MultipointBuilder.Add
// before:
ArcGIS.Core.Geometry.Coordinate point;
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Coordinate> points;
ArcGIS.Core.Geometry.MultipointBuilder multipointbuilder;
multipointbuilder.Add (point);
multipointbuilder.Add (points);
// now:
ArcGIS.Core.Geometry.Coordinate3D point3D;
System.Collections.Generic.IEnumerable<ArcGIS.Core.Geometry.Coordinate3D> points;
multipointbuilder.Add (point3D);
  • ArcGIS.Core.Geometry.MultipointBuilder.CreateMultipoint
// before:
ArcGIS.Core.Geometry.Multipoint result = multipointbuilder.CreateMultipoint (coordinates, spatialReference);
// now:
  • ArcGIS.Core.Geometry.MultipointBuilder.Insert
int beforePointIndex;
// before:
multipointbuilder.Insert (beforePointIndex, coordinate);
multipointbuilder.Insert (beforePointIndex, coordinates);
// now:
multipointbuilder.Insert (beforePointIndex, coordinate3D);
  • ArcGIS.Core.Geometry.PolygonBuilder Constructor
// before:
var polygonbuilder = new PolygonBuilder (coordinates, spatialReference);
// now:
  • ArcGIS.Core.Geometry.PolygonBuilder.CreatePolygon
// before:
ArcGIS.Core.Geometry.PolygonBuilder polygonbuilder;
ArcGIS.Core.Geometry.Polygon result = polygonbuilder.CreatePolygon (coordinates, spatialReference);
// now:
  • ArcGIS.Core.Geometry.PolylineBuilder Constructor
// before:
var polylinebuilder = new PolylineBuilder (coordinates, spatialReference);
// now:
  • ArcGIS.Core.Geometry.PolylineBuilder.CreatePolyline
// before:
ArcGIS.Core.Geometry.PolylineBuilder polylinebuilder;
ArcGIS.Core.Geometry.Polyline result = polylinebuilder.CreatePolyline (coordinates, spatialReference);
// now:
ArcGIS.Desktop.Core.dll
ArcGIS.Desktop.Core
  • ArcGIS.Desktop.Core.IProjectWindow.SelectedItems
// before:
ArcGIS.Desktop.Core.IProjectWindow iprojectwindow;
System.Collections.Generic.IEnumerable<ArcGIS.Desktop.Core.ProjectItem> result = iprojectwindow.SelectedItems ;
// now:
System.Collections.Generic.IEnumerable<ArcGIS.Desktop.Core.Item> result = iprojectwindow.SelectedItems ;
  • ArcGIS.Desktop.Core.Item.IsContainer
// before:
ArcGIS.Desktop.Core.Item item;
bool result = item.IsContainer ;
// now:
  • ArcGIS.Desktop.Core.ItemFactory.Create
using itemfactory = ArcGIS.Desktop.Core.ItemFactory;
string uri;
ArcGIS.Desktop.Core.ItemType itemType = 0;
// before:
ArcGIS.Desktop.Core.Item result = itemfactory.Create (uri, 0);
// now:
ArcGIS.Desktop.Core.Item result = itemfactory.Instance.Create (uri, 0);
  • ArcGIS.Desktop.Core.Project.Current.AddItem
string addFolderPath;
// before:
var theFolderToAdd = ItemFactory.Create(addFolderPath);
await Project.Current.AddAsync(theFolderToAdd);
// now:
var theFolderToAdd = ItemFactory.Instance.Create(addFolderPath);
await QueuedTask.Run(() => Project.Current.AddItem(theFolderToAdd as IProjectItem));
  • ArcGIS.Desktop.Core.Project.Current.RemoveItem
// before:
FolderConnectionProjectItem folderToRemove = Project.Current.GetItems<FolderConnectionProjectItem>().FirstOrDefault(myfolder => myfolder.Name.Equals("PlantSpecies"));
if (folderToRemove != null)
  await Project.Current.RemoveAsync(folderToRemove);
// now:
  Project.Current.RemoveItem(folderToRemove as IProjectItem);
  • ArcGIS.Desktop.Core.Project.GetItems
// before:
ArcGIS.Desktop.Core.Project project;
System.Collections.Generic.IEnumerable<Item> result = project.GetItems<Item> ();
System.Collections.Generic.IEnumerable<Item> result = await project.GetItemsAsync ();
// now:
  • ArcGIS.Desktop.Core.Project.Items
// before:
System.Collections.ObjectModel.ReadOnlyObservableCollection<ArcGIS.Desktop.Core.ProjectItem> result = project.Items ;
// now:
System.Collections.ObjectModel.ReadOnlyObservableCollection<ArcGIS.Desktop.Core.Item> result = project.Items ;
  • ArcGIS.Desktop.Core.Project.SearchAsync
List<Item> _mxd = new List<Item>();
//Gets all the folder connections in the current project
// before:
var allFoldersItem = Project.Current.GetItems<FolderConnectionProjectItem>();
if (allFoldersItem != null)
  //iterate through all the FolderConnectionProjectItems found
  foreach (var folderItem in allFoldersItem)
