ArcGIS.Desktop.Framework.Threading.Tasks Namespace / Progressor Class / Max Property
Example
    Max Property (Progressor)
    Gets or sets the maximum range of the progress meter displayed in the progress dialog.
    Syntax
    Public Property Max As UInteger
    public uint Max {get; set;}
    Example
    Cancelable Progressor
      CancelableProgressorSource cps =
        new("Doing my thing - cancelable", "Canceled");
      int numSecondsDelay = 5;
      //If you run this in the DEBUGGER you will NOT see the dialog
      //simulate doing some work which can be canceled
      // Use await with QueuedTask.Run
      QueuedTask.Run(() =>
        cps.Progressor.Max = (uint)numSecondsDelay;
        //check every second
        while (!cps.Progressor.CancellationToken.IsCancellationRequested)
          cps.Progressor.Value += 1;
          cps.Progressor.Status = "Status " + cps.Progressor.Value;
          cps.Progressor.Message = "Message " + cps.Progressor.Value;
          if (System.Diagnostics.Debugger.IsAttached)
            System.Diagnostics.Debug.WriteLine(string.Format("RunCancelableProgress Loop{0}", cps.Progressor.Value));
          //are we done?
          if (cps.Progressor.Value == cps.Progressor.Max) break;
          //block the CIM for a second
          Task.Delay(1000).Wait();
        System.Diagnostics.Debug.WriteLine(string.Format("RunCancelableProgress: Canceled {0}",
                                            cps.Progressor.CancellationToken.IsCancellationRequested));
      }, cps.Progressor);
    Requirements
