ArcGIS.Desktop.Mapping Namespace / MapViewKeyEventArgs Class
Properties Methods
    MapViewKeyEventArgs Class Members
    The following tables list the members exposed by MapViewKeyEventArgs.
    Public Properties
     NameDescription
    Public Property Gets the point in client coordinates relative to the top-left corner of the view.
    Public PropertyGets the key that is part of dead key composition to create a single combined character. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets the input device that initiated this event. (Inherited from System.Windows.Input.InputEventArgs)
    Public PropertyGets or sets a value that indicates the present state of the event handling for a routed event as it travels the route. (Inherited from System.Windows.RoutedEventArgs)
    Public PropertyGets the keyboard key referenced by the event, if the key will be processed by an Input Method Editor (IME). (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets the input source that provided this input. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets a value that indicates whether the key referenced by the event is in the down state. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets a value that indicates whether the keyboard key referenced by the event is a repeated key. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets a value that indicates whether the key referenced by the event is in the toggled state. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets a value that indicates whether the key referenced by the event is in the up state. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets the keyboard key associated with the event. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets the keyboard device associated with the input event. (Inherited from System.Windows.Input.KeyboardEventArgs)
    Public PropertyGets the state of the keyboard key associated with this event. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets the original reporting source as determined by pure hit testing, before any possible System.Windows.RoutedEventArgs.Source adjustment by a parent class. (Inherited from System.Windows.RoutedEventArgs)
    Public PropertyGets or sets the System.Windows.RoutedEventArgs.RoutedEvent associated with this System.Windows.RoutedEventArgs instance. (Inherited from System.Windows.RoutedEventArgs)
    Public PropertyGets or sets a reference to the object that raised the event. (Inherited from System.Windows.RoutedEventArgs)
    Public PropertyGets the keyboard key referenced by the event, if the key will be processed by the system. (Inherited from System.Windows.Input.KeyEventArgs)
    Public PropertyGets the time when this event occurred. (Inherited from System.Windows.Input.InputEventArgs)
    Top
    Protected Methods
     NameDescription
    Protected MethodInvokes event handlers in a type-specific way, which can increase event system efficiency. (Inherited from System.Windows.Input.KeyEventArgs)
    Protected MethodWhen overridden in a derived class, provides a notification callback entry point whenever the value of the System.Windows.RoutedEventArgs.Source property of an instance changes. (Inherited from System.Windows.RoutedEventArgs)
    Top