    _mxd.AddRange(await folderItem.SearchAsync(".mxd"));
// now:
_mxd.AddRange(await Project.Current.SearchAsync(".mxd"));
ArcGIS.Desktop.Core.Events
  • ArcGIS.Desktop.Core.Events.ProjectItemsChangedEventArgs.ProjectItem
// before:
ArcGIS.Desktop.Core.Events.ProjectItemsChangedEventArgs projectitemschangedeventargs;
ArcGIS.Desktop.Core.ProjectItem result = projectitemschangedeventargs.ProjectItem ;
// now:
ArcGIS.Desktop.Core.Item result = projectitemschangedeventargs.ProjectItem ;
ArcGIS.Desktop.Core.Geoprocessing
  • ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing.ShowMessageBox
System.Collections.Generic.IEnumerable<ArcGIS.Desktop.Core.Geoprocessing.IGPMessage> messages;
string content_header;
ArcGIS.Desktop.Core.Geoprocessing.GPMessageBoxStyle style;
string window_title;
string icon_source;
// before:
ArcGIS.Desktop.Core.Geoprocessing.Geoprocessing geoprocessing;
geoprocessing.ShowMessageBox (messages, content_header, style, window_title, icon_source);
// now:
ArcGIS.Desktop.Framework.Contracts.ViewModelBase parentViewModel;
geoprocessing.ShowMessageBox (messages, content_header, style, window_title, icon_source, parentViewModel);
ArcGIS.Desktop.Editing.dll
  • ArcGIS.Desktop.Editing.EditOperation.Planarize
ArcGIS.Desktop.Mapping.Layer sourceLayer;
System.Collections.Generic.IEnumerable<long> sourceOIDs;
// before:
double clusterTolerance;
ArcGIS.Desktop.Editing.EditOperation editoperation;
editoperation.Planarize (sourceLayer, sourceOIDs, clusterTolerance);
// now:
double? clusterTolerance;
ArcGIS.Desktop.Editing.Attributes
  • ArcGIS.Desktop.Editing.Attributes.Attribute.SetOriginalValue
object value;
// before:
ArcGIS.Desktop.Editing.Attributes.Attribute attribute;
attribute.SetOriginalValue (value);
// now:
bool didEditFail = False;
attribute.SetOriginalValue (value, False);
ArcGIS.Desktop.Editing.Events
  • ArcGIS.Desktop.Editing.Events.TopologyEventArgs Constructor
System.Tuple<stringbooldouble> newUseTopology;
System.Tuple<stringbooldouble> oldUseTopology;
// before:
var topologyeventargs = new TopologyEventArgs (newUseTopology, oldUseTopology);
// now:
ArcGIS.Desktop.Mapping.Map map;
var topologyeventargs = new TopologyEventArgs (map, newUseTopology, oldUseTopology);
ArcGIS.Desktop.Framework.dll
ArcGIS.Desktop.Framework.Controls
  • ArcGIS.Desktop.Framework.Controls.EmbeddableControl Constructor
System.Xml.Linq.XElement options;
// before:
var embeddablecontrol = new EmbeddableControl (options);
// now:
bool canChangeOptions;
var embeddablecontrol = new EmbeddableControl (options, canChangeOptions);
  • ArcGIS.Desktop.Framework.Controls.EmbeddableControl.Create
string damlID;
// before:
ArcGIS.Desktop.Framework.Controls.EmbeddableControl embeddablecontrol;
System.Tuple<ArcGIS.Desktop.Framework.Controls.EmbeddableControl,System.Windows.Controls.UserControl> result = embeddablecontrol.Create (damlID, options);
// now:
System.Tuple<ArcGIS.Desktop.Framework.Controls.EmbeddableControl,System.Windows.Controls.UserControl> result = embeddablecontrol.Create (damlID);
ArcGIS.Desktop.Layouts.dll
  • ArcGIS.Desktop.Layouts.GroupElement.Elements
// before:
ArcGIS.Desktop.Layouts.GroupElement groupelement;
System.Collections.ObjectModel.ObservableCollection<ArcGIS.Desktop.Layouts.Element> result = groupelement.Elements ;
// now:
System.Collections.ObjectModel.ReadOnlyObservableCollection<ArcGIS.Desktop.Layouts.Element> result = groupelement.Elements ;
  • ArcGIS.Desktop.Layouts.TextProperties Constructor
string text;
string font;
double fontSize;
// before:
var textproperties = new TextProperties (text, font, fontSize);
// now:
string fontStyle;
var textproperties = new TextProperties (text, font, fontSize, fontStyle);
ArcGIS.Desktop.Mapping.dll
  • ArcGIS.Desktop.Mapping.ColorFactory.BlackRGB
using colorfactory = ArcGIS.Desktop.Mapping.ColorFactory;
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.BlackRGB ;
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.BlackRGB ;
  • ArcGIS.Desktop.Mapping.ColorFactory.BlueRGB
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.BlueRGB ;
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.BlueRGB ;
