ArcGIS.Desktop.Mapping Namespace / SimpleFillStyle Enumeration
Example Example
    Specifies simple fill style.
    Syntax
    Members
    MemberDescription
    BackwardDiagonal A hatched fill with evenly spaced diagonal lines at a -45° angle.
    Cross A hatched fill with evenly spaced horizontal and vertical lines.
    DiagonalCross A hatched fill with evenly spaced diagonal lines crossing each other at 90° angles.
    ForwardDiagonal A hatched fill with evenly spaced diagonal lines at a 45° angle.
    Horizontal A hatched fill with evenly spaced horizontal lines.
    Null An empty fill that does not draw.
    Solid A uniform solid fill of one color.
    Vertical A hatched fill with evenly spaced vertical lines.
    Example
    Create Ellipse Graphic Element
      //Note: Must be on QueuedTask.Run
      //Build geometry
      Coordinate2D center = new Coordinate2D(2, 2.75);
      var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45,
                                          ArcOrientation.ArcClockwise);
      var ellipse = eabElp.ToSegment();
      //Set symbology, create and add element to layout
      CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
                                      ColorFactory.Instance.GreenRGB, 2.0,
                              SimpleLineStyle.Dot);
      CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                                ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical,
                                                        outline);
      var poly = PolygonBuilderEx.CreatePolygon(
        PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
      var elpElm = ElementFactory.Instance.CreateGraphicElement(
        layout, poly, ellipseSym, "New Ellipse");
    Create Lasso Polygon, Freehand Element
      List<Coordinate2D> plyCoords = new List<Coordinate2D>();
      plyCoords.Add(new Coordinate2D(1, 1));
      plyCoords.Add(new Coordinate2D(1.25, 2));
      plyCoords.Add(new Coordinate2D(1.5, 1.1));
      plyCoords.Add(new Coordinate2D(1.75, 2));
      plyCoords.Add(new Coordinate2D(2, 1.1));
      plyCoords.Add(new Coordinate2D(2.25, 2));
      plyCoords.Add(new Coordinate2D(2.5, 1.1));
      plyCoords.Add(new Coordinate2D(2.75, 2));
      plyCoords.Add(new Coordinate2D(3, 1));
      Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
                  ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
      CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
               ColorFactory.Instance.RedRGB, SimpleFillStyle.ForwardDiagonal, outline);
        layout, poly, polySym, "New Lasso");
    Create Polygon Element
      //Build geometry
      plyCoords.Add(new Coordinate2D(1, 7));
      plyCoords.Add(new Coordinate2D(2, 7));
      plyCoords.Add(new Coordinate2D(2, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.7));
      plyCoords.Add(new Coordinate2D(3, 6.1));
      plyCoords.Add(new Coordinate2D(1, 6.1));
        ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.DashDotDot);
        layout, poly, polySym, "New Polygon", false);
    Create rectangle graphic with simple symbology
      //Create a simple 2D rectangle graphic and apply simple fill and
      //outline symbols.
      //Build 2D envelope geometry
      Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
      Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
      Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
        ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
        ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
      GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
        layout, rec_env, polySym, "New Rectangle");
      //Or use Predefined shape
      GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                                layout, PredefinedShape.Rectangle, rec_env, polySym,
                                "New Rectangle2");
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.SimpleFillStyle
    Requirements
