ArcGIS.Desktop.Mapping Namespace / TIFFImageCompression Enumeration
Example Example
    Specifies the compression scheme used to compress image or raster data in the output file.
    Syntax
    Members
    MemberDescription
    Deflate Lossless compression method that works well for most cases.
    JPEG Lossy compression method that works well for photographic-type images.
    LZW Lossless compression method using a code table.
    None Compression is not applied.
    Packbits Lossless compression method that works well if there are large areas of the same color.
    Example
    Export a map series to individual TIFF files
      //Export each page of a map series to an individual TIFF file.
      string filePath = @"Path and file name for the output export file";
      //Create TIFF format with appropriate settings
      TIFFFormat TIFF = new TIFFFormat()
        OutputFileName = filePath,
        Resolution = 300,
        ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
        HasGeoTiffTags = true,
        HasWorldFile = true,
        ImageCompression = TIFFImageCompression.LZW
      //Set up map series export options
      MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
        ExportPages = ExportPages.All,  //All pages
        ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
        ShowSelectedSymbology = true  //Include selection symbology in the output
      //Export on the worker thread
      //Check to see if the path is valid and export
      if (TIFF.ValidateOutputFilePath())
        await QueuedTask.Run(() => layout.Export(TIFF, MSExportOptions_TIFF));  //Export to TIFF
    Inheritance Hierarchy
    System.Object
       System.ValueType
          System.Enum
             ArcGIS.Desktop.Mapping.TIFFImageCompression
    Requirements