  • ArcGIS.Desktop.Mapping.ColorFactory.CreateColor
System.Drawing.Color color;
System.Windows.Media.Color color;
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.CreateColor (color);
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.CreateColor (color);
  • ArcGIS.Desktop.Mapping.ColorFactory.CreateRGBColor
// before:
System.Single R;
System.Single G;
System.Single B;
System.Single A = 100;
ArcGIS.Core.CIM.CIMColor result = colorfactory.CreateRGBColor (R, G, B, 100);
// now:
double R;
double G;
double B;
double A = 100;
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.CreateRGBColor (R, G, B, 100);
  • ArcGIS.Desktop.Mapping.ColorFactory.GreenRGB
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.GreenRGB ;
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.GreenRGB ;
  • ArcGIS.Desktop.Mapping.ColorFactory.GreyRGB
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.GreyRGB ;
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.GreyRGB ;
  • ArcGIS.Desktop.Mapping.ColorFactory.RedRGB
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.RedRGB ;
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.RedRGB ;
  • ArcGIS.Desktop.Mapping.ColorFactory.WhiteRGB
// before:
ArcGIS.Core.CIM.CIMColor result = colorfactory.WhiteRGB ;
// now:
ArcGIS.Core.CIM.CIMColor result = colorfactory.Instance.WhiteRGB ;
  • ArcGIS.Desktop.Mapping.LayerFactory.CanCreateLayerFrom
using layerfactory = ArcGIS.Desktop.Mapping.LayerFactory;
// before:
bool result = layerfactory.CanCreateLayerFrom (item);
// now:
bool result = layerfactory.Instance.CanCreateLayerFrom (item);
  • ArcGIS.Desktop.Mapping.LayerFactory.CreateFeatureLayer
System.Uri dataUri;
ArcGIS.Desktop.Mapping.ILayerContainerEdit mapOrGroupLayer;
ArcGIS.Desktop.Mapping.LayerPosition position = 0;
string layerName = "";
ArcGIS.Desktop.Mapping.RendererDefinition rendererDefinition;
int index;
ArcGIS.Core.CIM.CIMDataConnection dataConnection;
ArcGIS.Core.Data.FeatureClass featureClass;
// before:
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (dataUri, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (dataUri, mapOrGroupLayer, index, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (dataConnection, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (dataConnection, mapOrGroupLayer, index, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (featureClass, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (featureClass, mapOrGroupLayer, index, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (item, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.CreateFeatureLayer (item, mapOrGroupLayer, index, "", rendererDefinition);
// now:
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (dataUri, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (dataUri, mapOrGroupLayer, index, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (dataConnection, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (dataConnection, mapOrGroupLayer, index, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (featureClass, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (featureClass, mapOrGroupLayer, index, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (item, mapOrGroupLayer, 0, "", rendererDefinition);
ArcGIS.Desktop.Mapping.FeatureLayer result = layerfactory.Instance.CreateFeatureLayer (item, mapOrGroupLayer, index, "", rendererDefinition);
  • ArcGIS.Desktop.Mapping.LayerFactory.CreateGroupLayer
ArcGIS.Desktop.Mapping.ILayerContainerEdit container;
int index;
// before:
ArcGIS.Desktop.Mapping.GroupLayer result = layerfactory.CreateGroupLayer (container, index, "");
// now:
ArcGIS.Desktop.Mapping.GroupLayer result = layerfactory.Instance.CreateGroupLayer (container, index, "");
  • ArcGIS.Desktop.Mapping.LayerFactory.CreateLayer
System.Uri dataUri;
int index;
// before:
