ArcGIS.Desktop.Framework.Contracts Namespace / PlugIn Class / ID Property
Example
    ID Property (PlugIn)
    Gets the DAML identifier.
    Syntax
    Public ReadOnly Property ID As String
    public string ID {get;}
    Example
    Customize the disabledText property of a button or tool
      //Set the tool's loadOnClick attribute to "false" in the config.daml.
      //This will allow the tool to be created when Pro launches, so that the disabledText property can display customized text at startup.
      //Remove the "condition" attribute from the tool. Use the OnUpdate method(below) to set the enable\disable state of the tool.
      //Add the OnUpdate method to the tool.
      //Note: since OnUpdate is called very frequently, you should avoid lengthy operations in this method
      //as this would reduce the responsiveness of the application user interface.
        bool enableState = true; //TODO: Code your enabled state
        bool criteria = true;  //TODO: Evaluate criteria for disabledText
        if (enableState)
          Enabled = true;  //tool is enabled
        else
          Enabled = false;  //tool is disabled
                            //customize your disabledText here
          if (criteria)
            DisabledTooltip = "Missing criteria 1";
    Requirements
