ArcGIS.Desktop.Mapping Namespace / IDisplayTable Interface / GetTable Method
    GetTable Method (IDisplayTable)
    Returns the underlying table or feature class. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Function GetTable() As Table
    Table GetTable()
    Return Value
    Exceptions
    ExceptionDescription
    Remarks
    To ensure maximum robustness, callers should explicitly dispose of the returned ArcGIS.Core.Data.Table in either a using statement or a finally block.
    Requirements