ArcGIS.Desktop.Mapping.Layer result = layerfactory.CreateLayer (dataUri, mapOrGroupLayer, 0, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.CreateLayer (dataConnection, mapOrGroupLayer, index, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.CreateLayer (dataConnection, mapOrGroupLayer, 0, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.CreateLayer (item, mapOrGroupLayer, index, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.CreateLayer (item, mapOrGroupLayer, 0, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.CreateLayer (dataUri, mapOrGroupLayer, index, "");
// now:
ArcGIS.Desktop.Mapping.Layer result = layerfactory.Instance.CreateLayer (dataUri, mapOrGroupLayer, 0, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.Instance.CreateLayer (dataConnection, mapOrGroupLayer, index, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.Instance.CreateLayer (dataConnection, mapOrGroupLayer, 0, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.Instance.CreateLayer (item, mapOrGroupLayer, index, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.Instance.CreateLayer (item, mapOrGroupLayer, 0, "");
ArcGIS.Desktop.Mapping.Layer result = layerfactory.Instance.CreateLayer (dataUri, mapOrGroupLayer, index, "");
  • ArcGIS.Desktop.Mapping.MapFactory.CanCreateMapFrom
using mapfactory = ArcGIS.Desktop.Mapping.MapFactory;
// before:
bool result = mapfactory.CanCreateMapFrom (item);
// now:
bool result = mapfactory.Instance.CanCreateMapFrom (item);
  • ArcGIS.Desktop.Mapping.MapFactory.CreateMap
string name;
ArcGIS.Core.CIM.MapType mapType = 0;
ArcGIS.Core.CIM.MapViewingMode defaultViewingMode = 0;
ArcGIS.Desktop.Mapping.Basemap basemap = 1;
// before:
ArcGIS.Desktop.Mapping.Map result = mapfactory.CreateMap (name, 0, 0, 1);
// now:
ArcGIS.Desktop.Mapping.Map result = mapfactory.Instance.CreateMap (name, 0, 0, 1);
  • ArcGIS.Desktop.Mapping.StandaloneTableFactory.CanCreateStandaloneTableFrom
using standalonetablefactory = ArcGIS.Desktop.Mapping.StandaloneTableFactory;
// before:
bool result = standalonetablefactory.CanCreateStandaloneTableFrom (item);
// now:
bool result = standalonetablefactory.Instance.CanCreateStandaloneTableFrom (item);
  • ArcGIS.Desktop.Mapping.StandaloneTableFactory.CreateStandaloneTable
ArcGIS.Desktop.Mapping.IStandaloneTableContainerEdit container;
string tableName = "";
ArcGIS.Core.Data.Table table;
System.Uri tableUri;
// before:
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.CreateStandaloneTable (dataConnection, container, "");
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.CreateStandaloneTable (table, container, "");
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.CreateStandaloneTable (item, container, "");
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.CreateStandaloneTable (tableUri, container, "");
// now:
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.Instance.CreateStandaloneTable (dataConnection, container, "");
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.Instance.CreateStandaloneTable (table, container, "");
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.Instance.CreateStandaloneTable (item, container, "");
ArcGIS.Desktop.Mapping.StandaloneTable result = standalonetablefactory.Instance.CreateStandaloneTable (tableUri, container, "");
  • ArcGIS.Desktop.Mapping.StyleHelper.AddStyle
string theCustomStyleToAdd = @"C:\Temp\CustomStyle.stylx";
// before:
await Project.Current.AddStyleAsync(theCustomStyleToAdd);
// now:
await QueuedTask.Run(() => StyleHelper.AddStyle (Project.Current, theCustomStyleToAdd));
  • ArcGIS.Desktop.Mapping.StyleHelper.CreateStyle
string styleToCreate = @"C:\Temp\CustomStyle.stylx";
// before:
await Project.Current.AddStyleAsync(styleToCreate);
// now:
await QueuedTask.Run(() => StyleHelper.AddStyle (Project.Current, styleToCreate));
  • ArcGIS.Desktop.Mapping.StyleHelper.RemoveStyle
// before:
await Project.Current.RemoveStyleAsync("3D Vehicles");
// now:
await QueuedTask.Run(() => StyleHelper.RemoveStyle (Project.Current, "3D Vehicles"));
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructFill
using symbolfactory = ArcGIS.Desktop.Mapping.SymbolFactory;
// before:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.ConstructFill ();
// now:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.Instance.ConstructFill ();
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructHatchFill
