ArcGIS.Desktop.Layouts Namespace / Element Class / SetName Method
String
Example
    SetName Method (Element)
    Sets the name of the element. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetName( _
       ByVal name As String _
    public void SetName(
       string name
    Parameters
    name
    String
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run.
    Remarks
    All elements on a layout must have a unique name so they can be easily referenced.
    Example
    Create Legend 2
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D ll = new Coordinate2D(6, 2.5);
      Coordinate2D ur = new Coordinate2D(8, 4.5);
      Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
      //Reference MF, create legend and add to layout
      MapFrame mf = layout.FindElement("Map Frame") as MapFrame;
      var surroundInfo = new LegendInfo()
        MapFrameName = mf.Name
      var legendElm = ElementFactory.Instance.CreateMapSurroundElement(
        layout, env.Center, surroundInfo) as Legend;
      legendElm.SetName("New Legend");
    Create North Arrow From StyleItem 2
      //Build geometry
      Coordinate2D center = new Coordinate2D(7, 5.5);
      //Reference a North Arrow in a style
      StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
                                     .FirstOrDefault(item => item.Name == "ArcGIS 2D");
      NorthArrowStyleItem naStyleItm = stylePrjItm.SearchNorthArrows(
                                             "ArcGIS North 10")[0];
      //Reference MF, create north arrow and add to layout
      var mf = layout.FindElement("Map Frame") as MapFrame;
      var narrow_info = new NorthArrowInfo()
        MapFrameName = mf.Name,
        NorthArrowStyleItem = naStyleItm
      var arrowElm = (NorthArrow)ElementFactory.Instance.CreateMapSurroundElement(
        layout, center.ToMapPoint(), narrow_info) as NorthArrow;
      arrowElm.SetName("New North Arrow");
      arrowElm.SetHeight(1.75);
      arrowElm.SetX(7);
      arrowElm.SetY(6);
    Update element properties
      //Update an element's properties.
      //Find a single specific element
      element = layout.FindElement("Rectangle") as Element;
      // update an element's name
      element.SetName("New Name");
      // update and element's visibility
      element.SetVisible(true);
    Requirements
