ArcGIS.Desktop.Framework.Contracts Namespace / DynamicMenu Class / Add Method / Add(String,String,Boolean,Boolean,Boolean) Method
The menu item label.
The path to an image file to use.
Is the menu button checked. Default is false.
Is the menu button enabled. Default is true.
Is the menu button label bold. Default is false.
    Adds a new item to the menu that points to a delegate.
    Syntax
    Protected Overloads Sub Add( _
       ByVal caption As String, _
       Optional ByVal imagePath As String, _
       Optional ByVal isChecked As Boolean, _
       Optional ByVal isEnabled As Boolean, _
       Optional ByVal isBold As Boolean _
    Parameters
    caption
    imagePath
    isChecked
    isEnabled
    isBold
    Requirements