ArcGIS.Core.CIM.CIMColor color;
double angle;
double separation;
// before:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.ConstructHatchFill (color, angle, separation);
// now:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.Instance.ConstructHatchFill (color, angle, separation);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructLineSymbol
double width;
ArcGIS.Desktop.Mapping.SimpleLineStyle lineStyle;
ArcGIS.Core.CIM.CIMStroke stroke;
// before:
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.ConstructLineSymbol (color, width, lineStyle);
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.ConstructLineSymbol (stroke);
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.ConstructLineSymbol (color, width);
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.ConstructLineSymbol ();
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.ConstructLineSymbol (color);
// now:
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.Instance.ConstructLineSymbol (color, width, lineStyle);
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.Instance.ConstructLineSymbol (stroke);
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.Instance.ConstructLineSymbol (color, width);
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.Instance.ConstructLineSymbol ();
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.Instance.ConstructLineSymbol (color);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarker
int characterIndex;
string fontFamily;
string fontStyle;
int size;
double size;
ArcGIS.Desktop.Mapping.SimpleMarkerStyle markerStyle;
// before:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (characterIndex, fontFamily, fontStyle);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (characterIndex, fontFamily);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (characterIndex, fontFamily, fontStyle, size, color);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (characterIndex, fontFamily, fontStyle, size);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (color);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker ();
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (color, size, markerStyle);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarker (color, size);
// now:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (characterIndex, fontFamily, fontStyle);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (characterIndex, fontFamily);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (characterIndex, fontFamily, fontStyle, size, color);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (characterIndex, fontFamily, fontStyle, size);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (color);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker ();
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (color, size, markerStyle);
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarker (color, size);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarkerFromBitmapSource
System.Windows.Media.Imaging.BitmapSource bitmapSource;
// before:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarkerFromBitmapSource (bitmapSource);
// now:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarkerFromBitmapSource (bitmapSource);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructMarkerFromStream
System.IO.Stream stream;
// before:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.ConstructMarkerFromStream (stream);
// now:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.ConstructMarkerFromStream (stream);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructPointSymbol
double size;
ArcGIS.Desktop.Mapping.SimpleMarkerStyle style;
ArcGIS.Core.CIM.CIMMarker marker;
// before:
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.ConstructPointSymbol (color, size, style);
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.ConstructPointSymbol (marker);
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.ConstructPointSymbol (color, size);
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.ConstructPointSymbol ();
