ArcGIS.Desktop.Framework.Threading.Tasks Namespace / QueuedTask Class / Run Method / Run(Action,TaskCreationOptions) Method
Example
    Queue a new task to the framework dispatcher thread.
    Syntax
    Public Overloads Shared Function Run( _
       ByVal action As Action, _
       Optional ByVal creationOptions As TaskCreationOptions _
    ) As Task
    Parameters
    action
    creationOptions
    Example
    Progressor - Simple and non-cancelable
      ProgressorSource ps = new("Doing my thing...", false);
      int numSecondsDelay = 5;
      //If you run this in the DEBUGGER you will NOT see the dialog
      QueuedTask.Run(() => Task.Delay(numSecondsDelay * 1000).Wait(), ps.Progressor);
    Cancelable Progressor
      CancelableProgressorSource cps =
        new("Doing my thing - cancelable", "Canceled");
      //simulate doing some work which can be canceled
      // Use await with QueuedTask.Run
        cps.Progressor.Max = (uint)numSecondsDelay;
        //check every second
        while (!cps.Progressor.CancellationToken.IsCancellationRequested)
          cps.Progressor.Value += 1;
          cps.Progressor.Status = "Status " + cps.Progressor.Value;
          cps.Progressor.Message = "Message " + cps.Progressor.Value;
          if (System.Diagnostics.Debugger.IsAttached)
            System.Diagnostics.Debug.WriteLine(string.Format("RunCancelableProgress Loop{0}", cps.Progressor.Value));
          //are we done?
          if (cps.Progressor.Value == cps.Progressor.Max) break;
          //block the CIM for a second
          Task.Delay(1000).Wait();
        System.Diagnostics.Debug.WriteLine(string.Format("RunCancelableProgress: Canceled {0}",
                                            cps.Progressor.CancellationToken.IsCancellationRequested));
      }, cps.Progressor);
    Requirements
