ArcGIS.Desktop.Mapping Namespace / IDisplayTable Interface / SetSelectable Method
A boolean to make it selectable.
    SetSelectable Method (IDisplayTable)
    Toggles the selectability of a MapMember. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub SetSelectable( _
       ByVal isSelectable As Boolean _
    void SetSelectable(
       bool isSelectable
    Parameters
    isSelectable
    Exceptions
    ExceptionDescription
    Remarks
    It only affects interactive selecting features of a layer off a map view, does not have any when IDisplayTable.Select method is called.
    Requirements