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.ConstructPointSymbol (color);
// now:
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.Instance.ConstructPointSymbol (color, size, style);
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.Instance.ConstructPointSymbol (marker);
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.Instance.ConstructPointSymbol (color, size);
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.Instance.ConstructPointSymbol ();
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.Instance.ConstructPointSymbol (color);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructPolygonSymbol
ArcGIS.Desktop.Mapping.SimpleFillStyle fillStyle;
ArcGIS.Core.CIM.CIMStroke outline;
ArcGIS.Core.CIM.CIMFill fill;
// before:
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.ConstructPolygonSymbol (color, fillStyle, outline);
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.ConstructPolygonSymbol (fill, outline);
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.ConstructPolygonSymbol (color, fillStyle);
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.ConstructPolygonSymbol ();
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.ConstructPolygonSymbol (color);
// now:
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.Instance.ConstructPolygonSymbol (color, fillStyle, outline);
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.Instance.ConstructPolygonSymbol (fill, outline);
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.Instance.ConstructPolygonSymbol (color, fillStyle);
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.Instance.ConstructPolygonSymbol ();
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.Instance.ConstructPolygonSymbol (color);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructProceduralSymbol
string rulePackagePath;
ArcGIS.Desktop.Mapping.FeatureLayer featureLayer;
System.Collections.Generic.IEnumerable<ArcGIS.Core.CIM.CIMPrimitiveOverride> overrides;
// before:
ArcGIS.Core.CIM.CIMSymbolReference result = symbolfactory.ConstructProceduralSymbol (rulePackagePath, featureLayer, overrides);
// now:
ArcGIS.Core.CIM.CIMSymbolReference result = symbolfactory.Instance.ConstructProceduralSymbol (rulePackagePath, featureLayer, overrides);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructSolidFill
// before:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.ConstructSolidFill (color);
// now:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.Instance.ConstructSolidFill (color);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructStroke
double width;
// before:
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.ConstructStroke (color, width);
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.ConstructStroke (color, width, lineStyle);
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.ConstructStroke ();
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.ConstructStroke (color);
// now:
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.Instance.ConstructStroke (color, width);
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.Instance.ConstructStroke (color, width, lineStyle);
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.Instance.ConstructStroke ();
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.Instance.ConstructStroke (color);
  • ArcGIS.Desktop.Mapping.SymbolFactory.ConstructTextSymbol
double size;
string fontFamilyName;
string fontStyleName;
ArcGIS.Core.CIM.CIMPolygonSymbol symbol;
// before:
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.ConstructTextSymbol (color);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.ConstructTextSymbol (color, size, fontFamilyName, fontStyleName);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.ConstructTextSymbol (symbol, size, fontFamilyName, fontStyleName);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.ConstructTextSymbol ();
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.ConstructTextSymbol (size);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.ConstructTextSymbol (color, size);
// now:
