ArcGIS.Desktop.Framework.Contracts Namespace / Gallery Class / Insert Method
The zero-based index at which item should be inserted.
The item being added to the gallery.
    Insert Method (Gallery)
    Inserts an element into the collection at the specified index.
    Syntax
    Protected Sub Insert( _
       ByVal index As Integer, _
       ByVal item As Object _
    protected void Insert(
       int index,
       object item
    Parameters
    index
    item
    Remarks
    All items added to the ItemCollection must be created on the main UI thread as these ultimately become the content of buttons added to the gallery popup control.
    Requirements
