ArcGIS.Desktop.Reports Namespace / Report Class / AddLayoutPage Method / AddLayoutPage(Item,String) Method
The layout item.
The name of the report section that the page will be added before. If null, the page is added to the end of the report. If empty, the page is added to the beginning of the report.
    Adds a layout page section to the report. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub AddLayoutPage( _
       ByVal layoutItem As Item, _
       ByVal insertSectionName As String _
    public void AddLayoutPage(
       Item layoutItem,
       string insertSectionName
    Parameters
    layoutItem
    The layout item.
    insertSectionName
    Exceptions
    ExceptionDescription
    The layoutItem is invalid.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