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.Instance.ConstructTextSymbol (color);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.Instance.ConstructTextSymbol (color, size, fontFamilyName, fontStyleName);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.Instance.ConstructTextSymbol (symbol, size, fontFamilyName, fontStyleName);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.Instance.ConstructTextSymbol ();
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.Instance.ConstructTextSymbol (size);
ArcGIS.Core.CIM.CIMTextSymbol result = symbolfactory.Instance.ConstructTextSymbol (color, size);
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultFill
// before:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.DefaultFill ;
// now:
ArcGIS.Core.CIM.CIMFill result = symbolfactory.Instance.DefaultFill ;
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultLineSymbol
// before:
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.DefaultLineSymbol ;
// now:
ArcGIS.Core.CIM.CIMLineSymbol result = symbolfactory.Instance.DefaultLineSymbol ;
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultMarker
// before:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.DefaultMarker ;
// now:
ArcGIS.Core.CIM.CIMMarker result = symbolfactory.Instance.DefaultMarker ;
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultPointSymbol
// before:
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.DefaultPointSymbol ;
// now:
ArcGIS.Core.CIM.CIMPointSymbol result = symbolfactory.Instance.DefaultPointSymbol ;
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultPolygonSymbol
// before:
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.DefaultPolygonSymbol ;
// now:
ArcGIS.Core.CIM.CIMPolygonSymbol result = symbolfactory.Instance.DefaultPolygonSymbol ;
  • ArcGIS.Desktop.Mapping.SymbolFactory.DefaultStroke
// before:
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.DefaultStroke ;
// now:
ArcGIS.Core.CIM.CIMStroke result = symbolfactory.Instance.DefaultStroke ;
  • ArcGIS.Desktop.Mapping.SymbolFactory.GetDictionarySymbol
string dictionaryName;
System.Collections.Generic.Dictionary<stringobject> values;
// before:
ArcGIS.Core.CIM.CIMSymbol result = symbolfactory.GetDictionarySymbol (dictionaryName, values);
// now:
ArcGIS.Core.CIM.CIMSymbol result = symbolfactory.Instance.GetDictionarySymbol (dictionaryName, values);
ArcGIS.Desktop.TaskAssistant.dll
  • ArcGIS.Desktop.TaskAssistant.TaskAssistantModule.CloseTaskAsync
// before:
System.Guid taskGuid;
ArcGIS.Desktop.TaskAssistant.TaskAssistantModule taskassistantmodule;
System.Threading.Tasks.Task result = taskassistantmodule.CloseTaskAsync (taskGuid);
// now:
System.Guid taskItemGuid;
System.Threading.Tasks.Task result = taskassistantmodule.CloseTaskAsync (taskItemGuid);
  • ArcGIS.Desktop.TaskAssistant.TaskAssistantModule.ExportTaskAsync
string path;
// before:
System.Threading.Tasks.Task<string> result = taskassistantmodule.ExportTaskAsync (taskGuid, path);
// now:
System.Threading.Tasks.Task<string> result = taskassistantmodule.ExportTaskAsync (taskItemGuid, path);
  • ArcGIS.Desktop.TaskAssistant.TaskAssistantModule.OpenTaskItemAsync
// before:
System.Threading.Tasks.Task<System.Guid> result = taskassistantmodule.OpenTaskItemAsync (taskGuid);
// now:
System.Threading.Tasks.Task<System.Guid> result = taskassistantmodule.OpenTaskItemAsync (taskItemGuid);
ArcGIS.Desktop.Workflow.dll
  • ArcGIS.Desktop.Workflow.WorkflowModule.ConnectAsync
// before:
ArcGIS.Desktop.Workflow.WorkflowModule workflowmodule;
System.Threading.Tasks.Task<ArcGIS.Desktop.Workflow.Models.WorkflowConnectionStatus> result = workflowmodule.ConnectAsync ();
// now:
System.Threading.Tasks.Task<ArcGIS.Desktop.Workflow.Models.WorkflowConnection> result = workflowmodule.ConnectAsync ();
  • ArcGIS.Desktop.Workflow.Models.JobsManager.CloseJobs
// before:
System.Collections.Generic.IReadOnlyList<int> jobIDs;
ArcGIS.Desktop.Workflow.Models.JobsManager jobsmanager;
System.Collections.Generic.IReadOnlyList<int> result = jobsmanager.CloseJobs (jobIDs);
// now:
System.Collections.Generic.IReadOnlyList<string> jobIDs;
