ArcGIS.Desktop.Mapping Namespace / IDisplayTable Interface / SetSelectRelatedData Method
A boolean value indicating if related data should be selected when creating a new selection.
    SetSelectRelatedData Method (IDisplayTable)
    Toggles the SelectRelatedData of a MapMember. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Sub SetSelectRelatedData( _
       ByVal selectRelatedData As Boolean _
    void SetSelectRelatedData(
       bool selectRelatedData
    Parameters
    selectRelatedData
    Exceptions
    ExceptionDescription
    Requirements
