string openProjectPath = @"D\DATA\IGPHistoryItemTestProject\IGPHistoryItemTestProject.aprx";
Project.OpenAsync(openProjectPath);
MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("Map", StringComparison.CurrentCultureIgnoreCase));
// Note: Needs QueuedTask to run
var map = mapProjItem.GetMap();
var ftrLayer = map.Layers[0] as FeatureLayer;
string tool1 = "management.GetCount";
var args1 = Geoprocessing.MakeValueArray(ftrLayer);
var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
GPExecuteToolFlags executeFlags = GPExecuteToolFlags.AddToHistory;
var t = Geoprocessing.ExecuteToolAsync(tool1, args1, env, null, null, executeFlags);
IEnumerable<IGPHistoryItem> hisItems = Project.Current.GetProjectItemContainer(Geoprocessing.HistoryContainerKey) as IEnumerable<IGPHistoryItem>;
string hitemID = "";
string hitemToolPath = "";
IGPResult hitemGPResult = null;
DateTime hitemTimeStamp;
foreach (var hitem in hisItems)
// common IGPHistoryItem and Item properties
hitemID = (hitem as Item).ID;
hitemToolPath = hitem.ToolPath;
hitemGPResult = hitem.GPResult;
hitemTimeStamp = hitem.TimeStamp;
// use the properties as needed