System.Collections.Generic.IReadOnlyList<string> result = jobsmanager.CloseJobs (jobIDs);
  • ArcGIS.Desktop.Workflow.Models.JobsManager.DeleteJobs
bool deleteVersion;
bool deleteHistory;
// before:
System.Int32[] jobIDs;
System.Int32[] result = jobsmanager.DeleteJobs (jobIDs, deleteVersion, deleteHistory);
// now:
System.String[] jobIDs;
System.String[] result = jobsmanager.DeleteJobs (jobIDs, deleteVersion, deleteHistory);
  • ArcGIS.Desktop.Workflow.Models.JobsManager.DeleteMaps
// before:
System.Int32[] result = jobsmanager.DeleteMaps (jobIDs);
// now:
System.String[] result = jobsmanager.DeleteMaps (jobIDs);
  • ArcGIS.Desktop.Workflow.Models.JobsManager.DeleteVersions
// before:
System.Int32[] result = jobsmanager.DeleteVersions (jobIDs);
// now:
System.String[] result = jobsmanager.DeleteVersions (jobIDs);
  • ArcGIS.Desktop.Workflow.Models.JobsManager.GetJob
// before:
string jobID2;
ArcGIS.Desktop.Workflow.Models.JobModels.Job result = jobsmanager.GetJob (jobID2);
// now:
string jobID;
ArcGIS.Desktop.Workflow.Models.JobModels.Job result = jobsmanager.GetJob (jobID);
ArcGIS.Desktop.Workflow.Models.ConfigItems
  • ArcGIS.Desktop.Workflow.Models.ConfigItems.JobTypeDescription.ID
// before:
ArcGIS.Desktop.Workflow.Models.ConfigItems.JobTypeDescription jobtypedescription;
int result = jobtypedescription.ID ;
// now:
string result = jobtypedescription.ID ;
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CanCompleteStep
// before:
int stepID = -1;
ArcGIS.Desktop.Workflow.Models.JobModels.Job job;
System.Tuple<bool,string> result = job.CanCompleteStep (-1);
// now:
string stepID;
System.Tuple<bool,string> result = job.CanCompleteStep (stepID);
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CanExecuteStep
// before:
int stepID = -1;
System.Tuple<bool,string> result = job.CanExecuteStep (-1);
// now:
string stepID;
System.Tuple<bool,string> result = job.CanExecuteStep (stepID);
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CanSetCurrentStep
// before:
int stepID;
bool result = job.CanSetCurrentStep (stepID);
// now:
string stepID;
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.CompleteStep
// before:
int stepID = -1;
ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult result = job.CompleteStep (-1);
// now:
string stepID;
ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult result = job.CompleteStep (stepID);
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.ExecuteStep
// before:
int stepID = -1;
ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult result = job.ExecuteStep (-1);
// now:
string stepID;
ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult result = job.ExecuteStep (stepID);
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.FinishSplitExecutionStep
System.Collections.Generic.IReadOnlyList<string> args;
// before:
int stepID;
ArcGIS.Desktop.Workflow.Models.JobModels.WorkflowExecutionResult result = job.FinishSplitExecutionStep (stepID, args);
// now:
string stepID;
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.GetCurrentSteps
// before:
System.Collections.Generic.IReadOnlyList<int> result = job.GetCurrentSteps ();
// now:
System.Collections.Generic.IReadOnlyList<string> result = job.GetCurrentSteps ();
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.ID
// before:
int result = job.ID ;
// now:
string result = job.ID ;
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.ParentJobID
// before:
int result = job.ParentJobID ;
// now:
string result = job.ParentJobID ;
  • ArcGIS.Desktop.Workflow.Models.JobModels.Job.SetCurrentStep
// before:
int stepID;
job.SetCurrentStep (stepID);
// now:
string stepID;
  • ArcGIS.Desktop.Workflow.Models.JobModels.JobIdentifier.ID
// before:
ArcGIS.Desktop.Workflow.Models.JobModels.JobIdentifier jobidentifier;
int result = jobidentifier.ID ;
// now:
string result = jobidentifier.ID ;
ArcGIS.Desktop.Workflow.Models.Queries
  • ArcGIS.Desktop.Workflow.Models.Queries.JobQueryRow.JobID
// before:
ArcGIS.Desktop.Workflow.Models.Queries.JobQueryRow jobqueryrow;
int result = jobqueryrow.JobID ;
// now:
string result = jobqueryrow.JobID ;
