//Set the tool's loadOnClick attribute to "false" in the config.daml.
//This will allow the tool to be created when Pro launches, so that the disabledText property can display customized text at startup.
//Remove the "condition" attribute from the tool. Use the OnUpdate method(below) to set the enable\disable state of the tool.
//Add the OnUpdate method to the tool.
//Note: since OnUpdate is called very frequently, you should avoid lengthy operations in this method
//as this would reduce the responsiveness of the application user interface.
bool enableState = true; //TODO: Code your enabled state
bool criteria = true; //TODO: Evaluate criteria for disabledText
if (enableState)
Enabled = true; //tool is enabled
else
Enabled = false; //tool is disabled
//customize your disabledText here
if (criteria)
DisabledTooltip = "Missing criteria 1";
